Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Seagate ST31000520AS F/WCC32
PostPosted: December 4th, 2013, 22:40
Okay, I will read all the tutorial and related info on what the tutorial is about, then next week, probably tuesday I will be able to continue working on the drive. I will have random minutes free until then unfortunately, as I would really like to dig into this and learn something!
PostPosted: December 6th, 2013, 0:25
I managed to find some time today.
I am including a putty log of trying the commands that are in your posts. Very interesting, so much info!
after that I ran V4 and it scrolled for a LONG time. Thats not good is it?
After a reset I got:
st 0x20M
(P) SATA Reset
(S) SATA Reset
ASCII Online mode
Starting LBA of RW Request=0060006F  Length=FFFFFFFF
ProcessRWError -Read-   at LBA 0060006F  Sense Code=43110081
InitiateMarkPendingReallocateRequest for disc_lba: 0060006F
FAILED to spare!
(S) SATA Reset
(S) SATA Reset
Does any of that make any sense as to whats wrong?
putty.txt [15.22 KiB]
Downloaded 678 times
PostPosted: December 7th, 2013, 22:05
This did not help. It does stop windows trying to access the disk though.
What would be the terminal commands I should run that would display the most informative information to you?
The msgBox from windows say "The parameter is incorrect" when trying to access the drive. Probably a windows generic message for "this disk is dodgy"
PostPosted: December 8th, 2013, 6:38
What?
Do you really expect to get your data by simple loading the drive in windows after some magic commands?
You have still more work to do to get your data...
You have to clone the drive sectors by sectors on a new drive, possibly with some hardware tool as Deepspar or DE, admitted that there aren't more issues as translator, heads, etc
My firmware database:
PostPosted: December 8th, 2013, 7:41
michael chiklis wrote:
What?
Hi Michael, no I don't. I was asking what terminal commands might give the information that might lead to a diagnosis of a problem. I don't recall executing any windows commands yet. I know there are terminal commands that can be run to list out variables/parameters/status of the drive, what I am asking is if any of these are helpful in determining whats wrong with it.
Obviously I don't have a Deepspar or DE, otherwise I would likely not be here asking what pros would consider stupid questions.
I am hoping, with some guidance, I might be able to diagnose if the drive is fixable DIY, or needs a Pro. I think we know a Pro would likely fix it, and if it requires a pro, that's fine. But it hasn't been determined yet.
As it may help others, can you please specify which information I provided that led to this diagnosis?
Thanks for your input, I appreciate all comments.
PostPosted: December 9th, 2013, 22:55
Drive did not detect in MHDD. It does show up in the list for boot devices when booting the computer.
here is F3 T>F
is the linked tute still valid for this drive?
F3 T>F
           RWErrorRecovery Mode Page
              RWErrorRecovery Group
Byte:00A2:       RWRecoveryFlags = C0
Byte:00A2:           Bit:0, DISABLE_CORRECTION = 0
Byte:00A2:           Bit:1, DISABLE_TRANSFER_ON_ERROR = 0
Byte:00A2:           Bit:2, POST_ERROR = 0
Byte:00A2:           Bit:3, ENABLE_EARLY_RECOVERY = 0
Byte:00A2:           Bit:4, READ_CONTINUOUS = 0
Byte:00A2:           Bit:5, TRANSFER_BLOCK = 0
Byte:00A2:           Bit:6, READ_SPARING_ENABLED = 1
Byte:00A2:           Bit:7, WRITE_SPARING_ENABLED = 1
Byte:00A3:       ReadRetries = 10
Byte:00A4:       CorrectionSpan = FF
Byte:00A5:       HeadOffset = 00
Byte:00A6:       DataStrobeOffset = 00
Byte:00A8:       WriteRetries = 05
Byte:00AA:       RecoveryLimitMSB = FF
Byte:00AB:       RecoveryLimitLSB = FF
           FormatParameters Mode Page
              FormatParameters Group
Byte:00AE:       TracksPerZoneMSB = 00
Byte:00AF:       TracksPerZoneLSB = 01
Byte:00B0:       AltSectorsPerZoneMSB = 00
Byte:00B1:       AltSectorsPerZoneLSB = 00
Byte:00B2:       AltTracksPerZoneMSB = 00
Byte:00B3:       AltTracksPerZoneLSB = 00
Byte:00B4:       AltTracksPerVolumeMSB = 00
Byte:00B5:       AltTracksPerVolumeLSB = 02
Byte:00B6:       SectorsPerTrackMSB = 00
Byte:00B7:       SectorsPerTrackLSB = 03
Byte:00B8:       BytesPerSectorMSB = 02
Byte:00B9:       BytesPerSectorLSB = 00
Byte:00BA:       InterleaveMSB = 00
Byte:00BB:       InterleaveLSB = 01
Byte:00BC:       TrackSkewMSB = 00
Byte:00BD:       TrackSkewLSB = 00
Byte:00BE:       CylinderSkewMSB = 00
Byte:00BF:       CylinderSkewLSB = 00
Byte:00C0:       FormatFlags = 40
           DriveGeometry Mode Page
              DriveGeometry Group
Byte:00C6:       CylindersMSB = 00
Byte:00C7:       CylindersMDB = 00
Byte:00C8:       CylindersLSB = 04
Byte:00C9:       Heads = 04
Byte:00CA:       WritePrecompMSB = 00
Byte:00CB:       WritePrecompMDB = 00
Byte:00CC:       WritePrecompLSB = 00
Byte:00CD:       ReducedCurrentMSB = 00
Byte:00CE:       ReducedCurrentMDB = 00
Byte:00CF:       ReducedCurrentLSB = 00
Byte:00D0:       StepRateMSB = 00
Byte:00D1:       StepRateLSB = 00
Byte:00D2:       LandingZoneMSB = 00
Byte:00D3:       LandingZoneMDB = 00
Byte:00D4:       LandingZoneLSB = 00
Byte:00D5:       PositionLocking = 00
Byte:00D6:       RotationalOffset = 00
Byte:00D8:       RotationRateMSB = 17
Byte:00D9:       RotationRateLSB = 0C
           VerifyError Mode Page
              VerifyError Group
Byte:00DE:       VerifyRecoveryFlags = 00
Byte:00DE:           Bit:0, VE_DISABLE_CORRECTION = 0
Byte:00DE:           Bit:1, VE_DISABLE_TRANSFER_ON_ERROR = 0
Byte:00DE:           Bit:2, VE_POST_ERROR = 0
Byte:00DE:           Bit:3, VE_ENABLE_EARLY_RECOVERY = 0
Byte:00DF:       VerifyRetryCount = 10
Byte:00E0:       VerifyCorrectionSpan = FF
Byte:00E6:       VerifyTimeLimitMSB = FF
Byte:00E7:       VerifyTimeLimitLSB = FF
           CacheControl Mode Page
              CacheControl Group
Byte:00EA:       CacheFlags = 14
Byte:00EA:           Bit:0, READ_CACHING_DISABLED_ON_POWER_UP = 0
Byte:00EA:           Bit:1, MULTIPLICATION_FACTOR = 0
Byte:00EA:           Bit:2, WRITE_CACHING_ENABLED_ON_POWER_UP = 1
Byte:00EA:           Bit:4, DISCONTINUITY = 1
Byte:00EA:           Bit:5, CACHING_ANALYSIS_PERMITTED = 0
Byte:00EA:           Bit:6, ABORT_PREFETCH = 0
Byte:00EA:           Bit:7, DISABLE_ADAPTIVE_READ_AHEAD = 0
Byte:00EB:       RetentionPriority = 00
Byte:00EC:       DisablePrefetchLengthMSB = FF
Byte:00ED:       DisablePrefetchLengthLSB = FF
Byte:00EE:       MinPrefetchMSB = 00
Byte:00EF:       MinPrefetchLSB = 00
Byte:00F0:       MaxPrefetchMSB = FF
Byte:00F1:       MaxPrefetchLSB = FF
Byte:00F2:       MaxPrefetchCeilingMSB = FF
Byte:00F3:       MaxPrefetchCeilingLSB = FF
Byte:00F4:       SpecialCacheFlags = 80
Byte:00F4:           Bit:5, READ_LOOKAHEAD_DISABLED_ON_POWER_UP = 0
Byte:00F4:           Bit:7, FORCE_SEQUENTIAL_WRITE = 1
Byte:00F5:       CacheSegmentNum = 20
Byte:00F6:       CacheSegSizeMSB = 00
Byte:00F7:       CacheSegSizeLSB = 00
Byte:00F9:       NonCacheSegSizeMSB = 00
Byte:00FA:       NonCacheSegSizeMDB = 00
Byte:00FB:       NonCacheSegSizeLSB = 00
           ControlMode Mode Page
              ControlMode Group
Byte:00FE:       LogFlags = 02
Byte:00FF:       QueueFlags = 00
Byte:0100:       AllegianceFlags = 00
Byte:0102:       RAERHoldOffMSB = 00
