Re: Maxtor Safe mode jumper
March 24th, 2009, 15:04
This tool doesnot support the ALTSA loader it gives an error while loading it no use trying it .
And this tool works in DEC mode while pc3k works in HEX mode so be carefull while writing and reading SA .
March 24th, 2009, 15:27
rameez wrote:This tool doesnot support the ALTSA loader it gives an error while loading it no use trying it .
I want to add a little correction:
This tool supports both the ALT and non-ALT loaders, but only some times. :mrgreen:
Janos
March 29th, 2009, 6:16
But i have never had luck with N40P switching to SA-C with this tool .
March 31st, 2009, 13:34
Thanks for replies!
I will not try ALT-SA.
But can I try/do SelfScan with HDRepair?
And what is the conditions of SS ?
March 31st, 2009, 15:18
Want to buy some know-how ? :mrgreen:
April 1st, 2009, 16:44
Before I buy I ask.
Is all Maxtor drive has ALT-SA?
April 1st, 2009, 18:05
Unfortunately there are things that money cannot buy (assuming having the money, at first). Enough said.
April 1st, 2009, 22:41
NO
April 5th, 2009, 11:51
Hi all! Thanks for replies.
There is an empty (AA55) 95h modul on a N40P DM+8 hdd.
Is ALT_SA or no on this drive? How can I check it?
I assume not all N40P has an ALT_SA.
Is it possible to rebuild a bad/corrupt 33h module?
SelfScan=SelfTest?
BlackST:I do not plan to buy here anything. I need Info.
April 5th, 2009, 16:20
SelfScan=SelfTest?
Yes .
April 5th, 2009, 16:23
For a little correction:
Smart SelfTest != SelfScan
Janos
April 5th, 2009, 16:38
Thanks rameez!
Every information is important.
I have another (simple or no) question.
How can I check the checksum of a loader, if it is not in the name of the file ? Maybe with Winhex?
April 5th, 2009, 16:44
Hi Janos and thanks!
Yes, I know -Smart- SelfTest not equal with SelfScan.
April 6th, 2009, 15:20
You can check the checksum with the maxtor checksum utility . You can find it on Hddguru file section .
April 8th, 2009, 7:42
Thank you rameez!
I found it.
April 8th, 2009, 12:25
Hi all!
Some N40P hdd has ALT-SA and some has no.
How can I check it, which has, without PC3000?
For example: mod 95h or external ROM exist or others.
April 8th, 2009, 14:57
Iszerda wrote:Hi all!
External rom can be for a lot of purpose....
Example if the platter is lean on the planned SA area, the mfg can write another location or another BIAS value or similar for the SA, to be able to use.....
The external rom is independent from the ALT-SA.
Janos
April 8th, 2009, 15:46
All N40P should have Alt-SA
April 8th, 2009, 16:23
Try switching to ALT-SA with SA-c LDR .
Its rare to find n40p with no ALT-SA .
April 8th, 2009, 17:54
Thanks to Janos, rameez, harddrivespecialist!
Somewhere I read: If there is no external ROM that board sure support ALT-SA. Is it right?
Now I am searching for C loader, but I did not found it yet in File Section.
Can I use a COD file and rename as LDR?
My drive is:
6E040L0510605 AAA KMCA NAR61590 B8FEA E1G38P2E
