Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10EAVS-32D7B1 unable to read data
PostPosted: March 4th, 2010, 13:51
Alexii wrote:
And a smiley at the end of criptic message does not give it much credo.
Will apsence of smiley at the end give it more credibility? I don't think so.
Alexii wrote:
All "might be's"...
Stick around in data recovery for few years and you will be saying the same thing, because there is a lot of variables in this trade.
Alexii wrote:
This gets so tiering lately...
Do you think its not "tiering" to retype same info over and over again, because someone does not want to do a research?
As far as I know, people on this forum, will help you or will point you to a right direction, but not many people, if any, would like to "spoonfeed" others.
Just search and read, search again and read again and your happiness will come eventually.
www.datarecoveryne.com
PostPosted: March 4th, 2010, 14:48
ty all. close thread plz.
PostPosted: March 6th, 2010, 22:32
hddguy wrote:
In some cases head replacment is successful, but some heads may not be aligned. One way in which a HotSwap can help in such situations can sometimes provide access to SA and in fact data.
I can see from your posts that while you are eager, you are not very experienced. Also, you seem quite confident that a head replacement procedure will work for you. Have you tried this before?
with my experience some of these case i will pass head replacement first. why make it more complexity
@Alexii you should do more and think more. these kind of drive no hard to understand.
data recovery service[/b]
PostPosted: March 7th, 2010, 2:22
hddguy, :D
PostPosted: March 7th, 2010, 6:12
networkpc3000 wrote:
with my experience
Alexii has not enough experience...
Agreed, but alternatives require knowledge and experience...
Alexii has confidence it will work....
PostPosted: March 9th, 2010, 12:27
Yes. I did succesfull head swaps before. And I did head swap on a trashed drive we had in our bin with same specs as the one in question. That drive also had the access to SA only , no lba. To test myself i removed those heads and put them back in. Same access to SA only after the procedure. Going to source the drive and try to put good heads in. Now like i already explained myself , i maybe misundertood HddSpazes reply here, but what trigered me was "why not both " part. If i do the head swap - there is absolutly no need for a HOT swap ... So i felt like i am being yanked a bit... On another note we hav 3 drives that fail in exactly the same way. That usually indicates specific problem with a specific drive. Faulty batch came from the factory with weak heads or smth. Or logical issue with adaptives or smth. Thats why i requested help. Not for the purpose of general diagnostics. Yet it seems that nothing is specific. Like i was told , a gentleman here did some of em with head swap , some with hot swap , and some with no "swap" at all ( that last part intrigues me , but i guess ill be told to do my own research into the problem, so ill just drop it ) Anyway , if there is nothing specific about that drive model going on and its all just random fails - ill treat it as such. Ty all again.
PS Just got a wd1600JS-40mvb1 to play with. Removed heads and put em back =) Still working. Going to do it till it dies on me.
Users browsing this forum: No registered users and 76 guests
