Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: is there an HDD duplicator that doesnt cost thousands?
PostPosted: August 2nd, 2010, 10:38
BlackST wrote:
I know, but everybody think that DR is easy, what to say ? :(
the true will say something to him :)
data recovery service[/b]
PostPosted: August 7th, 2010, 6:01
drc wrote:
0ldfart wrote:
Specifically what is it that the dedicated hardware units are able to do that software can't?
Deal with errors in a predictable and specified way
Along with power regulating functions. You can't power restart a drive every time it hits a bad sector. Especially when you may need to do it probably a thousand times. Can you?
Bitlevel Data Recovery
PostPosted: August 7th, 2010, 11:03
So how do these expensive duplicators actually handle 'damaged' drives that wont appear ready
and/or manage to skip a bad heads (other than trying to calculate what LBA's to skip)
or somehow handle weak heads
Unless they have some firmware override (like factory mode etc)
then surely there is no way , using standard ata commands, to read sectors from disks that wont come ready
Or can they only handle disks that are ready but wont read (or hang) on certain sectors -- in which case what advance other than speed (and hardware resetting) do they give ?
Or maybe they use the read long commands as well, to try to overcome ecc? errors
"Also as has been pointed out any hardware/software combination is of no or little use if the drive has certain mechanical or firmware problems so bear that in mind."
PostPosted: August 7th, 2010, 13:02
This is why these instruments cost "a lot" (everything is relative).
Again, if you really want, you can make on your own, but you have to struggle and test and study and experiment : the manufacturers of these instruments ask you this in return. That's the market.
PostPosted: August 8th, 2010, 7:40
exactly !
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
PostPosted: August 18th, 2010, 13:06
Some good info on a hardware based imager
http://www.deepspar.com/pdf/DeepSparDis ... paper3.pdf
PostPosted: September 6th, 2010, 15:46
If your could program your own tools you can use something like this
http://www.sigma-shop.com/product/8/-us ... d-12v.html
Control The power and also control fan operation just in case the drive gets too warm while imaging. You could go all the way and code your own SATA/IDE/SCSI drivers for use in Linux with direct connection into hardware :O)
The world could be your oyster!
Users browsing this forum: No registered users and 287 guests
