May 7th, 2013, 16:06
Recently had a case with Relo mod checked good, but still get translation issues. I think I wrote another good relo mod from another drive of the same fw ver and then then the data was accessible and drive ran decently.
But careful how you play with this! Your data, your choice.
May 8th, 2013, 3:54
If relo has any data other than header, clear it and recalc checksum.
May 8th, 2013, 5:35
Spildit, you're looking are looking at the exception flags table. There's nothing wrong with the file.
- Code:
File Loaded
ReloList parser activated
file_version : 00170000
No. of Rsvd Cylinders .................... : 0
# of Hash Elements ....................... : 195
Max Linear Elements ...................... : 1465
Offset to Hash Table ..................... : 0xA4
Offset to Linear Table ................... : 0x230
Offset to Exception Flags Table .......... : 0x1AE4
Offset to Write Uncorrectable Flags Table : 0x2114
Offset to Future Flags Table ............. : 0x2744
Offset to Rehab Table .................... : 0x33A0
First Spare ABA .......................... : 0x162F14B5
First Spare LBA .......................... : 0xAEFE6D10
Last Spare LBA ............................: 0xC27632AF
Starting Spare Phy Cyl ................... : 0x37FF9
Starting Spare Phy Hd .................... : 1
RELOs Remaining .......................... : 1437 (0x59D)
Spare Sectors Left ....................... : 40827060 (0x26ef8b4)
No. of ExceptionList Entries ............. : 768
No. of Relos ............................. : 28
No. of Total Tares........................ : 2
No. of Total FTares....................... : 0
No. of Pure Tares......................... : 2
No. of Pure FTares........................ : 0
No. of Pseudo Write Uncorrectables ....... : 0
No. of Flagged Write Uncorrectables .......: 0
No. of Write Uncorrectable read err ...... : 0
May 8th, 2013, 12:15
hddguy wrote:If relo has any data other than header, clear it and recalc checksum.
Is this something that can be done with WDR Demo?
WDR is the only tool I have for service-area manipulation.
June 5th, 2013, 9:49
fzabkar wrote:FWIW, MODs 20h and 21h are showing that the SMART Command Timeout attribute has hit its threshold. That's one of the hidden attributes that isn't reported to the user.
- Code:
ID Typ Cur Worst Raw Description
1 2F 200 200 00000000000000 Read Error Rate
3 27 253 253 000000000003F8 Spin-Up Time
4 32 97 97 00000000000F6B Start/Stop Count
5 33 200 200 00000000000000 Reallocated Sector Count
7 2E 191 191 00000000000355 Seek Error Rate
9 32 97 97 0000000000096F Power-On Hours
A 32 100 100 00000000000000 Spin Retry Count
B 32 100 100 00000000000000 Calibration Retry Count
C 32 97 97 00000000000F69 Power Cycle Count
B8 B2 H 100 100 00000000000000 End-to-End Error
BB B2 H 100 100 00000000000000 Reported Uncorrectable Errors
BC B2 H 1 1 0000DF00E10151 Command Timeout
BE A2 H 68 52 00000000000020 Airflow Temperature
C0 32 200 200 000000000000A0 Power-off Retract Count
C1 32 197 197 0000000000266E Load/Unload Cycle Count
C2 22 118 102 00000000000020 Temperature
C3 B6 H 100 253 00000000000000 Hardware ECC Recovered
C4 32 200 200 00000000000000 Reallocation Event Count
C5 32 200 200 00000000000002 Current Pending Sector Count
C6 30 200 200 00000000000002 Offline Uncorrectable
C7 32 200 200 00000000000000 UltraDMA CRC Error Count
C8 8 200 200 00000000000003 Write Error Rate
F0 B2 H 99 99 00000000000371 Head Flying Hours
F1 B2 H 200 200 000000102A61AA Total LBAs Written
F2 B2 H 200 200 0000000BAD411D Total LBAs Read
the mod 0x20 seems to be a copy of mod 21. it doesn't show in directory table - mod 01. basically it's
invisible.
fzabkar how did (with what) you gen the table from the mod 21? I found the smart table sector inside..but I need a method to get it right.
June 5th, 2013, 11:04
k, I found myself the jumpin' pointer to the table..inside that file...I need to do the same also for the threshold table.
March 27th, 2014, 9:31
Hello everyone!
I need some help.
I have a patient WD20EARX-00MMMB0) drive with damaged system area. The heads are okay, because i swapped in clean room yesterday from a working donor (WD30EZRX-00MMMB0). My Atola Insight unit could not identify the drive. With WD Repair Tool 5.3 i can read the rom and the head map, but when i want to read the firmware rom files , the appearing window is empty. When i start the drive it spins up, clicks 5 times, and spins down, and the wdr tool identifies it:WDC ROM MODEL-DRAGON- FW:20.5QP SN:WDC-ROM SN# XYZ
Question: How can i access to the system area, and fix firmware related problems?
