 Post subject: Error on WD Raptor
PostPosted: February 14th, 2010, 12:34
Hey all!
I've got an WD Raptor:
Model: WDC WD1500ADFD-00NLR5
Firmware: 21.07QR5
Serial: WD-WMAP41614947
LBA: 293046768
This drive ran under Win Vista 64-bit Ultimate and just stopped working from time to time giving a Bluescreen. I took a picture of it and attached it for you to see.
After this it ran Checkdisk and found a couple of errors. Attached the screen from this event to.
After this it happens again and this time it bluescreend and gave the same error .. and I tried to star in Fail safe mode. This worked until it got to the file CRCDISK.SYS then it hang again.
Now I have bougt a SSD-drive insted but i reconnected te Raptor and formated it. No errors, know I'm starting to worrie that there maybe is another error causing this behavior. Any hints on what causes these problems, or can I assume that the Raptor is the cause of the problem?
Here is the SMART output from the raptor:
Firmware: 21.07QR5
LBA: 293046768
Report By: HDDScan for Windows version 3.1
Report Date: 2010-02-14 17:31:38
Num Attribute Name Value Worst Raw(hex) Threshold
001 Raw Read Error Rate 200 200 00000000-0000 051
003 Spin Up Time 166 162 00000000-125C 021
004 Start/Stop Count 099 099 00000000-04AF 040
005 Reallocation Sector Count 200 200 00000000-0000 140
007 Seek Error Rate 200 200 00000000-0000 051
009 PowerOn Hours Count 093 093 00000000-1659 000
010 Spin Retry Count 100 100 00000000-0000 051
011 Recalibration Retries 100 100 00000000-0000 051
012 Device Power Cycle Count 099 099 00000000-049E 000
194 HDA Temperature 102 097 45 C 000
196 Reallocation Event Count 200 200 00000000-0000 000
197 Current Pending Sector Count 200 200 00000000-0000 000
198 Uncorrectable Sector Count 200 200 00000000-0000 000
199 UltraDMA CRC Error Count 200 253 00000000-0869 000
200 Write Error Rate 200 200 00000000-0000 051
Best regards
Fredrik L
Sweden
 Post subject: Re: Error on WD Raptor
PostPosted: February 15th, 2010, 13:01
I wouldn't run any more chkdsk operations. You definitely appear to have some file system corruption. I'm sure one of the off the shelf solutions that are out there like RStudio, Runtime or something like that should help. Make an image of the drive first before you start the actual recovery.
PostPosted: February 16th, 2010, 13:45
The disc is already unmounted and replaced.
I just want to find a way to find out if, and how, it was broken.
I want to eliminate other possible casuse such as a faulty Motherborad.
Don't want this to happen again.
/lynch
PostPosted: February 16th, 2010, 21:10
I believe UDMA CRC errors suggest cabling or communications problems between the drive and the SATA controller.
I don't know about Vista, but Windows XP downgrades the drive from DMA mode to PIO mode after it detects 6 CRC errors.
Users browsing this forum: No registered users and 156 guests
