May 22nd, 2015, 14:43
fzabkar wrote:andy17d wrote:I'll check diodes but i think that if diodes would be damaged, the computer would not be turned on.
That depends on whether the corresponding resistor is closed or open. WD's drives have an amazingly stupid design.
Catastrophic failures in Western Digital PCBs:
http://www.hddoracle.com/viewtopic.php? ... 119&p=5033
May 27th, 2015, 4:58
May 27th, 2015, 8:25
Spildit wrote:Maybe because of ROM ...
You need to adapt the ROM to work with the drive.
May 27th, 2015, 12:05
Spildit wrote:Does the drive clicks or does it makes normal noise ?
May 27th, 2015, 17:32
Spildit wrote: in any case the sollution is the same, DUMP ROM with firmware tools, check format and rebuild ROM using info on SA with specialized firmware tools.
May 27th, 2015, 17:33
Spildit wrote:Are you willing to pay to get your data recovered ? Are you willing to ship the drive ?
May 30th, 2015, 5:18
Spildit wrote:You can try to use WDR DEMO to read/write ROM
June 1st, 2015, 10:00
Spildit wrote:Download modules from the drive with SeDiv DEMO.
Then you have to find correct Modules (SA) that you download with SeDiv (the ones with the adaptives - copy of Rom modules) and PATCH your ROM file with the correct info on SA to re-build original ROMThen you write that to the PCB and you will hopefully have original ROM
June 1st, 2015, 10:28
June 1st, 2015, 10:56
June 1st, 2015, 19:00
Mikippp wrote:Hi,
Search this PCB:
2060-701494-001
2060-701494-002
*You can ignore the drive model and capacity
Mikippp
June 1st, 2015, 19:48
andy17d wrote:I have done this and received a folder with multiple *.bin files
June 2nd, 2015, 6:14
fzabkar wrote:andy17d wrote:I have done this and received a folder with multiple *.bin files
IIUC, you are working with the donor PCB on the donor drive, and your resource dump contains the ROM and SA modules of the donor, not the patient. Am I correct, or have you managed to dump the patient's SA modules?
June 2nd, 2015, 10:39
June 5th, 2015, 16:59
Spildit wrote:Time to ship the drive to someone who can recover it ?
June 18th, 2015, 10:38
