May 1st, 2013, 9:15
May 1st, 2013, 13:50
May 1st, 2013, 14:53
C, H and S are the cylinder number, the head number, and the sector number
LBA is the logical block address
HPC is the maximum number of heads per cylinder (reported by disk drive, typically 16 for 28-bit LBA)
SPT is the maximum number of sectors per track (reported by disk drive, typically 63 for 28-bit LBA)May 1st, 2013, 15:03
May 1st, 2013, 15:30
labtech wrote:Indeed, it jumps from head to head on most of the modern drives where the recording is taking place perpendicularly.
Some modern drives, Samsung in particular, have larger zones on a given head, therefore increasing the possibility of recovering "bigger" files.
Needless to say, WD, Seagate, as you said, chances are very slim to recover from.
May 1st, 2013, 16:35
louis wrote:@fzabkar do you have any idea how LBA gets incremented over the tracks/sectors?
let's say we have a 2 headed drive with 5 zones
H0 tracks 1-n
H1 tracks 1-n
the LBA will go from H0 track 1->n through each one of the 5 zones...or it jumps from time to time to H1?
May 1st, 2013, 17:03
1. MHDD sends VERIFY SECTORS command with LBA number and
number of sectors to verify as parameters
2. DRIVE raises BUSY flag
3. MHDD starts timer
4. After drive executes VERIFY command, it drops BUSY flag
5. MHDD counts the time and puts corresponding block
on the screen. If error occures MHDD prints corresponding
letter which describes the error.
MHDD scans drives by blocks. For IDE/SATA drives one block is 255 sectors
May 1st, 2013, 18:50
Current Head = 0x0
No. of Zones = 21
Zone 0
First Virt. cyl .. = 0xffffff56 (-170)
Last Virt. cyl... = 0xffffffff (-1)
SPT .............. = 0x051f (1311)
Zone 1
First Virt. cyl .. = 0x0000 (0)
Last Virt. cyl... = 0x39d2 (14802)
SPT .............. = 0x0816 (2070)
Zone 2
First Virt. cyl .. = 0x39d3 (14803)
Last Virt. cyl... = 0x6f3b (28475)
SPT .............. = 0x07e8 (2024)
Zone 3
First Virt. cyl .. = 0x6f3c (28476)
Last Virt. cyl... = 0x9848 (38984)
SPT .............. = 0x07c3 (1987)
Zone 4
First Virt. cyl .. = 0x9849 (38985)
Last Virt. cyl... = 0xd450 (54352)
SPT .............. = 0x078c (1932)Current Head = 0x1
No. of Zones = 21
Zone 0
Zone 1
Last Virt. cyl... = 0x3bff (15359)
SPT .............. = 0x0831 (2097)
Zone 2
First Virt. cyl .. = 0x3c00 (15360)
Last Virt. cyl... = 0x65b7 (26039)
Zone 3
First Virt. cyl .. = 0x65b8 (26040)
Last Virt. cyl... = 0xa2a7 (41639)
Zone 4
First Virt. cyl .. = 0xa2a8 (41640)
Last Virt. cyl... = 0xcdc7 (52679)
SPT .............. = 0x07ba (1978)Current Head = 0x2
No. of Zones = 21
Zone 0
Zone 1
Zone 2
Zone 3
Zone 4
SPT .............. = 0x078c (1932)Current Head = 0x3
No. of Zones = 21
Zone 0
Zone 1
Last Virt. cyl... = 0x4543 (17731)
Zone 2
First Virt. cyl .. = 0x4544 (17732)
Last Virt. cyl... = 0x705f (28767)
SPT .............. = 0x0764 (1892)
Zone 3
First Virt. cyl .. = 0x7060 (28768)
Last Virt. cyl... = 0xa33b (41787)
SPT .............. = 0x0747 (1863)
Zone 4
First Virt. cyl .. = 0xa33c (41788)
Last Virt. cyl... = 0xd237 (53815)
SPT .............. = 0x071d (1821)May 2nd, 2013, 16:18
May 2nd, 2013, 16:53
May 7th, 2013, 17:04
May 17th, 2013, 7:49
May 19th, 2013, 4:58
May 19th, 2013, 5:25
fzabkar wrote:Tyco's web site is offering free samples (don't all rush at once). Otherwise it is available over here for AU$14.
May 19th, 2013, 6:05
May 19th, 2013, 6:24
louis wrote:the conn name it's spec in a link in my prev post.
May 19th, 2013, 6:44
May 19th, 2013, 7:03
