Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: How do I repair a fried WD PCB board?
PostPosted: February 9th, 2011, 15:28
If ur preamp didnt bite the dust - there is still chance.
PostPosted: February 9th, 2011, 15:55
Even if it did... :mrgreen:
PostPosted: February 9th, 2011, 17:30
When I receive the PCB tomorrow and install it on to the HD if it spins and seen by my computer then that would be a lucky escape. :D
If I install it tomorrow and nothing spins then I know I have blown the pre amp and possibly my chances of recovering the data. :cry:
Due to the costs of pre-amp recovery by DATA RECOVERY firms then I would have to put it down to experience and give it a miss. :oops:
What will be will be... :(
PostPosted: February 10th, 2011, 1:00
jan5ki wrote:
fzabkar. What do you think?
I would first ask your repairer to confirm the presence of the onboard voltages at Q1 (linear regulator) and at the switchmode DC-DC converters near the SMOOTH chip. Also get him to test for the presence of the +5V and -5V supplies at the preamp pads. If these are OK, then I would have more confidence in a good outcome.
BTW, I mentioned Diverse Devices because the proprietor is a regular contributor at the sci.electronics.repair newsgroup which I watch on a regular basis.
PostPosted: February 10th, 2011, 8:47
I thought I would post an update... :(
I got the drive today installed the PCB and plugged in the power but alas though it powers up.
I do not hear the drive working so like I said in my previous post it's the end of the road for me... :(
Put it down to experience and walk away... :cry: :(
PostPosted: February 10th, 2011, 13:31
you do not hear drive working ? As in no spin or heads not moving ?
PostPosted: February 10th, 2011, 14:44
Assuming that the head preamp is still working and the damage is limited to the PCB, the odds are high that a professional data recovery firm could still recover your data without it costing an arm and a leg. But, you have to be up front about what was done and perhaps ease the tension by offering to cover the cost of the donor drive, is such a purchase is needed.
PostPosted: February 18th, 2011, 6:45
Dear Sir.
I also went to same experience as you , i plugged my laptop power cord 19v and the 750 Westerndigital is not working .
I am going to do same thing as you try to find out if the diode is burnt and then replace.
Thank you for the information.
Regards.
Vinay Navinchandra
PostPosted: February 18th, 2011, 6:50
Dear Sir.
Yesterday i did same mistake putting power cord of my laptop 19v and western figital is not working any more.
I will do same as you try to find out the broked diode and replace, onle chance.
Regards.
Vinay
PostPosted: August 25th, 2014, 2:57
hi, i got 1tb wd cavier green ears....its not detected by my comp...so when check in internet..maybe fault of board..so i took out d4 diode....but what happen is...hardisk start to give clicking noise.....still no detected by comp..any suggestion
PostPosted: August 25th, 2014, 6:27
Probable bad heads o FW problem or media problems. but not sure
con you show us picd from your drive, stiker and pcb from both sides.?