Byte:0103:       RAERHoldOffLSB = 00
Byte:0104:       BusyTimeoutMSB = 00
Byte:0105:       BusyTimeoutLSB = 00
Byte:0106:       ExtendedDstestTimeMSB = 00
Byte:0107:       ExtendedDstestTimeLSB = 00
           PowerCondition Mode Page
              PowerCondition Group
Byte:010B:       PowerFlags = 02
Byte:010B:           Bit:0, STANDBY = 0
Byte:010B:           Bit:1, IDLE = 1
Byte:010C:       IdleTimerMSB = 00
Byte:010D:       IdleTimerNMSB = 00
Byte:010E:       IdleTimerNLSB = 00
Byte:010F:       IdleTimerLSB = 05
Byte:0110:       StandbyTimerMSB = 00
Byte:0111:       StandbyTimerNMSB = 00
Byte:0112:       StandbyTimerNLSB = 00
Byte:0113:       StandbyTimerLSB = 04
           BackgroundMediaScan Mode Page
              BGMS Group
Byte:0117:       BGMSBusIdleIn100ms = 05
Byte:0118:       OtherScanFlags = 00
Byte:0118:           Bit:0, IRAW_ENABLE = 0
Byte:0118:           Bit:1, IRAW_DISABLE_REASSIGNMENTS = 0
Byte:0119:       IRAWWriteCachePercentage = 00
Byte:011A:       IRAWDelayInMilliSecs = 00
Byte:011B:       IRAWMaxQDepth = 00
Byte:011C:       BGMSFlags = 00
Byte:011C:           Bit:1, BGMS_DISABLE_DATA_REFRESH = 0
Byte:011C:           Bit:2, BGMS_DISABLE_TEMPERATURE_LIMITATION = 0
Byte:011D:       BGMSECCTLevel = 0A
Byte:0124:       ReadAfterWriteControl = 31
Byte:0124:           Bit:0, MP_RAW_ENABLE_BIT = 1
Byte:0124:           Bit:1, MP_RAW_TRIP_1ST_N_WRITES = 0
Byte:0124:           Bit:2, MP_RAW_FORCE_RAW_MODE = 0
Byte:0124:           Bit:3, MP_RAW_UDS_DEBUG_MODE = 0
Byte:0124:           Bit:4, MP_RAW_DISABLE_AR_ON_GOOD_READ = 1
Byte:0124:           Bit:5, MP_RAW_DISABLE_SOFT_AR = 1
Byte:0124:           Bit:6, MP_RAW_DISABLE_SERIAL_DEBUG_MSG = 0
Byte:0125:       NWritesAfterSWDFail = 08
Byte:0126:       NWritesAfterRAWFail = 08
Byte:0127:       NWritesAfterIRAWFail = 08
Byte:0128:       N1stWrites = 00
Byte:0129:       RAWOnColdThreshold = 05
Byte:012A:       RAWOnHotThreshold = 44
Byte:012B:       RAWATAMode = 02
Byte:012C:       RAWVerifyNSectors = 00 00 00 00
Byte:0130:       RAWVerifyNSectorsATAMode3 = 00 00
Byte:0132:       NWritesAfterSWDSumFail = 08
Byte:0134:       SWDControl = 03
Byte:0134:           Bit:0, MP_SWD_ENABLE_BIT = 1
Byte:0134:           Bit:1, MP_SWD_DONT_REPORT_BIT = 1
Byte:0134:           Bit:2, MP_SWD_DEBUG_MODE_BIT = 0
Byte:0135:       SWDDvgasEventsBeforeFail = 08
Byte:0136:       SWDRvgasEventsBeforeFail = 08
Byte:0137:       SWDFvgasEventsBeforeFail = 08
Byte:0138:       SWDSumOfEventsBeforeFail = 08
Byte:013C:       DOSOughtToScanThreshold = 02
Byte:013D:       DOSNeedToScanThreshold = 04
Byte:013E:       DOSNeedToGraceMilliseconds = 00 14
Byte:0140:       DOSNeedToRegraceMilliseconds = 00 14
Byte:0142:       DOSNeedToMinimumScanMilliseconds = 00 64
Byte:0144:       RAWOnForNPowerCycles = 00 00
Byte:0146:       RAWOnForNHours = 00 00
Byte:0148:       RAWOnForNSpinups = 00 00
           UnifiedDebugGeneral Mode Page
              UDSGeneral Group
Byte:014E:       Revision = 00
Byte:014F:       GlobalTraceTriggerFlags = 70
Byte:014F:           Bit:3, UDS_GEN_SVIN_BIT = 0
Byte:014F:           Bit:4, UDS_GEN_SVEN_BIT = 1
Byte:014F:           Bit:5, UDS_GEN_GTGE_BIT = 1
Byte:014F:           Bit:6, UDS_GEN_TREN_BIT = 1
Byte:014F:           Bit:7, UDS_GEN_TGTD_BIT = 0
Byte:0150:       MethodParameterFlags = 00
Byte:0150:           Bit:7, UDS_CLR = 0
Byte:0154:       DetailedExternalTriggerFlags = 00
Byte:0156:       ErrorTypeMSB = 00
Byte:0157:       ErrorTypeLSB = 00
Byte:0158:       ErrorLBABigEndian = 00 00 00 00 00 00 00 00
Byte:0164:       AutomaticTraceSaveFlags = 80
Byte:0164:           Bit:5, UDS_GEN_INTR_BIT = 0
Byte:0164:           Bit:6, UDS_GEN_DTFS_BIT = 0
Byte:0164:           Bit:7, UDS_GEN_TSEN_BIT = 1
Byte:0166:       MSBAutomaticTraceSaveIntervalInMinutes = 00
Byte:0167:       LSBAutomaticTraceSaveIntervalInMinutes = 78
Byte:0168:       MSBMinimumIdleTimeBeforeAutoTraceSaveInMilliseconds = 00
Byte:0169:       LSBMinimumIdleTimeBeforeAutoTraceSaveInMilliseconds = C8
Byte:016A:       TimestampFormatIdentifierMSB = 00
Byte:016B:       TimestampFormatIdentifierLSB = 00
Byte:016C:       CustomerSystemTimeInCustUniqueFormat = 00 00 00 00 00 00 00 00
           DriveNativeInfo Mode Page
              DriveNativeInfo Group
Byte:018E:       PartNumber = 30 32 37 4A 4A 30 44 54 58
                 '027JJ0DTX'
Byte:0197:       PartNumberWhitespacePad = 20 20 20 20 20 20 20 00
Byte:019F:       PartNumberPad = 00
Byte:01A0:       ProcessControlVersion = 00 00
Byte:01A2:       CongenConfigurationState = 01
Byte:01A3:       WrittenCount = 00
Byte:01A4:       InternalSeagateModelNumber =
                 53 54 33 31 30 30 30 35 32 33 43 53 20 20 20 20
                 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
                 'ST31000523CS                            '
Byte:01CC:       BuildFlags = 00 00
Byte:01CC:           Bit:0, QNR_SUPPORTED = 0
Byte:01CE:       RealTimeUpdatedFlags = 08 00
Byte:01CE:           Bit:3, CONGEN_READ_FROM_MEDIA = 1
           ANSIBackgroundMediaScan Mode Page
              ANSIBackgroundMediaScan Group
Byte:01D4:       BGMSFlags = 01
Byte:01D4:           Bit:0, BGMS_ENABLE = 1
Byte:01D5:       Prescan = 00
Byte:01D5:           Bit:0, BGMS_PRESCAN = 0
Byte:01D6:       BGMSIntervalTimeHoursMSB = 00
Byte:01D7:       BGMSIntervalTimeHoursLSB = 18
Byte:01D8:       PrescanTimeoutHoursMSB = 00
Byte:01D9:       PrescanTimeoutHoursLSB = 18
           UDSFastTraceClassesLevels Mode Page
              UDSFastTrace Group
Byte:01E4:       Revision = 00
Byte:01E5:       FastTraceLevels_0 = 11
Byte:01E6:       FastTraceLevels_1 = 11
Byte:01E7:       FastTraceLevels_2 = 11
Byte:01E8:       FastTraceLevels_3 = 11
Byte:01E9:       FastTraceLevels_4 = 11
Byte:01EA:       FastTraceLevels_5 = 11
Byte:01EB:       FastTraceLevels_6 = 11
Byte:01EC:       FastTraceLevels_7 = 12
Byte:01ED:       FastTraceLevels_8 = 11
Byte:01EE:       FastTraceLevels_9 = 11
Byte:01EF:       FastTraceLevels_10 = 10
Byte:01F0:       FastTraceLevels_11 = 11
Byte:01F1:       FastTraceLevels_12 = 11
Byte:01F2:       FastTraceLevels_13 = 11
Byte:01F3:       FastTraceLevels_14 = 11
Byte:01F4:       FastTraceLevels_15 = 11
Byte:01F5:       FastTraceLevels_16 = 11
Byte:01F6:       FastTraceLevels_17 = 11
Byte:01F7:       FastTraceLevels_18 = 11
Byte:01F8:       FastTraceLevels_19 = 11
Byte:01F9:       FastTraceLevels_20 = 11
Byte:01FA:       FastTraceLevels_21 = 11
Byte:01FB:       FastTraceLevels_22 = 11
Byte:01FC:       FastTraceLevels_23 = 11
Byte:01FD:       FastTraceLevels_24 = 11
Byte:01FE:       FastTraceLevels_25 = 11
Byte:01FF:       FastTraceLevels_26 = 11
Byte:0200:       FastTraceLevels_27 = 11
Byte:0201:       FastTraceLevels_28 = 11
Byte:0202:       FastTraceLevels_29 = 11
Byte:0203:       FastTraceLevels_30 = 11
Byte:0204:       FastTraceLevels_31 = 10
           UDSTriggerControl Mode Page
              UDSTrigger Group
Byte:020C:       Revision = 00
Byte:0210:       TriggerControlFlags1_0 = 00
Byte:0214:       TriggerCaptureFlags1_0 = 00
Byte:0215:       TriggerCaptureFlags2_0 = 00
Byte:0216:       SpecialTriggerCaptureFlags_0 = 00
Byte:0218:       TriggerResponseFlags1_0 = 00
Byte:0219:       TriggerResponseFlags2_0 = 00
Byte:021A:       SpecialTriggerResponseFlags_0 = 00
Byte:021C:       TriggerControlFlags1_1 = 00
