 Post subject: HP Proliant ML350 G5
PostPosted: March 16th, 2010, 5:15
server has Raid5 configured in 4x750GB Seagate ST3750330NS server was Down i check HDD's i got first drive gone Bad Firmware Locked i Repair HDD it is working fine now i return back that drive in server it is not taking that drive showing Drive Disable if u want to Enable press F2 data will loss like this 1779 Error i Boot with Raid utility CD i can see my Raid Controller it shows 2 Partitions in it but it has Cross Mark if i try to Re-enable it shows Data will loss Any Idea appreciate for All Comments.
Controller : Smart Array E200i
 Post subject: Re: HP Proliant ML350 G5
PostPosted: March 16th, 2010, 6:11
i think is better you try to acess the array with winhex.
ZeBong
" Россия еще раз"
PostPosted: March 16th, 2010, 6:26
Image all 4 drives before you do anything else
Users browsing this forum: Google [Bot], huangmiaofang and 216 guests
