 Post subject: WD800UE-00KVT0 firmware fault?
PostPosted: March 11th, 2010, 7:13
I wondered if there were any known issues with the firmware on WD800UE series drives? At the moment I can not not access any LBA value. The heads seem OK, and I have access to the SA. I have errors on modules (on both heads 0 & 1) on:
0034 - G-List
0032 - RBBLIST
0021 - SMART Table
0022 - SMART Table
I've tried resetting the G-list & SMART but it does not make a difference. I don't have a donor for this drive I only have the more common WD800UE-xxHCT0.
Any help with this one would be much appreciated,
best wishes,
John
0161 408 4857
 Post subject: Re: WD800UE-00KVT0 firmware fault?
PostPosted: March 11th, 2010, 7:16
Rewrite all modules from close matching donor, clear SMART, clear GLIST, rebuild translator.
PostPosted: March 11th, 2010, 7:44
Yes I had a feeling that might be the case, now just the task of finding WD800UE-00KVT0 firmware in SD format! I've found a WD1200UE-00KVT0 which might do the job, I will post the results,
best wishes,
John
PostPosted: March 11th, 2010, 8:37
why you looking for firmware need full model same? :shock:
data recovery service[/b]
PostPosted: March 12th, 2010, 8:21
can't you use pc3000 mods in SD?
Just rename the file extensions or compare mods in hex editor.
Or buy a donor.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], pepe and 135 guests