Byte:0220:       TriggerCaptureFlags1_1 = 00
Byte:0221:       TriggerCaptureFlags2_1 = 00
Byte:0222:       SpecialTriggerCaptureFlags_1 = 00
Byte:0224:       TriggerResponseFlags1_1 = 00
Byte:0225:       TriggerResponseFlags2_1 = 00
Byte:0226:       SpecialTriggerResponseFlags_1 = 00
Byte:0228:       TriggerControlFlags1_2 = 80
Byte:022C:       TriggerCaptureFlags1_2 = F2
Byte:022D:       TriggerCaptureFlags2_2 = E8
Byte:022E:       SpecialTriggerCaptureFlags_2 = 80
Byte:0230:       TriggerResponseFlags1_2 = 00
Byte:0231:       TriggerResponseFlags2_2 = A0
Byte:0232:       SpecialTriggerResponseFlags_2 = 80
Byte:0234:       TriggerControlFlags1_3 = 80
Byte:0238:       TriggerCaptureFlags1_3 = F2
Byte:0239:       TriggerCaptureFlags2_3 = E8
Byte:023A:       SpecialTriggerCaptureFlags_3 = 80
Byte:023C:       TriggerResponseFlags1_3 = 00
Byte:023D:       TriggerResponseFlags2_3 = A0
Byte:023E:       SpecialTriggerResponseFlags_3 = 80
Byte:0240:       TriggerControlFlags1_4 = 80
Byte:0244:       TriggerCaptureFlags1_4 = F2
Byte:0245:       TriggerCaptureFlags2_4 = E8
Byte:0246:       SpecialTriggerCaptureFlags_4 = 80
Byte:0248:       TriggerResponseFlags1_4 = 02
Byte:0249:       TriggerResponseFlags2_4 = A0
Byte:024A:       SpecialTriggerResponseFlags_4 = 80
Byte:024C:       TriggerControlFlags1_5 = 80
Byte:0250:       TriggerCaptureFlags1_5 = F2
Byte:0251:       TriggerCaptureFlags2_5 = E8
Byte:0252:       SpecialTriggerCaptureFlags_5 = 80
Byte:0254:       TriggerResponseFlags1_5 = 00
Byte:0255:       TriggerResponseFlags2_5 = A0
Byte:0256:       SpecialTriggerResponseFlags_5 = 80
Byte:0258:       TriggerControlFlags1_6 = 80
Byte:025C:       TriggerCaptureFlags1_6 = 71
Byte:025D:       TriggerCaptureFlags2_6 = C8
Byte:025E:       SpecialTriggerCaptureFlags_6 = 80
Byte:0260:       TriggerResponseFlags1_6 = 00
Byte:0261:       TriggerResponseFlags2_6 = A0
Byte:0262:       SpecialTriggerResponseFlags_6 = 80
Byte:0264:       TriggerControlFlags1_7 = 80
Byte:0268:       TriggerCaptureFlags1_7 = 71
Byte:0269:       TriggerCaptureFlags2_7 = C8
Byte:026A:       SpecialTriggerCaptureFlags_7 = 80
Byte:026C:       TriggerResponseFlags1_7 = 00
Byte:026D:       TriggerResponseFlags2_7 = A0
Byte:026E:       SpecialTriggerResponseFlags_7 = 80
Byte:0270:       TriggerControlFlags1_8 = 80
Byte:0274:       TriggerCaptureFlags1_8 = F2
Byte:0275:       TriggerCaptureFlags2_8 = E8
Byte:0276:       SpecialTriggerCaptureFlags_8 = 80
Byte:0278:       TriggerResponseFlags1_8 = 00
Byte:0279:       TriggerResponseFlags2_8 = A0
Byte:027A:       SpecialTriggerResponseFlags_8 = 80
Byte:027C:       TriggerControlFlags1_9 = 80
Byte:0280:       TriggerCaptureFlags1_9 = F2
Byte:0281:       TriggerCaptureFlags2_9 = E8
Byte:0282:       SpecialTriggerCaptureFlags_9 = 80
Byte:0284:       TriggerResponseFlags1_9 = 00
Byte:0285:       TriggerResponseFlags2_9 = A0
Byte:0286:       SpecialTriggerResponseFlags_9 = 80
Byte:0288:       TriggerControlFlags1_10 = 00
Byte:028C:       TriggerCaptureFlags1_10 = 11
Byte:028D:       TriggerCaptureFlags2_10 = C8
Byte:028E:       SpecialTriggerCaptureFlags_10 = 80
Byte:0290:       TriggerResponseFlags1_10 = 00
Byte:0291:       TriggerResponseFlags2_10 = A0
Byte:0292:       SpecialTriggerResponseFlags_10 = 80
Byte:0294:       TriggerControlFlags1_11 = 80
Byte:0298:       TriggerCaptureFlags1_11 = F2
Byte:0299:       TriggerCaptureFlags2_11 = E8
Byte:029A:       SpecialTriggerCaptureFlags_11 = 80
Byte:029C:       TriggerResponseFlags1_11 = 00
Byte:029D:       TriggerResponseFlags2_11 = A0
Byte:029E:       SpecialTriggerResponseFlags_11 = 80
Byte:02A0:       TriggerControlFlags1_12 = 80
Byte:02A4:       TriggerCaptureFlags1_12 = F2
Byte:02A5:       TriggerCaptureFlags2_12 = E8
Byte:02A6:       SpecialTriggerCaptureFlags_12 = 80
Byte:02A8:       TriggerResponseFlags1_12 = 00
Byte:02A9:       TriggerResponseFlags2_12 = A0
Byte:02AA:       SpecialTriggerResponseFlags_12 = 80
Byte:02AC:       TriggerControlFlags1_13 = 00
Byte:02B0:       TriggerCaptureFlags1_13 = 00
Byte:02B1:       TriggerCaptureFlags2_13 = 00
Byte:02B2:       SpecialTriggerCaptureFlags_13 = 00
Byte:02B4:       TriggerResponseFlags1_13 = 00
Byte:02B5:       TriggerResponseFlags2_13 = 00
Byte:02B6:       SpecialTriggerResponseFlags_13 = 00
Byte:02B8:       TriggerControlFlags1_14 = 80
Byte:02BC:       TriggerCaptureFlags1_14 = F2
Byte:02BD:       TriggerCaptureFlags2_14 = E8
Byte:02BE:       SpecialTriggerCaptureFlags_14 = 80
Byte:02C0:       TriggerResponseFlags1_14 = 00
Byte:02C1:       TriggerResponseFlags2_14 = A0
Byte:02C2:       SpecialTriggerResponseFlags_14 = 80
Byte:02C4:       TriggerControlFlags1_15 = 80
Byte:02C8:       TriggerCaptureFlags1_15 = 71
Byte:02C9:       TriggerCaptureFlags2_15 = C8
Byte:02CA:       SpecialTriggerCaptureFlags_15 = 80
Byte:02CC:       TriggerResponseFlags1_15 = 00
Byte:02CD:       TriggerResponseFlags2_15 = A0
Byte:02CE:       SpecialTriggerResponseFlags_15 = 80
Byte:02D0:       TriggerControlFlags1_16 = 00
Byte:02D4:       TriggerCaptureFlags1_16 = F2
Byte:02D5:       TriggerCaptureFlags2_16 = C8
Byte:02D6:       SpecialTriggerCaptureFlags_16 = 80
Byte:02D8:       TriggerResponseFlags1_16 = 00
Byte:02D9:       TriggerResponseFlags2_16 = A0
Byte:02DA:       SpecialTriggerResponseFlags_16 = 80
Byte:02DC:       TriggerControlFlags1_17 = 00
Byte:02E0:       TriggerCaptureFlags1_17 = 00
Byte:02E1:       TriggerCaptureFlags2_17 = 00
Byte:02E2:       SpecialTriggerCaptureFlags_17 = 00
Byte:02E4:       TriggerResponseFlags1_17 = 00
Byte:02E5:       TriggerResponseFlags2_17 = 00
Byte:02E6:       SpecialTriggerResponseFlags_17 = 00
Byte:02E8:       TriggerControlFlags1_18 = 80
Byte:02EC:       TriggerCaptureFlags1_18 = 71
Byte:02ED:       TriggerCaptureFlags2_18 = C8
Byte:02EE:       SpecialTriggerCaptureFlags_18 = 80
Byte:02F0:       TriggerResponseFlags1_18 = 00
Byte:02F1:       TriggerResponseFlags2_18 = A0
Byte:02F2:       SpecialTriggerResponseFlags_18 = 80
Byte:02F4:       TriggerControlFlags1_19 = 00
Byte:02F8:       TriggerCaptureFlags1_19 = 00
Byte:02F9:       TriggerCaptureFlags2_19 = 00
Byte:02FA:       SpecialTriggerCaptureFlags_19 = 00
Byte:02FC:       TriggerResponseFlags1_19 = 00
Byte:02FD:       TriggerResponseFlags2_19 = 00
Byte:02FE:       SpecialTriggerResponseFlags_19 = 00
Byte:0300:       TriggerControlFlags1_20 = 00
Byte:0304:       TriggerCaptureFlags1_20 = 00
Byte:0305:       TriggerCaptureFlags2_20 = 00
Byte:0306:       SpecialTriggerCaptureFlags_20 = 00
Byte:0308:       TriggerResponseFlags1_20 = 00
Byte:0309:       TriggerResponseFlags2_20 = 00
Byte:030A:       SpecialTriggerResponseFlags_20 = 00
Byte:030C:       TriggerControlFlags1_21 = 00
Byte:0310:       TriggerCaptureFlags1_21 = 00
Byte:0311:       TriggerCaptureFlags2_21 = 00
Byte:0312:       SpecialTriggerCaptureFlags_21 = 00
Byte:0314:       TriggerResponseFlags1_21 = 00
Byte:0315:       TriggerResponseFlags2_21 = 00
Byte:0316:       SpecialTriggerResponseFlags_21 = 00
           UDSTraceBufferConfig Mode Page
              UDSBuffer Group
Byte:031C:       Revision = 00
Byte:0320:       MinimumAllocationInTraceBlocksMSB_0 = 00
Byte:0321:       MinimumAllocationInTraceBlocksLSB_0 = 05
Byte:0322:       TraceBufferControlFlags1_0 = 80
Byte:0324:       MinimumAllocationInTraceBlocksMSB_1 = 00
