August 2nd, 2012, 11:12
August 2nd, 2012, 12:33
August 2nd, 2012, 13:42
August 3rd, 2012, 2:53
August 3rd, 2012, 7:45
August 3rd, 2012, 15:01
August 4th, 2012, 5:36
SAjunky wrote:I advice to not use diode testing range. Besides you have just finished testing.
I wrote it already. Didn't I? Cut this diode.
August 5th, 2012, 6:04
August 5th, 2012, 7:07
Joeri. wrote:My flush cutter ended up being either not strong enough or I just didnt dare using enough pressure because I am still afraid of slipping and scratching the pcb.
SAjunky wrote:Cut this diode.
August 5th, 2012, 15:06
Vulcan wrote:@Joeri.Joeri. wrote:My flush cutter ended up being either not strong enough or I just didnt dare using enough pressure because I am still afraid of slipping and scratching the pcb.
I don't want to get involved in your ongoing conversation with SAjunky, but when he said:SAjunky wrote:Cut this diode.
... you do realise that he did not mean to cut the black epoxy body of the diode itself, don't you? If you were trying to do that then, of course, normal flush cutters won't succeed (they're not designed for cutting through epoxy) and the risks of the cutters slipping and damaging the PCB (or your fingers!) are high (as well as you damaging the cutting edges of the tool itself). See the earlier postings in this thread for more details from SAjunky about where to cut.
I am not telling you what to do - you're already getting advice. I'm just concerned that some mis-communication between you & SAjunky is potentially going to result in you trying to really cut the diode itself, and cause even more problems if the cutters slip. That is all
August 5th, 2012, 16:06
Joeri. wrote:No worries, I didnt try to do that.
Joeri. wrote:Thanks for the heads up though.
August 6th, 2012, 14:38
August 6th, 2012, 15:27
August 6th, 2012, 17:15
