 Post subject: Maxtor DiamondMax 20 - Bad Diode
PostPosted: March 17th, 2010, 23:19
Hello everyone,
Kinda found the board and hoping I could possible get some help. I'm a programmer, not a EE/CE >_<
My external died and I figured the controller just went. Hooked everything up with another IDE-to-USB to find smoke coming from it. Seems like its coming from a diode right in front of the power.
I don't have a camera on me, but I can get a picture if you want. The damage in minimal, there isn't even a burn mark on the board, but the diode is cracked and that's where the smoke is coming from.
Anyways, I believe I can just replace the PCB bored, but I'm not positive and would like some of you pro to let me know what you think. Its a Maxtor DiamondMax 20 160 GB PATA. Any and all help would be appreciated. Thanks.
Thanks,
Daniel
 Post subject: Re: Maxtor DiamondMax 20 - Bad Diode
PostPosted: March 18th, 2010, 0:30
It is TVS more than likey but post photos to make sure. It is actually TVS you can remove it and get your data then trash the drive
Iorana Haraharaini
PostPosted: March 18th, 2010, 0:31
Search for a TVS on the forum.
PostPosted: March 18th, 2010, 0:32
A picture would definitely be helpful. Do a search for "TVS" diode, read a little. The drive is unprotected once that is removed, and the USB adapters usually come with the cheapest power supply made. You definitely don't want to use that on a drive in that condition. Hook it up internaly
PostPosted: March 18th, 2010, 5:29
Be careful you may smoke your motor IC too.
Users browsing this forum: Majestic-12 [Bot], pepe and 147 guests