Byte:0325:       MinimumAllocationInTraceBlocksLSB_1 = 00
Byte:0326:       TraceBufferControlFlags1_1 = 00
Byte:0328:       MinimumAllocationInTraceBlocksMSB_2 = 00
Byte:0329:       MinimumAllocationInTraceBlocksLSB_2 = 00
Byte:032A:       TraceBufferControlFlags1_2 = 00
Byte:032C:       MinimumAllocationInTraceBlocksMSB_3 = 00
Byte:032D:       MinimumAllocationInTraceBlocksLSB_3 = 00
Byte:032E:       TraceBufferControlFlags1_3 = 00
Byte:0330:       MinimumAllocationInTraceBlocksMSB_4 = 00
Byte:0331:       MinimumAllocationInTraceBlocksLSB_4 = 00
Byte:0332:       TraceBufferControlFlags1_4 = 00
Byte:0334:       MinimumAllocationInTraceBlocksMSB_5 = 00
Byte:0335:       MinimumAllocationInTraceBlocksLSB_5 = 00
Byte:0336:       TraceBufferControlFlags1_5 = 00
Byte:0338:       MinimumAllocationInTraceBlocksMSB_6 = 00
Byte:0339:       MinimumAllocationInTraceBlocksLSB_6 = 00
Byte:033A:       TraceBufferControlFlags1_6 = 00
Byte:033C:       MinimumAllocationInTraceBlocksMSB_7 = 00
Byte:033D:       MinimumAllocationInTraceBlocksLSB_7 = 00
Byte:033E:       TraceBufferControlFlags1_7 = 00
Byte:0340:       MinimumAllocationInTraceBlocksMSB_8 = 00
Byte:0341:       MinimumAllocationInTraceBlocksLSB_8 = 00
Byte:0342:       TraceBufferControlFlags1_8 = 00
Byte:0344:       MinimumAllocationInTraceBlocksMSB_9 = 00
Byte:0345:       MinimumAllocationInTraceBlocksLSB_9 = 00
Byte:0346:       TraceBufferControlFlags1_9 = 00
Byte:0348:       MinimumAllocationInTraceBlocksMSB_10 = 00
Byte:0349:       MinimumAllocationInTraceBlocksLSB_10 = 00
Byte:034A:       TraceBufferControlFlags1_10 = 00
Byte:034C:       MinimumAllocationInTraceBlocksMSB_11 = 00
Byte:034D:       MinimumAllocationInTraceBlocksLSB_11 = 00
Byte:034E:       TraceBufferControlFlags1_11 = 00
Byte:0350:       MinimumAllocationInTraceBlocksMSB_12 = 00
Byte:0351:       MinimumAllocationInTraceBlocksLSB_12 = 00
Byte:0352:       TraceBufferControlFlags1_12 = 00
Byte:0354:       MinimumAllocationInTraceBlocksMSB_13 = 00
Byte:0355:       MinimumAllocationInTraceBlocksLSB_13 = 00
Byte:0356:       TraceBufferControlFlags1_13 = 00
Byte:0358:       MinimumAllocationInTraceBlocksMSB_14 = 00
Byte:0359:       MinimumAllocationInTraceBlocksLSB_14 = 00
Byte:035A:       TraceBufferControlFlags1_14 = 00
Byte:035C:       MinimumAllocationInTraceBlocksMSB_15 = 00
Byte:035D:       MinimumAllocationInTraceBlocksLSB_15 = 00
Byte:035E:       TraceBufferControlFlags1_15 = 00
Byte:0360:       MinimumAllocationInTraceBlocksMSB_16 = 00
Byte:0361:       MinimumAllocationInTraceBlocksLSB_16 = 00
Byte:0362:       TraceBufferControlFlags1_16 = 00
Byte:0364:       MinimumAllocationInTraceBlocksMSB_17 = 00
Byte:0365:       MinimumAllocationInTraceBlocksLSB_17 = 00
Byte:0366:       TraceBufferControlFlags1_17 = 00
Byte:0368:       MinimumAllocationInTraceBlocksMSB_18 = 00
Byte:0369:       MinimumAllocationInTraceBlocksLSB_18 = 00
Byte:036A:       TraceBufferControlFlags1_18 = 00
Byte:036C:       MinimumAllocationInTraceBlocksMSB_19 = 00
Byte:036D:       MinimumAllocationInTraceBlocksLSB_19 = 00
Byte:036E:       TraceBufferControlFlags1_19 = 00
Byte:0370:       MinimumAllocationInTraceBlocksMSB_20 = 00
Byte:0371:       MinimumAllocationInTraceBlocksLSB_20 = 00
Byte:0372:       TraceBufferControlFlags1_20 = 00
Byte:0374:       MinimumAllocationInTraceBlocksMSB_21 = 00
Byte:0375:       MinimumAllocationInTraceBlocksLSB_21 = 00
Byte:0376:       TraceBufferControlFlags1_21 = 00
Byte:0378:       MinimumAllocationInTraceBlocksMSB_22 = 00
Byte:0379:       MinimumAllocationInTraceBlocksLSB_22 = 00
Byte:037A:       TraceBufferControlFlags1_22 = 00
Byte:037C:       MinimumAllocationInTraceBlocksMSB_23 = 00
Byte:037D:       MinimumAllocationInTraceBlocksLSB_23 = 00
Byte:037E:       TraceBufferControlFlags1_23 = 00
Byte:0380:       MinimumAllocationInTraceBlocksMSB_24 = 00
Byte:0381:       MinimumAllocationInTraceBlocksLSB_24 = 00
Byte:0382:       TraceBufferControlFlags1_24 = 00
Byte:0384:       MinimumAllocationInTraceBlocksMSB_25 = 00
Byte:0385:       MinimumAllocationInTraceBlocksLSB_25 = 00
Byte:0386:       TraceBufferControlFlags1_25 = 00
Byte:0388:       MinimumAllocationInTraceBlocksMSB_26 = 00
Byte:0389:       MinimumAllocationInTraceBlocksLSB_26 = 00
Byte:038A:       TraceBufferControlFlags1_26 = 00
Byte:038C:       MinimumAllocationInTraceBlocksMSB_27 = 00
Byte:038D:       MinimumAllocationInTraceBlocksLSB_27 = 00
Byte:038E:       TraceBufferControlFlags1_27 = 00
Byte:0390:       MinimumAllocationInTraceBlocksMSB_28 = 00
Byte:0391:       MinimumAllocationInTraceBlocksLSB_28 = 00
Byte:0392:       TraceBufferControlFlags1_28 = 00
Byte:0394:       MinimumAllocationInTraceBlocksMSB_29 = 00
Byte:0395:       MinimumAllocationInTraceBlocksLSB_29 = 00
Byte:0396:       TraceBufferControlFlags1_29 = 00
Byte:0398:       MinimumAllocationInTraceBlocksMSB_30 = 00
Byte:0399:       MinimumAllocationInTraceBlocksLSB_30 = 00
Byte:039A:       TraceBufferControlFlags1_30 = 00
Byte:039C:       MinimumAllocationInTraceBlocksMSB_31 = 00
Byte:039D:       MinimumAllocationInTraceBlocksLSB_31 = 00
Byte:039E:       TraceBufferControlFlags1_31 = 00
Byte:03A0:       MinimumAllocationInTraceBlocksMSB_32 = 00
Byte:03A1:       MinimumAllocationInTraceBlocksLSB_32 = 00
Byte:03A2:       TraceBufferControlFlags1_32 = 00
Byte:03A4:       MinimumAllocationInTraceBlocksMSB_33 = 00
Byte:03A5:       MinimumAllocationInTraceBlocksLSB_33 = 00
Byte:03A6:       TraceBufferControlFlags1_33 = 00
Byte:03A8:       MinimumAllocationInTraceBlocksMSB_34 = 00
Byte:03A9:       MinimumAllocationInTraceBlocksLSB_34 = 00
Byte:03AA:       TraceBufferControlFlags1_34 = 00
Byte:03AC:       MinimumAllocationInTraceBlocksMSB_35 = 00
Byte:03AD:       MinimumAllocationInTraceBlocksLSB_35 = 00
Byte:03AE:       TraceBufferControlFlags1_35 = 00
Byte:03B0:       MinimumAllocationInTraceBlocksMSB_36 = 00
Byte:03B1:       MinimumAllocationInTraceBlocksLSB_36 = 00
Byte:03B2:       TraceBufferControlFlags1_36 = 00
Byte:03B4:       MinimumAllocationInTraceBlocksMSB_37 = 00
Byte:03B5:       MinimumAllocationInTraceBlocksLSB_37 = 00
Byte:03B6:       TraceBufferControlFlags1_37 = 00
Byte:03B8:       MinimumAllocationInTraceBlocksMSB_38 = 00
Byte:03B9:       MinimumAllocationInTraceBlocksLSB_38 = 00
Byte:03BA:       TraceBufferControlFlags1_38 = 00
Byte:03BC:       MinimumAllocationInTraceBlocksMSB_39 = 00
Byte:03BD:       MinimumAllocationInTraceBlocksLSB_39 = 00
Byte:03BE:       TraceBufferControlFlags1_39 = 00
Byte:03C0:       MinimumAllocationInTraceBlocksMSB_40 = 00
Byte:03C1:       MinimumAllocationInTraceBlocksLSB_40 = 00
Byte:03C2:       TraceBufferControlFlags1_40 = 00
Byte:03C4:       MinimumAllocationInTraceBlocksMSB_41 = 00
Byte:03C5:       MinimumAllocationInTraceBlocksLSB_41 = 00
Byte:03C6:       TraceBufferControlFlags1_41 = 00
Byte:03C8:       MinimumAllocationInTraceBlocksMSB_42 = 00
Byte:03C9:       MinimumAllocationInTraceBlocksLSB_42 = 00
Byte:03CA:       TraceBufferControlFlags1_42 = 00
Byte:03CC:       MinimumAllocationInTraceBlocksMSB_43 = 00
Byte:03CD:       MinimumAllocationInTraceBlocksLSB_43 = 00
Byte:03CE:       TraceBufferControlFlags1_43 = 00
Byte:03D0:       MinimumAllocationInTraceBlocksMSB_44 = 00
Byte:03D1:       MinimumAllocationInTraceBlocksLSB_44 = 00
Byte:03D2:       TraceBufferControlFlags1_44 = 00
