 Post subject: PCB Swap on Seagate Pipeline HD
PostPosted: March 29th, 2010, 10:39
I am trying to swap the PCB on a seagate pipeline HDD model number ST3320310CS.(all the pcb's i am replacing are from drives which are not spinning up)
I have matched all the numbers which are normally required but all i am getting is corrupt firmware.
Does anyone have any idea about what else is required with these drives?Any help would be much appreciated.
Markhig2 :)
 Post subject: Re: PCB Swap on Seagate Pipeline HD
PostPosted: March 29th, 2010, 11:04
markhig2 wrote:
corrupt firmware
What does this mean?
Terminal log would help.
PostPosted: March 29th, 2010, 11:22
Our sytem doesn't give a log, im testing the drive to make sure it is test ready, so it will give a pass or fail. In this case im just getting Corrupt firmware.
This is not uncommon and usually means the drive is bad, but all of the drives i have swapped boards on say this, so im guessing there is something else which needs to be done. Perhaps a Rom chip?Or will i need to use PC3000 or something?
Markhig2 :(
PostPosted: March 29th, 2010, 12:11
Looking more, looks like those are F3 architecture which means the ROM contains adaptives, yes. PC3000 does not support these currently.
Users browsing this forum: No registered users and 168 guests
