 Post subject: Re: Seagate ST2000DL003 stays busy
PostPosted: May 19th, 2014, 14:46
waqas_ali766 wrote:
After use of m0,2,2,,,,,22 command always use clear smart, other wise all sector goes inaccessible.
If terminal shows this error (ProcessRWError -Read- at LBA 00F8C514 Sense Code=C4090082) then not worry about that, it is auto relocation system by firmware.
if you have any cloning tools like pc3000 and MRT try to disable smart option and try to clone the hdd with OK heads.
Thank You again Ali!
I did everything that you said, but the drive does not read any sectors :roll: :
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max Iterations = 01, Max Certify Rewrite Retries = 29EC
User Partition Format 3% complete, Zone 00, Pass 00, LBA 0002C712, ErrCode 00000080, Elapsed Time 0 mins 30 secs
User Partition Format Successful - Elapsed Time 0 mins 30 secs
Zone re-format was skipped.
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>/2
F3 2>Z
Spin Down Complete
Elapsed Time 14.516 secs
F3 2>
Rst 0x40M
MC Internal LPC Process
FAIL Op=0165 Resp=0005
FAIL Op=0055 Resp=0005
FAIL Op=0065 Resp=0005
FAIL Op=0600 Resp=0005
(P) SATA Reset
User Data Base 00991198
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A58C 4011869C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0000002F
[RSRS] 0003
Starting LBA of RW Request=000001A4 Length=000004EC
ProcessRWError -Read- at LBA 000001EB Sense Code=43110081
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
ErrorSegmentOffset = 0238
Continuing after error
Reconstruction: Completed 0: MCMT Was Valid, HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00005141
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00005141
MCMainPOR: Feature Enabled...
FAIL Op=0555 Resp=0005
ASCII Diag mode
F3 T>F00A2,00,22
(D) SATA Reset
F3 T>F014E,00,22
(D) SATA Reset
F3 T>F057C,043C,22
(D) SATA Reset
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 14.518 secs
F3 2>
Rst 0x40M
FAIL Op=0900 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000030
[RSRS] 0003
[MCMTWS]
Starting LBA of RW Request=00132233 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00132233 Sense Code=43110081
FAIL Op=045B Resp=0005
FAIL Op=055B Resp=0005
PostPosted: May 19th, 2014, 15:35
Spildit wrote:
waqas_ali766 wrote:
Now if your drive access firmware and not gives access to user area , follow this
m0,2,2,,,,,22
/1
N1
power reset
/t
F00A2,00,22
F014E,00,22
F057C,043C,22
power reset
these three commands are used to disable smart and auto relocation.
now all sectors Access easily..
Software is just a plate form to diagnose a hard disk. main thing is your mind which give you idea to perform several tricks to repair hdd.
Waqas Ali
http://www.sediv.net
Very VERY BAD idea to do on a seagate drive that is more recent then 7200.11
m0,2,2,,,,,22 "regen translator" without taking intro consideration the non-resident G list, and you will end up without LBA access or partial LBA access only and you will need PC3K to fix it with the "Fork" method or the salvation data tool.
And your congen command is wrong as well. Its F01E4,00,22 and NOT F014E,00,22
Thanks Spildit!
What about Leonardo Method? http://malthus.zapto.org/viewtopic.php?f=6&t=196
PostPosted: May 19th, 2014, 15:49
No, I can't access to any sector.
Every sector access came back with "ProcessRWError -Read- at LBA XXXXXXXX Sense Code=43110081" (EDAC HW uncorrectable error) error, no matter wich is the direction that i would like to imaging the drive.
Users browsing this forum: ccc and 166 guests
cron