Byte:03D4:       MinimumAllocationInTraceBlocksMSB_45 = 00
Byte:03D5:       MinimumAllocationInTraceBlocksLSB_45 = 00
Byte:03D6:       TraceBufferControlFlags1_45 = 00
Byte:03D8:       MinimumAllocationInTraceBlocksMSB_46 = 00
Byte:03D9:       MinimumAllocationInTraceBlocksLSB_46 = 00
Byte:03DA:       TraceBufferControlFlags1_46 = 00
Byte:03DC:       MinimumAllocationInTraceBlocksMSB_47 = 00
Byte:03DD:       MinimumAllocationInTraceBlocksLSB_47 = 00
Byte:03DE:       TraceBufferControlFlags1_47 = 00
Byte:03E0:       MinimumAllocationInTraceBlocksMSB_48 = 00
Byte:03E1:       MinimumAllocationInTraceBlocksLSB_48 = 00
Byte:03E2:       TraceBufferControlFlags1_48 = 00
Byte:03E4:       MinimumAllocationInTraceBlocksMSB_49 = 00
Byte:03E5:       MinimumAllocationInTraceBlocksLSB_49 = 00
Byte:03E6:       TraceBufferControlFlags1_49 = 00
Byte:03E8:       MinimumAllocationInTraceBlocksMSB_50 = 00
Byte:03E9:       MinimumAllocationInTraceBlocksLSB_50 = 00
Byte:03EA:       TraceBufferControlFlags1_50 = 00
Byte:03EC:       MinimumAllocationInTraceBlocksMSB_51 = 00
Byte:03ED:       MinimumAllocationInTraceBlocksLSB_51 = 00
Byte:03EE:       TraceBufferControlFlags1_51 = 00
Byte:03F0:       MinimumAllocationInTraceBlocksMSB_52 = 00
Byte:03F1:       MinimumAllocationInTraceBlocksLSB_52 = 00
Byte:03F2:       TraceBufferControlFlags1_52 = 00
Byte:03F4:       MinimumAllocationInTraceBlocksMSB_53 = 00
Byte:03F5:       MinimumAllocationInTraceBlocksLSB_53 = 00
Byte:03F6:       TraceBufferControlFlags1_53 = 00
Byte:03F8:       MinimumAllocationInTraceBlocksMSB_54 = 00
Byte:03F9:       MinimumAllocationInTraceBlocksLSB_54 = 00
Byte:03FA:       TraceBufferControlFlags1_54 = 00
Byte:03FC:       MinimumAllocationInTraceBlocksMSB_55 = 00
Byte:03FD:       MinimumAllocationInTraceBlocksLSB_55 = 00
Byte:03FE:       TraceBufferControlFlags1_55 = 00
Byte:0400:       MinimumAllocationInTraceBlocksMSB_56 = 00
Byte:0401:       MinimumAllocationInTraceBlocksLSB_56 = 00
Byte:0402:       TraceBufferControlFlags1_56 = 00
Byte:0404:       MinimumAllocationInTraceBlocksMSB_57 = 00
Byte:0405:       MinimumAllocationInTraceBlocksLSB_57 = 00
Byte:0406:       TraceBufferControlFlags1_57 = 00
Byte:0408:       MinimumAllocationInTraceBlocksMSB_58 = 00
Byte:0409:       MinimumAllocationInTraceBlocksLSB_58 = 00
Byte:040A:       TraceBufferControlFlags1_58 = 00
Byte:040C:       MinimumAllocationInTraceBlocksMSB_59 = 00
Byte:040D:       MinimumAllocationInTraceBlocksLSB_59 = 00
Byte:040E:       TraceBufferControlFlags1_59 = 00
Byte:0410:       MinimumAllocationInTraceBlocksMSB_60 = 00
Byte:0411:       MinimumAllocationInTraceBlocksLSB_60 = 00
Byte:0412:       TraceBufferControlFlags1_60 = 00
Byte:0414:       MinimumAllocationInTraceBlocksMSB_61 = 00
Byte:0415:       MinimumAllocationInTraceBlocksLSB_61 = 00
Byte:0416:       TraceBufferControlFlags1_61 = 00
Byte:0418:       MinimumAllocationInTraceBlocksMSB_62 = 00
Byte:0419:       MinimumAllocationInTraceBlocksLSB_62 = 00
Byte:041A:       TraceBufferControlFlags1_62 = 00
Byte:041C:       MinimumAllocationInTraceBlocksMSB_63 = 00
Byte:041D:       MinimumAllocationInTraceBlocksLSB_63 = 00
Byte:041E:       TraceBufferControlFlags1_63 = 00
Byte:0420:       MinimumAllocationInTraceBlocksMSB_64 = 00
Byte:0421:       MinimumAllocationInTraceBlocksLSB_64 = 00
Byte:0422:       TraceBufferControlFlags1_64 = 00
Byte:0424:       MinimumAllocationInTraceBlocksMSB_65 = 00
Byte:0425:       MinimumAllocationInTraceBlocksLSB_65 = 00
Byte:0426:       TraceBufferControlFlags1_65 = 00
Byte:0428:       MinimumAllocationInTraceBlocksMSB_66 = 00
Byte:0429:       MinimumAllocationInTraceBlocksLSB_66 = 00
Byte:042A:       TraceBufferControlFlags1_66 = 00
Byte:042C:       MinimumAllocationInTraceBlocksMSB_67 = 00
Byte:042D:       MinimumAllocationInTraceBlocksLSB_67 = 00
Byte:042E:       TraceBufferControlFlags1_67 = 00
Byte:0430:       MinimumAllocationInTraceBlocksMSB_68 = 00
Byte:0431:       MinimumAllocationInTraceBlocksLSB_68 = 00
Byte:0432:       TraceBufferControlFlags1_68 = 00
Byte:0434:       MinimumAllocationInTraceBlocksMSB_69 = 00
Byte:0435:       MinimumAllocationInTraceBlocksLSB_69 = 00
Byte:0436:       TraceBufferControlFlags1_69 = 00
Byte:0438:       MinimumAllocationInTraceBlocksMSB_70 = 00
Byte:0439:       MinimumAllocationInTraceBlocksLSB_70 = 00
Byte:043A:       TraceBufferControlFlags1_70 = 00
Byte:043C:       MinimumAllocationInTraceBlocksMSB_71 = 00
Byte:043D:       MinimumAllocationInTraceBlocksLSB_71 = 00
Byte:043E:       TraceBufferControlFlags1_71 = 00
Byte:0440:       MinimumAllocationInTraceBlocksMSB_72 = 00
Byte:0441:       MinimumAllocationInTraceBlocksLSB_72 = 00
Byte:0442:       TraceBufferControlFlags1_72 = 00
Byte:0444:       MinimumAllocationInTraceBlocksMSB_73 = 00
Byte:0445:       MinimumAllocationInTraceBlocksLSB_73 = 00
Byte:0446:       TraceBufferControlFlags1_73 = 00
Byte:0448:       MinimumAllocationInTraceBlocksMSB_74 = 00
Byte:0449:       MinimumAllocationInTraceBlocksLSB_74 = 00
Byte:044A:       TraceBufferControlFlags1_74 = 00
Byte:044C:       MinimumAllocationInTraceBlocksMSB_75 = 00
Byte:044D:       MinimumAllocationInTraceBlocksLSB_75 = 00
Byte:044E:       TraceBufferControlFlags1_75 = 00
Byte:0450:       MinimumAllocationInTraceBlocksMSB_76 = 00
Byte:0451:       MinimumAllocationInTraceBlocksLSB_76 = 00
Byte:0452:       TraceBufferControlFlags1_76 = 00
           Congen Mode Page
              Congen Group
Byte:0458:       NumDefaultATCyls = FF 3F
Byte:045A:       NumDefaultATHeads = 10 00
Byte:045C:       NumDefaultATSectors = 3F 00
Byte:045E:       NumECCBytesForLongCmds = 04 00
Byte:0460:       MaximumMultipleSize = 10
Byte:0461:       LogicalSectorAlignment = 00
Byte:0462:       PIOModeTiming = 00 02
Byte:0464:       DMAModeTiming = 00 02
Byte:0466:       NumCurrentATCyls = FF 3F
Byte:0468:       NumCurrentATHeads = 10 00
Byte:046A:       NumCurrentATSectors = 3F 00
Byte:046C:       CurrentMultipleSize = 10 00
Byte:046E:       MultiwordDMAModesSupported = 07
Byte:046E:           Bit:0, MULTIWORD_DMA_MODE_0_SUPPORTED = 1
Byte:046E:           Bit:1, MULTIWORD_DMA_MODE_1_SUPPORTED = 1
Byte:046E:           Bit:2, MULTIWORD_DMA_MODE_2_SUPPORTED = 1
Byte:046F:       UltraDMAModesSupported = 7F
Byte:046F:           Bit:0, ULTRA_DMA_MODE0_SUPPORTED = 1
Byte:046F:           Bit:1, ULTRA_DMA_MODE1_AND_BELOW_SUPPORTED = 1
Byte:046F:           Bit:2, ULTRA_DMA_MODE2_AND_BELOW_SUPPORTED = 1
Byte:046F:           Bit:3, ULTRA_DMA_MODE3_AND_BELOW_SUPPORTED = 1
Byte:046F:           Bit:4, ULTRA_DMA_MODE4_AND_BELOW_SUPPORTED = 1
Byte:046F:           Bit:5, ULTRA_DMA_MODE5_AND_BELOW_SUPPORTED = 1
Byte:046F:           Bit:6, ULTRA_DMA_MODE6_AND_BELOW_SUPPORTED = 1
Byte:0470:       AdvancedPIOModesSupported = 03 00
Byte:0470:           Bit:0, PIO_MODE_3_SUPPORTED = 1
Byte:0470:           Bit:1, PIO_MODE_4_SUPPORTED = 1
Byte:0472:       MinimumMultiwordDMACycleTime = 78 00
Byte:0474:       RecommendedMultiwordDMACycleTime = 78 00
Byte:0476:       MinimumPIOTimeWithoutFlowControl = 78 00
Byte:0478:       MinimumPIOTimeWithFlowControl = 78 00
Byte:047A:       QDepth = 1F 00
Byte:047C:       SATACapabilities = 0E 05
Byte:047D:           Bit:0, SATA_NCQ_SUPPORTED = 1
Byte:047D:           Bit:1, HOST_INITIATED_PHY_POWER_MANAGEMENT_SUPPORTED = 0
Byte:047D:           Bit:2, SATA_PHY_EVENT_COUNTERS_SUPPORTED = 1
