 Post subject: WD2500BEVT-60ZCT1 Firmware needed
PostPosted: October 28th, 2009, 18:19
I am in need of firmware including resource file (loader) for WD2500BEVT-60ZCT1.
SD would be my preference but I should be able to make UDMA work as well.
Thanks & I appreciate it as always.
 Post subject: Re: WD2500BEVT-60ZCT1 Firmware needed
PostPosted: October 28th, 2009, 20:23
FW version?
PostPosted: October 29th, 2009, 9:08
Pepe,
It's T1.
PostPosted: October 29th, 2009, 12:58
i Have this
Pm me email.
ZeBong
" Россия еще раз"
PostPosted: October 29th, 2009, 13:02
PM send, thanks for taking the time to check your inventory.
PostPosted: October 29th, 2009, 13:10
Check email :)
ZeBong
" Россия еще раз"
PostPosted: October 29th, 2009, 13:20
Thanks :mrgreen:
PostPosted: October 29th, 2009, 13:31
T1 does not tell anything here...
it should be a number like 00020021 or something like that. U can check ROM module 4F for that version.
PostPosted: February 6th, 2010, 11:36
I also have a problem with WD3200BEVT-60ZCT1 drive. Firmware Revision is 13.01A13.
This drive was originally inside in a HP RDX cartridge (Q2041A).
BIOS and HDD-info softwares can see all drive parameters, but can't read/write the disk.
I guess that HP put a special FW to that, what do you think?
Is it possible to replace the firmware, or revive this drive to use as a normal HDD?
Thanks, in advance.
Greetings,
TF
Users browsing this forum: Bing [Bot] and 107 guests
