November 5th, 2012, 18:43
pcimage wrote:tamaro wrote:pcimage wrote:Unlikely to be PCB.
Why do you think that?
Because it is spinning.
well is on its way to DonorDrives we will see what they come up with.
November 5th, 2012, 19:06
I wish you all the best of luck.
Cheers
November 5th, 2012, 21:36
Do these drives still spin up if either of the USB Data+ or Data- pins are broken?
November 6th, 2012, 5:29
fzabkar wrote:pcimage wrote:tamaro wrote:pcimage wrote:Unlikely to be PCB.
Yes, it would.
But this is very rare and why I said "unlikely" rather than "definitely not"
Assuming the OP accepts the risks of DIY, then its easily checked by checking the continuity of those two middle pins from mini USB connection to the track on the PCB. If a dry joint/suspect connection is found then it is easily fixable with a good iron.
What is much more likely that bad sectors are preventing the Smartware initialising, or a firmware issue.
In literally 100's of these cases I can only recall one that the problem what you mentioned.
November 7th, 2012, 10:23
mm.. he said that the drive does not spin.. so it could be the pcb..
Despite that, with my experience for this kind of hard disk the diagnosis is Head Gone
November 7th, 2012, 15:18
recupero-dati wrote:mm.. he said that the drive does not spin..
There are two posters with problems ...
November 7th, 2012, 16:21
fzabkar wrote:recupero-dati wrote:mm.. he said that the drive does not spin..
Yes, you are right.
One says his drive does not spin (could be PCB) and one says it does spin (unlikely PCB)
Hence the confusion and conflicts of diagnosis.
This is what happen who people hijack other people's threads
