Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: HD Recovery When to Give Up
PostPosted: November 30th, 2012, 5:13
Cleanroom wrote:
I wanted to give some conclusion to this discussion. I received this drive from the client yesterday and here is what i figured out about the drive. She gave me authorization to post about it
It had been to three different places before i saw it. Local IT company, Ontrack, and Drivesavers
The first place is the place i believe caused the drive to be unrecoverable, since i would like to think that Ontrack and Drivesavers would not do such awful job with this.
Company one is a local IT company near the client.
1. Top label was completely peeled off. It was a Seagate drive, but model number and p/n was unknown at this point.
2. 1tb drive, standard laptop size, 2 platters
3. Drive was missing Screw that held the heads in underneath.
4. Once the drive was opened, i noticed that the reading heads were mangled, but the way they were mangled was not done by the drive on failure. More likely they did not care when they put them back in.
5. Dust particles on the platters
6. Platter screw that holds the platters in place was loose, and a little stripped, the platters were not secured in, and moving independently.
7. There was a Sharpie mark on the edges of the two platters to most likely keep them in alignment when they were removed. They are were not even aligned with each other at this point. Sharpie marks not lined up.
I am assuming that drivesaver and Ontrack came up with the same conclusion and realized that since the platters were removed in non-aligned way they deemed it unrecoverable. it was not even put back together correctly to keep the platters from moving.
:shock: :shock: :shock: :shock: :shock:
Wow, and I thought I've seen it all...
PostPosted: November 30th, 2012, 10:46
Thanks for the update, Northwind. This just fry’s me. I cannot imagine such incompetency: opening a drive under clearly unprofessional circumstances, let alone moving platters-using a visual index!!! This company clearly overstepped there level and destroyed the ability to recover the drive. Had it gone to you in the first place, or likely the other two companies, the outcome would positivly be different.
PostPosted: November 30th, 2012, 14:29
a few things:
I read here that the larger companies who receive a large amount of drives choose the drives that are the easiest to recover because they obviously make more money and don't want to spend valuable time on a drive for weeks or money swapping heads.
Could not be further from the truth. Its usually the other way around - Drives go to cheaper local places first and they skim off the easy stuff.
My guess is that there was media damage in a critical area. Platters can be re-aligned easily enough - so that would not be the problem.
PostPosted: November 30th, 2012, 16:09
Keatah wrote:
Sometimes a corrupt jpeg is the result of an "improperly formatted" or "mis-placed" pixel - to use layman's terms. Oftentimes one has to repair just 1 single pixel and the rest of the image magically appears.
This is not how JPGs work.
Users browsing this forum: Google [Bot] and 66 guests