Byte:047D:           Bit:3, UNLOAD_WHILE_NCQ_CMDS_OUTSTANDING_SUPPORTED = 0
Byte:047D:           Bit:4, NCQ_PRIORITY_SUPPORTED = 0
Byte:0480:       SATAFeaturesSupported = 48 00
Byte:0480:           Bit:2, DMA_AUTOACTIVATE_SUPPORTED = 0
Byte:0480:           Bit:3, DEVICE_INITIATED_POWER_MANAGEMENT_SUPPORTED = 1
Byte:0480:           Bit:6, PRESERVE_SETTINGS_ON_COMRESET_SUPPORTED = 1
Byte:0482:       SATAFeaturesEnabled = 40 00
Byte:0482:           Bit:2, DMA_AUTOACTIVATE_ENABLED = 0
Byte:0482:           Bit:3, DEVICE_INITIATED_POWER_MANAGEMENT_ENABLED = 0
Byte:0482:           Bit:6, PRESERVE_SETTINGS_ON_COMRESET_ENABLED = 1
Byte:0484:       MajorVersionNumber = F0 01
Byte:0484:           Bit:1, ATAPI_1_SUPPORTED = 0
Byte:0484:           Bit:2, ATAPI_2_SUPPORTED = 0
Byte:0484:           Bit:3, ATAPI_3_SUPPORTED = 0
Byte:0484:           Bit:4, ATAPI_4_SUPPORTED = 1
Byte:0484:           Bit:5, ATAPI_5_SUPPORTED = 1
Byte:0484:           Bit:6, ATAPI_6_SUPPORTED = 1
Byte:0484:           Bit:7, ATAPI_7_SUPPORTED = 1
Byte:0485:           Bit:0, ATAPI_8_ACS_SUPPORTED = 1
Byte:0486:       MinorVersionNumber = 29 00
Byte:0488:       CommandSetSupported = 6B 34
Byte:0488:           Bit:0, SMART_SUPPORTED = 1
Byte:0488:           Bit:1, SECURITY_MODE_FEATURE_SET_SUPPORTED = 1
Byte:0488:           Bit:5, WRITE_CACHE_SUPPORTED = 1
Byte:0488:           Bit:6, READ_LOOKAHEAD_SUPPORTED = 1
Byte:0489:           Bit:2, HOST_PROTECTED_AREA_SUPPORTED = 1
Byte:0489:           Bit:4, WRITE_BUFFER_CMD_SUPPORTED = 1
Byte:0489:           Bit:5, READ_BUFFER_CMD_SUPPORTED = 1
Byte:0489:           Bit:6, NOP_CMD_SUPPORTED = 0
Byte:048A:       CommandSetsSupported = 29 7F
Byte:048A:           Bit:1, READ_WRITE_DMA_QUEUED_SUPPORTED = 0
Byte:048A:           Bit:3, ADVANCED_POWER_MANAGEMENT_SUPPORTED = 1
Byte:048A:           Bit:5, POWER_UP_IN_STANDBY_SUPPORTED = 1
Byte:048A:           Bit:6, SET_FEATURES_SPINUP_REQUIRED_SUPPORTED = 0
Byte:048B:           Bit:0, SET_MAX_SECURITY_EXTENSION_SUPPORTED = 1
Byte:048B:           Bit:1, AUTO_ACOUSTIC_MANAGEMENT_SUPPORTED = 1
Byte:048B:           Bit:2, FOURTYEIGHT_BIT_SUPPORTED = 1
Byte:048B:           Bit:3, DCO_COMMAND_SETS_SUPPORTED = 1
Byte:048B:           Bit:4, FLUSH_CACHE_SUPPORTED = 1
Byte:048B:           Bit:5, FLUSH_CACHE_EXT_SUPPORTED = 1
Byte:048C:       CommandSetSupportedExtension = 63 41
Byte:048C:           Bit:0, SMART_ERROR_LOGGING_SUPPORTED = 1
Byte:048C:           Bit:1, SMART_SELF_TEST_SUPPORTED = 1
Byte:048C:           Bit:2, MEDIA_SERIALNUMBER_SUPPORTED = 0
Byte:048C:           Bit:4, STREAMING_FEATURE_SET_SUPPORTED = 0
Byte:048C:           Bit:6, FUA_WRITE_EXT_COMMANDS_SUPPORTED = 1
Byte:048C:           Bit:7, FUA_WRITE_QUEUED_EXT_COMMANDS_SUPPORTED = 0
Byte:048D:           Bit:0, SIXTYFOUR_BIT_WWN_SUPPORTED = 1
Byte:048D:           Bit:3, AV_LITE_SUPPORTED = 0
Byte:048D:           Bit:4, AV_LITE_RC_WC_SUPPORTED = 0
Byte:048D:           Bit:5, IDLE_IMMEDIATE_UNLOAD_SUPPORTED = 0
Byte:048E:       CommandSetEnabled = 69 34
Byte:048E:           Bit:0, SMART_ENABLED = 1
Byte:048E:           Bit:1, SECURITY_MODE_FEATURE_SET_ENABLED = 0
Byte:048E:           Bit:5, WRITE_CACHE_ENABLED = 1
Byte:048E:           Bit:6, READ_LOOKAHEAD_ENABLED = 1
Byte:048F:           Bit:2, HOST_PROTECTED_AREA_ENABLED = 1
Byte:0490:       CommandSetsEnabled = 09 BE
Byte:0490:           Bit:3, ADVANCED_POWER_MANAGEMENT_ENABLED = 1
Byte:0490:           Bit:5, POWER_UP_IN_STANDBY_ENABLED = 0
Byte:0490:           Bit:6, SET_FEATURES_SPINUP_REQUIRED_ENABLED = 0
Byte:0490:           Bit:7, ADDRESS_OFFSET_RESERVED_AREA_BOOT = 0
Byte:0491:           Bit:0, SET_MAX_SECURITY_EXTENSION_ENABLED = 0
Byte:0491:           Bit:1, AUTO_ACOUSTIC_MANAGEMENT_ENABLED = 1
Byte:0492:       CommandSetEnabledExtension = 63 41
Byte:0492:           Bit:2, MEDIA_SERIALNUMBER_IS_VALID = 0
Byte:0493:           Bit:3, AV_LITE_ENABLED = 0
Byte:0493:           Bit:4, AV_LITE_RC_WC_ENABLED = 0
Byte:0494:       FreeFallSensitivity = 00 00
Byte:0496:       CurrentAPMValue = C0 C0
Byte:0498:       MasterPasswordRevisionCode = FE FF
Byte:049A:       AcousticLevel = 00 FE
Byte:049C:       StreamMinRequestSize = 00 00
Byte:049E:       StreamXferTimeDMA = 00 00
Byte:04A0:       StreamAccessLatency = 00 00
Byte:04A2:       StreamPerformanceGranularity = 00 00 00 00
Byte:04A6:       StreamXferTimePIO = 00 00
Byte:04A8:       Max512ByteUnitsPerDownloadMicrocode = 00 00
Byte:04AA:       PhysicalLogicalSectorSize = 00 00
Byte:04AA:           Bit:0, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B0 = 0
Byte:04AA:           Bit:1, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B1 = 0
Byte:04AA:           Bit:2, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B2 = 0
Byte:04AA:           Bit:3, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B3 = 0
Byte:04AB:           Bit:4, DEV_LOG_SEC_LEN_GREATER_THAN_256W = 0
Byte:04AB:           Bit:5, DEV_HAS_MUL_LOG_SECTORS_PER_PHY_SECTOR = 0
Byte:04AC:       AVLiteWorstCaseTimer = 00 00
Byte:04AE:       WordsPerLogicalSector = 00 01 00 00
Byte:04B2:       ATACommandSetSupportedExt2 = 0E 40
Byte:04B2:           Bit:1, WRITE_READ_VERIFY_SUPPORTED = 1
Byte:04B2:           Bit:2, WRITE_UNCORRECTABLE_SUPPORTED = 1
Byte:04B2:           Bit:3, READ_AND_WRITE_DMA_EXP_GPL_COMMANDS_SUPPORTED = 1
Byte:04B2:           Bit:5, FREEFALL_SENSOR_SUPPORTED = 0
Byte:04B2:           Bit:6, EXTENDED_POWER_CONDITIONS_SUPPORTED = 0
Byte:04B4:       ATACommandSetEnabledExt2 = 08 40
Byte:04B4:           Bit:1, WRITE_READ_VERIFY_ENABLED = 0
Byte:04B4:           Bit:3, READ_AND_WRITE_DMA_EXP_GPL_COMMANDS_ENABLED = 1
Byte:04B4:           Bit:5, FREEFALL_SENSOR_ENABLED_BY_DEFAULT = 0
Byte:04B4:           Bit:6, EXTENDED_POWER_CONDITIONS_ENABLED = 0
Byte:04B6:       ATATransportMajorRevisionNumber = 08 10
Byte:04B8:       ATATransportMinorRevisionNumber = 00 00
Byte:04BA:       ATSMARTDefaultFlags = 01 00
Byte:04BA:           Bit:0, SMARTDEFAULTON = 1
Byte:04BC:       ATSMARTConfig =
                 0F 00 06 00 03 00 00 00 32 00 14 00 33 00 24 00
                 0F 00 1E 00 32 00 00 00 13 00 61 00 32 00 14 00
                 32 00 00 00 3A 00 00 00 22 00 2D 00 32 00 00 00
                 32 00 00 00 32 00 00 00 22 00 00 00 1A 00 00 00
                 12 00 00 00 10 00 00 00 3E 00 00 00 32 00 63 00
                 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                 00 00 00 00 32 00 00 00 0F 00 1E 00 32 00 00 00
Byte:04BC:       SMART1Status = 0F 00
Byte:04BE:       SMART1Threshold = 06
Byte:04C0:       SMART2Status = 03 00
Byte:04C2:       SMART2Threshold = 00
Byte:04C4:       SMART3Status = 32 00
Byte:04C6:       SMART3Threshold = 14
Byte:04C8:       SMART4Status = 33 00
Byte:04CA:       SMART4Threshold = 24
Byte:04CC:       SMART5Status = 0F 00
Byte:04CE:       SMART5Threshold = 1E
Byte:04D0:       SMART6Status = 32 00
Byte:04D2:       SMART6Threshold = 00
Byte:04D4:       SMART7Status = 13 00
Byte:04D6:       SMART7Threshold = 61
Byte:04D8:       SMART8Status = 32 00
Byte:04DA:       SMART8Threshold = 14
Byte:04DC:       SMART9Status = 32 00
Byte:04DE:       SMART9Threshold = 00
Byte:04E0:       SMART10Status = 3A 00
Byte:04E2:       SMART10Threshold = 00
Byte:04E4:       SMART11Status = 22 00
Byte:04E6:       SMART11Threshold = 2D
