Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Intermittent hum on WD 1TB drive
PostPosted: July 9th, 2013, 14:10
Could not edit successfully the previous message to add some more lines.
Clarification :
When drive is idle / off heads are parked on the ramp and in that condition the drive can withstand also much higher shock : the spindle can stuck but there's nothing on surface that can harm. Heads do leave the ramp only when the pack has reached target speed !
In this case heads ARE actually touching the surface and are "stuck" to the surface (that is coated etc. etc.) : take two glass sheets, apply some water and stick them together, then notice how much force you have to apply to "detach" them - unless you make them glide one on each other !
In this condition, every relative movement of heads ONTO the platters can be a problem, as the headstack is not held into place (the right place !) by top lid, action of air bearing during spinning and other factors. This is what I want to mean.
There are many WD drives where headstacks are fitted in a manner that if you unscrew the top cover, it is a very difficult task to re-align it correctly (microns DO matter) , go figure... (still don't get why do they engineered them that way , but there must be a reason for it).
The only thing that mitigates the problem is the fact that platters are coated with a "lubricating" layer - it can cause stiction but also protects....
Just my opinion, any other opinion or correction from other SENIOR DR EXPERTS is always welcome...
PostPosted: July 17th, 2013, 11:47
Update:
Data Savers says the drive is unrecoverable.
Anyone have any recommendations for some data recovery software to try to use on the laptop drive that had a lot of the original data before it was moved to the external drive that is now dead?
PostPosted: July 18th, 2013, 3:04
I'd go for raw recovery at this point.
Use R-Studio to see what it can recover.
I'm sorry for your drive.
PostPosted: July 18th, 2013, 3:54
That sucks. check pm
Users browsing this forum: Google [Bot] and 203 guests
