 Post subject: WD800BB-00JHC0 couldn't write modules?
PostPosted: October 15th, 2009, 17:13
Hello gurus
I have this case (WD800BB-00JHC0) can not write mods. (21,22) SMART
and mod. (32) RBBLIST with SD Doctor for WD
any help will be appreciated
 Post subject: Re: WD800BB-00JHC0 couldn't write modules?
PostPosted: October 15th, 2009, 19:41
did you test heads?
www.datarecoveryne.com
PostPosted: October 15th, 2009, 20:12
thanks for reply harddrivespecialist,
yes I did, and the two heads looks fine.
I think it's a bad sectors in the SA ?
the drive take long period to detect and make some sounds after recalibration and shows busy for long period to get ready
PostPosted: November 3rd, 2009, 22:19
Problem 100% solved gurus :wink:
PostPosted: November 4th, 2009, 4:31
And your solution?
PostPosted: November 4th, 2009, 6:25
I vote relocation.
PostPosted: November 4th, 2009, 6:36
This forum is for asking questions. Not giving solutions LMFAO take take take...la la laaaaaa
PostPosted: November 4th, 2009, 8:47
it wasn't relocation (thatdellguy) :)
it was very simple than that.
P9 and P10 (PCB) made the job perfectly
PostPosted: November 4th, 2009, 8:52
this drive opened to me a solutions for several families with the same defect.
Starling,unicorn,sabre,mamoth even new royal drives that still busy always then spindown and not detected.
PostPosted: November 4th, 2009, 18:21
I forgot ( and hawk too ) :)
relocation with marvell is very hard work I think, maybe in older drives relocation maybe useful
PostPosted: November 5th, 2009, 8:08
Good it worked for you. Will try it when I have a drive like that :O)
PostPosted: March 9th, 2010, 4:17
hello unknown20010 and guru
can u be more specific abour how u resolved the problem ?
i am not sure i understood "P9 and P10 (PCB) made the job perfectly"
appreciate your assistance
ephraim
ephraim
PostPosted: March 14th, 2010, 9:50
hello unknown20010 and guru (2nd request for help)
ephraim
ephraim
PostPosted: March 15th, 2010, 4:47
I haven't had a drive like that so I cannot help :O)
PostPosted: March 15th, 2010, 4:56
Easy, you did a smart erase :) I have had a few like this.
Zero Alpha: zeroalpha.com.au
PostPosted: March 15th, 2010, 5:01
P9 is a Hammer.
P10 is chisel.
PostPosted: March 16th, 2010, 12:26
hello unknown20010
received your answer. tks.
what to do after shortening?
do i need special tools?
can u give more details?
i was walking in the forum. found some words. not really too clear.
tks again for your assistance
ephraim
Users browsing this forum: Google [Bot], Majestic-12 [Bot], pepe and 135 guests