Byte:04E8:       SMART12Status = 32 00
Byte:04EA:       SMART12Threshold = 00
Byte:04EC:       SMART13Status = 32 00
Byte:04EE:       SMART13Threshold = 00
Byte:04F0:       SMART14Status = 32 00
Byte:04F2:       SMART14Threshold = 00
Byte:04F4:       SMART15Status = 22 00
Byte:04F6:       SMART15Threshold = 00
Byte:04F8:       SMART16Status = 1A 00
Byte:04FA:       SMART16Threshold = 00
Byte:04FC:       SMART17Status = 12 00
Byte:04FE:       SMART17Threshold = 00
Byte:0500:       SMART18Status = 10 00
Byte:0502:       SMART18Threshold = 00
Byte:0504:       SMART19Status = 3E 00
Byte:0506:       SMART19Threshold = 00
Byte:0508:       SMART20Status = 32 00
Byte:050A:       SMART20Threshold = 63
Byte:050C:       SMART21Status = 32 00
Byte:050E:       SMART21Threshold = 00
Byte:0510:       SMART22Status = 00 00
Byte:0512:       SMART22Threshold = 00
Byte:0514:       SMART23Status = 00 00
Byte:0516:       SMART23Threshold = 00
Byte:0518:       SMART24Status = 00 00
Byte:051A:       SMART24Threshold = 00
Byte:051C:       SMART25Status = 00 00
Byte:051E:       SMART25Threshold = 00
Byte:0520:       SMART26Status = 32 00
Byte:0522:       SMART26Threshold = 00
Byte:0524:       SMART27Status = 0F 00
Byte:0526:       SMART27Threshold = 1E
Byte:0528:       SMART28Status = 32 00
Byte:052A:       SMART28Threshold = 00
Byte:052C:       SMART29Status = 00 00
Byte:052E:       SMART29Threshold = 00
Byte:0530:       SMART30Status = 00 00
Byte:0532:       SMART30Threshold = 00
Byte:0536:       SCTCommandSetSupported = 3F 10
Byte:0536:           Bit:0, SCT_SUPPORTED_COMMAND_SET = 1
Byte:0536:           Bit:1, SCT_SUPPORTED_LONG_SECTOR_ACCESS = 1
Byte:0536:           Bit:2, SCT_SUPPORTED_LBA_SEGMENT_ACCESS = 1
Byte:0536:           Bit:3, SCT_SUPPORTED_ERROR_RECOVERY_CONTROL = 1
Byte:0536:           Bit:4, SCT_SUPPORTED_FEATURES_CONTROL = 1
Byte:0536:           Bit:5, SCT_SUPPORTED_DATA_TABLE = 1
Byte:0538:       SCTFanControlMaxOperatingTemp = 37
Byte:0539:       SCTFanControlOverRangeTemp = 3C
Byte:053A:       SCTFanControlUnderRangeTemp = 0A
Byte:053B:       SCTFanControlMinOperatingTemp = 0E
Byte:053C:       SCTVendorFlags = 07 00
Byte:053C:           Bit:0, SCT_VENDORFLAGS_SEATOOLS = 1
Byte:053C:           Bit:1, SCT_VENDORFLAGS_WRITE_SAME = 1
Byte:053C:           Bit:2, SCT_VENDORFLAGS_CORRECTABLE_BIT = 1
Byte:053D:           Bit:7, SCT_VENDORFLAGS_DEBUG_MODE = 0
Byte:053E:       SCTTimerReadDefault = 00 00
Byte:0540:       SCTTimerWriteDefault = 00 00
Byte:0542:       SCTTenMsecCount = 00
Byte:0543:       SCTPerformanceFlags = 00
Byte:0544:       SCTTempDataTableSize = 00 00
Byte:0546:       SCTSamplingPeriod = 0A 00
Byte:0548:       SCTInterval = 3B 00
Byte:054A:       ATAPadSlewRate = 00
Byte:054B:       ATAIORDYPadControl = 00
Byte:054C:       PreampHotTweak = 00
Byte:054D:       PreampColdTweak = 00
Byte:054E:       LubeMitigationRetries = 00 00
Byte:0550:       LengthOfWriteSpaceToFlush = 00 00
Byte:0552:       LengthOfWriteCommandToTriggerFlush = 00 00
Byte:0554:       NDSLBAThresholdA = 00 00
Byte:0556:       NDSLBAThresholdB = 00 00
Byte:0558:       NDSPartitionDependencies = 00 00
Byte:055A:       NDSODOffsetConfig = 00
Byte:055B:       NDSIDOffsetConfig = 00
Byte:055C:       APMTimer1mSec = 10 27
Byte:055E:       APMTimer2mSec = 00 15
Byte:0560:       APMStandByTimer = 20 00
Byte:0562:       APMTimerForDither = 2C 01
Byte:0564:       ReadDelayMinimum = 00
Byte:0565:       WriteDelayMinimum = 00
Byte:0566:       WriteDelayIncremental = 00
Byte:0567:       ReadDelayIncremental = 00
Byte:0568:       FeatureFlags = 81 A0 00 28
Byte:0568:           Bit:0, WRITE_CONFIG_DATA_TO_FLASH = 1
Byte:0568:           Bit:1, SPINUP_WRITE_FAULT_THRESHOLDS_ENABLED = 0
Byte:0568:           Bit:2, IOEDC_CHECK_ENABLED = 0
Byte:0568:           Bit:3, IOEDC_ERROR_ENABLED = 0
Byte:0568:           Bit:4, DOWNLOAD_MICROCODE_FUTURE_USE_ONLY = 0
Byte:0568:           Bit:5, SUPPRESS_SERIAL_PORT_PRINTS = 0
Byte:0568:           Bit:6, DRQ_CLEAR_ON_PIO_READ_ERR_SUPPORTED = 0
Byte:0568:           Bit:7, OFFLINE_SEEK_AWAY = 1
Byte:0569:           Bit:0, DELAY_SLEEP_STANDBY_CMDCOMPLETE = 0
Byte:0569:           Bit:1, IDLE_IMMEDIATE_UNLOAD_EMERGENCY = 0
Byte:0569:           Bit:2, ENABLE_ALLOW_RAW_ERROR_RATE_UPDATE = 0
Byte:0569:           Bit:3, OP_SHOCK_DETECTION_ENABLED = 0
Byte:0569:           Bit:4, LOG99_CONTROL = 0
Byte:0569:           Bit:5, READ_WRITE_LONG_EXTENDED_ENABLED = 1
Byte:0569:           Bit:6, WRITE_REORDERING_DISABLED = 0
Byte:0569:           Bit:7, ALLOW_AAM_FEATURE_SET = 1
Byte:056A:           Bit:0, DATA_LOG_ENABLED = 0
Byte:056A:           Bit:1, HOST_STREAM_RECORD_FIRST_ERROR_BLOCK = 0
Byte:056A:           Bit:2, SAVE_ATA_COMMAND_HISTORY_TO_DISC = 0
Byte:056A:           Bit:3, EIB_ON_POWERUP = 0
Byte:056A:           Bit:4, LEFT_JUSTIFY_SERIAL_NUMBER = 0
Byte:056A:           Bit:5, SUN_MICRO_MODEL_NUMBER_UPDATE = 0
Byte:056A:           Bit:6, REVERTING_TO_POWER_ON_DEFAULTS_SUPPORTED = 0
Byte:056A:           Bit:7, RIGHT_JUSTIFY_FIRMWARE_REVISION = 0
Byte:056B:           Bit:0, SEGMENT_INITIALIZED = 0
Byte:056B:           Bit:1, DISPLAY_SMART_COMMANDS_ON_SERIAL_PORT_ENABLED = 0
Byte:056B:           Bit:2, DISABLE_SMART_AUTO_UPDATES = 0
Byte:056B:           Bit:3, DISABLE_LEGACY_READ_WRITE_LONG = 1
Byte:056B:           Bit:4, VERSION_ENFORCEMENT_SUPPORTED = 0
Byte:056B:           Bit:5, ENABLE_MICKEY_CERT = 1
Byte:056B:           Bit:6, RETAIN_AMPS_VALUE_ON_DOWNLOAD = 0
Byte:056C:       PerformanceFlags = 04 3F
Byte:056C:           Bit:0, REDUCED_RAW_TRANSITION_FLUSH = 0
Byte:056C:           Bit:1, REDUCED_AV_RETRIES = 0
Byte:056C:           Bit:2, ID_READ_PARAMETERS_FROM_CAP = 1
Byte:056C:           Bit:4, VJIT_DISABLED = 0
Byte:056C:           Bit:5, ZERO_LATENCY_RD_ENABLED = 0
Byte:056D:           Bit:0, DAR_ENABLED = 1
Byte:056D:           Bit:1, OFFLINE_SPARING_ENABLED = 1
Byte:056D:           Bit:2, JIT3 = 1
Byte:056D:           Bit:3, JIT2 = 1
Byte:056D:           Bit:4, JIT1 = 1
Byte:056D:           Bit:5, JIT0 = 1
Byte:056D:           Bit:6, DISABLE_IDLE_ACTIVITY = 0
Byte:056D:           Bit:7, ENABLE_SELF_SEEK = 0
Byte:056E:       AggressivelyScanThisManyTimes = 00 00
Byte:0570:       LongSeekEventTime = FF FF
Byte:0572:       SleepStandbyDelay = 00 00
Byte:0574:       CustomerUniques = 00 00 00 00
Byte:0578:       CustomerType = 00 00 00 00
Byte:057C:       AdditionalSATAFeatureConfig = 4B 00 00 00
Byte:057C:           Bit:0, SATA_FORCE_EARLY_STATUS = 1
Byte:057C:           Bit:1, SATA_EARLY_STATUS_FORCE_COMRESET = 1
Byte:057C:           Bit:2, SATA_INTRACOMMAND_PHY_MANAGEMENT_ENABLED = 0
Byte:057C:           Bit:3, SATA_ENABLE_PHY_PM_CALIBRATION = 1
Byte:057C:           Bit:4, SATA_ENABLE_SPI_VIS_MODE = 0
Byte:057C:           Bit:5, SATA_ENABLE_RERR_TESTING = 0
Byte:057C:           Bit:6, SATA_ENABLE_SSC = 1
Byte:057C:           Bit:7, SATA_EYE_DIAGRAM_TEST = 0
Byte:057D:           Bit:0, SATA_DISABLE_PRIMITIVE_SCRAMBLING = 0
Byte:057D:           Bit:1, SATA_ULTRA_AGGRESSIVE_INTER_COMMAND_PHY_SUPPORTED = 0
Byte:057D:           Bit:2, SATA_ULTRA_AGGRESSIVE_INTRA_COMMAND_PHY_SUPPORTED = 0
Byte:0580:       FactoryODScanMBytes = 00 00
Byte:0582:       FactoryIDScanMBytes = 00 00
Byte:0584:       MaxDSTSelfTestTime = 54 15
Byte:0586:       DSTShortTestTimeLimit = 3C 00