I really need help, because i have 3 patient WD drives with good heads and system area corruptions.
March 27th, 2014, 16:59
saltwater wrote:Hello everyone!
If you can't read the SA..then the heads are not good. The model number must be identical unless you know for sure that WD30EZRX heads work on WD20EARX. Basically after a head swap if heads are fine you should be able to read the SA. Those 5 clicks means that the firmware can-t read the heads...find servo information etc. even with a blank SA the drive with good heads should start fine..with no clicks.
March 27th, 2014, 22:22
DCM matters on these . . .
March 28th, 2014, 3:27
jono-ats wrote:DCM matters on these . . .
Yes it seems to, well at least one digit of it
March 28th, 2014, 4:10
Okay, these two drives DCM codes are:
WD30EZRX-00MMMB0 DCM:HBNCHT2ABB 08 SEP 2012
WD20EARX-00MMMB0 DCM:HARCHT2AAB 27 JUL 2012
The drives has the same head map, everything looks like same under the hood, except the PCB
But another patient drive (WD10EADS-00M2B0) could read the firmware rom files 0001.rpm, 00c0.rpm and the 0031.rpm. It does not identified by Atola, and i can't write the firmware files with WDR, can't format SA, can't write anything.
One more drive (WD5000AADS-00S9B0) is stays bsy when the PCB is attached, but when detached from the hdd, its puts itself ready state after a minute.
So what is the first thing i have to do with WDR to start the heads to read from the SA?
March 28th, 2014, 11:07
If the donor heads are good you have nothing to do to read the SA. the module map (which holds the information where the other modules are written) it's the mod 01 which it's located at reserved LBA 0 in SA. in wdr do a head test to see if it can read the SA. if it gives you errors ..then you have an incompatible/bad donor head stack.
sometime you have to fine tune the MRJOG values after a head swap for head 0 and 1 (wdr has a small window to help you do that), to access the SA. the data modified it's located in PCB's flash..so it doesn't need any SA write.
March 28th, 2014, 12:18
saltwater wrote:Okay, these two drives DCM codes are:
Is that so, that WDR is MOSTLY Not compatible with most PCBs???????
May i suggest a POLL on how most users rate WDR!!!!!!!!!!!!!!
March 29th, 2014, 7:30
longlife wrote:saltwater wrote:Okay, these two drives DCM codes are:
and
March 29th, 2014, 14:41
Now with donor hot swap, i can access to the system area. Witch are the most important mod's that has to be good for the system could identify the hdd?
And witch mods i have to finetune for access the data?
I need real answers please.
March 29th, 2014, 16:05
saltwater wrote:Witch are the most important mod's that has to be good for the system could identify the hdd?
don't expect answers. firmware modifies with each version. who knows what mods are required for your drive!? get a good drive, and start deleting mods to see which are really necessary. if you start reading around you will find some important mods...like mod 11 which it's a part of SA firmware..and some other mods containing tables used by firmware..like translators for SA or user area...smart mods which stores tables with drive live params etc.
saltwater wrote:And witch mods i have to finetune for access the data?
basically adaptive mods..one it's for SA and it's in ROM..and the others are on SA holding tables with data for each head in each zone of he platters.
May 19th, 2014, 14:27
If your hdd give you access to module and showing model and serial number OK, then problem occur due to following reasons,
1. Any defect list damaged like 31, 32, 33, 34, 36
2. one of the head not able to read or write
3. drive is encrypted by modification in 0b and 02 modules.
Waqas Ali
www.sediv.net
May 21st, 2014, 6:35
Hello again!
Back to the sick WD20EARX-00MMMB0 drive. After the head swap it clicks 3 times and spins down (micro jogs are compatible). When i would like to read the rom contents, the drive spins up (strange i think), clicks 3 times, and spins down. All modules readed from the rom except the 0001. The error code is 5441 (SERVO_ERROR_CODE_BASE_SvirActSync)
Could somebody help me, and upload a WD20EARX-00MMMB0 firmware modules with rom modules?
Thank you!
Best wishes for all....
May 21st, 2014, 7:41
saltwater wrote:Hello again!
mod 1 it's the directory module...and it's on SA. try to use the rom adaptives from the donor's pcb. if it doesn't work, then there's a problem with the HSA.
May 21st, 2014, 17:52
saltwater wrote:When i would like to read the rom contents, the drive spins up (strange i think), clicks 3 times, and spins down. All modules readed from the rom except the 0001. The error code is 5441 (SERVO_ERROR_CODE_BASE_SvirActSync)
If you examine ROM MOD 0B or MOD 20B, you will find an entry for MOD 01. Since this module is located in the SA rather than ROM (as has been explained by louis), then I would think that this explains why the drive spins up.
