Re: Help needed: WD10EADS-00L5B1
January 6th, 2010, 9:12
pninja wrote:
jono-ats wrote:You should ask Ace Lab this question. I have my own theories.
Suffice it to say that sometimes heads will pass the heads test, but you still cannot read customer LBAs. If a head passes the test but doesn't function in Data Extractor, then it is bad.
Hi jono-ats,
I don't say that head-test algorithm of ACE lab is absolute or perfect, it just helps
me to decide the head-swap as a first or last action in my data recovery process.
As to your example, I think you didn't choose a good example in this case. Head test
routine tests heads based on their physical parameters, while accessing usre LBAs in
data extractor involves logical parameters and translator tables too. Failing to access user
LBAs doesn't mean a faulty head necessarily. Please correct me if I am wrong.
You are correct. My statement was over-inclusive and thus faulty. However, in cases such as WD5000KS, replacing a head that fails in DE often resolves the problem. Therefore DE is one way to diagnose such bad heads.
January 12th, 2010, 22:00
Finally I could find a matching donor and was able to get about 60% of
data (300GB) using Hot swap.
Thank you all for your valuable hints and comments.
regards
pninja
March 24th, 2010, 19:29
hi pninja~
i was wondering if you still have modules for this drive
Details:
Model: WD10EADS-00L5B1
Date: 20 APR 2009
DCM: DANNNT2CFN
Firmware: 01.01A01
Firmware version: 000500C5
i need module 3 pretty desperatly.
it would be super if you could share
thanks
bfg
March 24th, 2010, 21:46
bfg wrote:hi pninja~
Details:
Date: 20 APR 2009
DCM: DANNNT2CFN
Firmware: 01.01A01
thanks
bfg
Here it is. I hope it helps.
Pninja
WD10EADS-00L5B1_000500C5_Mod03.zip
(5.52 KiB) Downloaded 288 times
March 25th, 2010, 17:52
it did not work.
all other modules are fine.
did you have any luck replacing module 3 in the past on newer Wd drives
thanks