Byte:0588:       BootFlagsForROM = 0A 00
Byte:0588:           Bit:0, BOOT_FLAG_POWER_ON_IN_STANDBY = 0
Byte:0588:           Bit:1, BOOT_FLAG_PARTIAL_OOB = 1
Byte:0588:           Bit:2, USE_SMALL_ID_FORMAT = 0
Byte:0588:           Bit:3, LOW_CURRENT_SPINUP = 1
Byte:058A:       LastCongenWriteCaller = 00 00
Byte:058C:       HostStreamJumpSizeInSectors = 00 00
Byte:058E:       HostStreamTotalJumpSteps = 00
Byte:058F:       SerialDebugLevel = 00
Byte:0590:       DefaultStandbyTimer = 00
Byte:0591:       ATAInterSectorTime = 08
Byte:0592:       StandbyDelayBeforePostingStatus = 00 00
Byte:0594:       StandbyPostingStatusFlags = 04 00
Byte:0594:           Bit:0, ENABLE_WAIT_FOR_DRIVE_SPINDOWN_BEFORE_POSTING_STATUS_AFTER_STANDBY = 0
Byte:0594:           Bit:1, ENABLE_HEADS_ON_RAMP_BEFORE_POSTING_STATUS_AFTER_STANDBY = 0
Byte:0594:           Bit:2, ENABLE_DELAY_BEFORE_POSTING_STATUS_AFTER_STANDBY = 1
Byte:0597:       LTTCPowerOnHours = 0A
Byte:0598:       DebugAddress0 = 00 00 00 00
Byte:059C:       DebugValue0 = 00 00 00 00
Byte:05A0:       DebugAddress1 = 00 00 00 00
Byte:05A4:       DebugValue1 = 00 00 00 00
Byte:05A8:       MaxDSTUnrecoverableFailures = 00 00
Byte:05AA:       APMTimer3mSec = 00 20
Byte:05AC:       LongCompletionEventTime = FF FF
Byte:05AE:       EIB_DebugFlags = 00
Byte:05AE:           Bit:0, EIB_WRT_MSG_ENABLE = 0
Byte:05AE:           Bit:1, EIB_SWD_MSG_ENABLE = 0
Byte:05AE:           Bit:2, EIB_SIM_MSG_ENABLE = 0
Byte:05AE:           Bit:3, EIB_DEBUG_MSG_ENABLE = 0
Byte:05AF:       Expansion =
                 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F3 T>
PostPosted: December 10th, 2013, 1:11
I'm just a novice trying to understand and learn. Even with some abnormalities in the terminal log, since you can see data in HxD, this would imply that the drive is working to a certain degree. Could it be as simple as to make an image with a free program like ddrescue(or a hardware imager) and then use recovery software on the image?
PostPosted: December 10th, 2013, 1:42
It would be ideal, yes, but the drive isnt accesable in HxD anymore, and MHDD doesnt see it. I don't have a hardware imager and other tools arent picking up the drive. Seems to be detected, well the model at least, but not much else.
I'd love to be able to get an image, but I dont see it is possible at the moment :)
PostPosted: December 10th, 2013, 14:05
I am assuming,"this did not help", was referring to the commands to stop reallocation
Could the attempt at stopping reallocation made the drive worse?
PostPosted: December 11th, 2013, 5:36
Yes the commands to stop reallocation didn't help to bring the disk online.
I blame Spildit for this. I asked the questions and expected a 100% solution to get my data back for free. That is what this forum is for I thought. Its not good enough, there is a glitch in the matrix, MOM!!!!
Seriously though It was worth a shot. I guess it is time to give up on this one, thanks for everyones help and comments :)
PostPosted: December 11th, 2013, 9:34
I think Spildit's advice was good. I just wondered if for some unknown reason the commands made it worse. I based this on the observation that the drive was on line at some point, but around the time of attempting to disable reallocation, it appeared to get worse. I am sure it was probably just coincidence.
PostPosted: December 11th, 2013, 17:42
I was joking about Spildits advice, but, yes I agree it seemed to get worse. I just don't have the required knowledge to interpret all the details of the terminal output. I can't see that anything he advised could have made it worse, so I am thinking that whatever the actual issue is must be getting worse.
Can anyone tell me if the ConGen output has anything wrong in it?
PostPosted: December 11th, 2013, 18:19
AISI, the ConGen output is telling you that the following commands were inappropriate for your drive:
F01E4,00,22
F057C,043C,22
              UDSFastTrace Group
The following appear to be the correct parameters:
Did you specify the parameters by their byte addresses, or did you specify their ASCII names?
PostPosted: December 11th, 2013, 19:13
Thanks fzabkar, I was planning to read through the list and check those today, and yes, stupidly the Byte address. I have just read all the info posted and see your advice about using names not hard byte addresses.
So I think I should be able to redo the commands I did earler with the original values to reset back to what is was, then apply the correct ones afterwards.
PostPosted: December 11th, 2013, 20:31
I reset ConGen with F,,22, then the commands using the Flag names.
Terminal gives SATA Reset at a steady slow pace. Windows says "need to format disk". So looks like back to where we started.
PostPosted: December 11th, 2013, 21:11
I am able to access the disk with HxD and see sectors. Partition Find and mount sees a partition, and lets me Try to mount it. It tries, but after a while fails with "The Paremeter is incorrect" message.
I am about to try MHDD again now the drive is more accessable.
PostPosted: December 11th, 2013, 21:49
PF&M will be unable to mount the partition because the sector size of the file system (4KB or 2KB ?) doesn't match the sector size of the drive (512 bytes).
I would suggest that now is the time to view sectors 16384 or 8192. Alternatively, a search for special sector (NTFS boot sector) should be relatively quick. You will need this information if you hope to find a suitable enclosure.
PostPosted: December 11th, 2013, 22:03
So before I did that, I tried create image from in P.F.A.M.
It is 3,119,104KB into creating the image when It gets a read error. retry didnt work, so I click ignore. I don't know how many of these it will get, but I guess the quality of the image is yet to be seen. It has had 4 errors between there and 4GB(-edit- 14Gb) . at 1%, hoping the errors are located on a small portion of the disk.
Wish I had a hardware imager or better tools!
PostPosted: December 11th, 2013, 22:23
I am trying to understand in a very basic way what ConGen means and this process of the tutorial you are using. The whole tutorial is abit above my head
F3 T>F,,22 <-------this makes sense, enter the command
could you explain very basically what that means? Do you enter those flag names as commands? If you could, please dumb it down as much as possible.
thanks for any help
PostPosted: December 11th, 2013, 22:39
Hi, if you go to the link that spildit recomended me to on page 1, there is more detail there.
Basically, the way I understand it is that the congen parameters are shown by typing F at the F3 T> prompt. You can change them. Each byte is broken down to their individual bits and each Bit is a "flag"
for example, if, for example a parameter "ExamplePar" was 1 Byte, and made up of:
bit 0 = "readfast" = 0;
bit 1 = "writefast" = 1;
bit 2 = "DoTheHokeypokey" = 0;
bit 3 = "TerminalOn" = 0;
bit 4 = "driveInSlowMo" = 1"
bit 5 = "RandomiseData" = 0;
bit 6 = "frustrateDIYers" = 1;
bit 7 = "techMode" = 0;
Then the Byte would be 0x52 (01010010b) and to change the readfast mode to "on" you would write 0x53 to the memory location of the parameter.
This is a totally made up example explaining the gist of how I see it..
good luck, i may be wrong but a discussion around it would be great
Users browsing this forum: Google [Bot] and 54 guests
