Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: [b]Seagate Barracuda ST3000DM001 3TB Recovery question[/
PostPosted: February 1st, 2016, 13:10
Enjoycie,
We do not work with hard drives previously opened, deftrue is a good choice.
PostPosted: October 19th, 2016, 7:05
The second "BIOS" (3) is a "FETKEY". It is part of the -5V supply for the preamp. It is not a "BIOS", and it does not need to be swapped. Where did you see this disinformation?
Also, you don't need to transfer TVS diodes. The drive will run without them, albeit without overvoltage protection.
The typical result of an overvoltage from a 19V laptop adapter is a shorted 12V TVS diode and open circuited zero-ohm resistors.
Here is a similar PCB:
http://www.users.on.net/~fzabkar/HDD/ST ... 01_TVS.jpg
Here is your PCB:
Do you have a multimeter? If so, we could take some measurements of your original PCB. You don't need to return the "BIOS" to this PCB for these tests.
Thx,
this post was very helpfull for me :-)
Users browsing this forum: No registered users and 87 guests
