Re: Seagate ST9320423ASG 0LBA problem
September 18th, 2011, 11:30
OK guys, I am giving up...
Thanks for all of you for your suggestions and your help!
Here, my last attempts to find a solution:
I tried to regenerate translator using AltList: m0,6,3,,,,,22 ----> "format successful" but 0LBA remains unchanged.
I started m0,6,4,,,,,22 to recover factory defect lists from factory selfscan logs; just after the start I get (not regular, but over and over) the same responce "LED:000000EE FAddr: 002829F8" Obviously a function with address 002829F8 returns general error "not successful." The last command m0,6,4,,,,,22 is running during the last 27 hours, should I breake this last run? or I am going a risk here to get irreparable damage of data?
Dear gurus who is familiar with this sort of problems and can take over?
Please PM me a short message.
Thanks in advance!
September 28th, 2011, 7:20
Many thanks to pcimage!
He solved this problem very fast and professional.
Thanks to all who was involved in this discussion.
September 28th, 2011, 16:15
Not quite as straight forward as I'd imagined, but got it sorted!
September 29th, 2011, 2:58
Good job pcimage :)
January 17th, 2012, 13:16
northwind wrote:Good job pcimage :)
So what did PCImage do in his PM that was different than your approach and solved your 7200.11 problem :? sector0,
Please advise..
Thanks!
Doug
January 17th, 2012, 18:19
I didn't do anything by PM, the drive was sent into our lab and I did it there :-)
January 17th, 2012, 18:28
Understood ... Good WORK I'd Say !
Thanks for the rapid response...
Doug
