July 19th, 2012, 11:06
michael chiklis wrote:Where can i find this "R-Studio Emergency boot cd" ?
Does it work in DOS or in linux?
July 19th, 2012, 14:00
July 20th, 2012, 4:33
HDData wrote:It's not a big problem with your hard drive, I can help you with this for a small fee
Decompression... Parsing ELF... Done
Starting the kernelJuly 20th, 2012, 10:03
michael chiklis wrote:I downloaded DMDE, but it works on windows.
I can't and i don't want to load this faulty device in windows, so i need the DOS version.
How can i boot DMDE in DOS with CD-Rom or USB ?
July 20th, 2012, 10:12
laptokowiec wrote:michael chiklis wrote:I downloaded DMDE, but it works on windows.
There is DOS version of DMDE.
http://softdm.com/download.htmlJuly 20th, 2012, 11:01
michael chiklis wrote:HDData wrote:It's not a big problem with your hard drive, I can help you with this for a small fee
How?
Should i ship you the drive?
Are you in USA?
For Dick & Loki:
I tried R-Studio Emergency boot cd but it hangs with this script:
- Code:
Starting the kernel
I tried all the boot CD downloaded from "Service Utilities for Local Recovery" section, but is always the same.
I really don't know where is the problem, can you help me please?
July 20th, 2012, 12:07
July 20th, 2012, 12:58
michael chiklis wrote:Finally i was able to boot DMDE in DOS with my USB key drive.
Unfurtunally also DMDE is very slow to copy the faulty drive, as all other DOS clone programs.
The only DOS program which is fast to read the drive is MHDD, but it's impossible to use it for clone purpose.
Am i right? Or there is a way to clone with mhdd?
I hope there is a way to clone with mhdd, because it's the only one makes me hope
July 20th, 2012, 17:29
July 20th, 2012, 17:52
July 20th, 2012, 18:26
labtech wrote:michael chiklis wrote:Finally i was able to boot DMDE in DOS with my USB key drive.
Read the MHDD manual.
MHDD is not a cloning tool, but rather a diagnostic tool, which if used, it will help get an idea what the issue is. Based on that and the feedback you would provide here (if you want to provide it), then we can recommend whether a cloning process is feasible.
Best wishes
July 21st, 2012, 2:33
July 21st, 2012, 5:31
July 21st, 2012, 9:23
July 21st, 2012, 11:12
michael chiklis wrote:UPdate:
i was trying again to clone with RecoverSoft Media Tools Professional 5.0 in DOS, when I realized that if I interrupt the cloning process and then resume after 2 or 3 seconds, the cloning process speeds up until 4.000 sectors about, then it slows again.
Then i interrupt again for 2 or 3 seconds and copys again other 4.000 LBA in very fast speed.
If only I could automate the process of cloning interruption and re-engage every 4.000 LBA, I could copy the disc in a few days.
Do you know a software to do such a thing?
Need a software that clones in DOS interrupting the process of cloning every 4000 sectors copied, and then resume the process after 2 or 3 seconds.
July 21st, 2012, 13:36
July 21st, 2012, 19:48
July 22nd, 2012, 5:38
July 22nd, 2012, 15:44
July 29th, 2012, 7:25
SAjunky wrote:Only on some models such option is available. After selecting disk, go to ATA commands/features set. Very close on the SMART disable option (it could be menu up and one down).
1. Device Configuration Overlay (DCO) Menu
- Show Identify or Modify: missing Multiword DMA (maybe it is correct)
- Check DCO structure: failed integrity
- in Dump DCO Data last two bytes (1FEh/1FFh) are zero
- it seems that DCO module (in firmware) is corrupted
2. SMART menu - Read Log Menu
- Self-Test Log (06h) or Extended Self-Test Log (07h): failing LBA = 432945
- this is the first LBA sector with error
- Summary Error Log (01h): error count = 355
- Read Attribute Data: Seek Error Rate
From internet:
Attribute values are supposed to have a "normal" value of 100 or 200
A SMART threshold of 0 indicates that the attributes health range is not
limited (since attribute values range from 1 to 253, 0 can never be reached)
what is (or should be) most commonly the case with parameters that reflect
the performance rather than the health of the hard disk drive
(so called "performance attributes").
Seek Error Rate = Rate of seek errors of the magnetic heads.
If there is a partial failure in the mechanical positioning system, then seek
errors will arise. Such a failure may be due to numerous factors, such as
damage to a servo, or thermal widening of the hard disk.
The raw value of Seek Error Rate is vendor specific.
Your disk has threshold=0, value=1, worst=1.
I think that the disk has a problem with the mechanical positioning system
(heads) and therefore is so slow.
Bad news is you can not fix it by yourself, you really need a profi help.Powered by phpBB © phpBB Group.
