Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: New WD 3TB 2.5" Passport
PostPosted: March 22nd, 2016, 10:57
Amarbir[CDR-Labs] wrote:
Respected Jon ,
Anything In Between The Heads For Separation [ Like Pill Foil ] Etc Would Do And Once PCB Connector Of The HSA is Out I am Sure Its a Easy Job .Lately We Have Started To See Many 10 Head Drives in HDDguru in 3.5" Form Factor And Also Now 2.5" Form Factor .Is it even Fatter Then the 2TB's They Are Selling Sir
Namaste Amarbir:
While it's certainly possible (as we have done it), I wouldn't go so far as to classify it as "easy." There is no way I could have done it if I hadn't had head swap experience leading to it.
When you casually say stuff is "a easy job", you encourage people who have no business to open their drives in their kitchens and garages, leaving the mess for others to clean up (when it can be done).
Cheers & best,
Jono
http://www.datasaversllc.com
PostPosted: March 22nd, 2016, 11:02
Doomer Sir ,
Have You Tried This Yourself .As Far As I am concerned Its a Matter of 5 Minutes To Trace the Traces of SATA From MCU .
I haven't tried this personally but I know that those two model are both from Pebble beach family, so essentially they are the same drive with the same firmware . Based on previous experience they will be compatible
PostPosted: April 11th, 2016, 12:53
I've got this far, but nothing coming through on the SATA end. I need to check everything again, or just get a compatible PCB now that I see they're available.
Data Recovery Cape Town
PostPosted: April 11th, 2016, 13:09
The wires are too long
PostPosted: April 11th, 2016, 14:12
BTW have you tried using USB/COM utility ?
PostPosted: April 11th, 2016, 15:12
Did you remove the capacitors?
It's hard to tell from the photo, but ISTM that one pair of wires may be crossed.
PostPosted: April 11th, 2016, 17:16
Caps have been removed. I think Doomer is right, wires are too long and/or thick. Going to rather source a SATA board.
PostPosted: April 11th, 2016, 17:21
Can you tell us which wire goes where? It still doesn't look right to me.
PostPosted: April 11th, 2016, 19:12
Is Your SATA Cable Slowing Down Your Data Transfers? Max PC Investigates:
http://web.archive.org/web/201111161606 ... vestigates
During our testing, we also tested out a couple of often not recommended practices: bending your SATA cable at right angles. Many motherboard vendors recommend against putting right-angles into the cables during system builds so we took a cable and put about 15 right-angle kinks in it: no difference. We also took a 36-inch cable and tightly wrapped around a hot PSU cable: no difference.
What about joining two 36-inch cables end-to-end using male-to-male connectors 36-inch cables end-to-end using male-to-male connectors? That’s about 30-inches outside the SATA spec for cable length: No. Frakking. Difference. The only thing that stopped SATA dead in its tracks was running three 36-inch SATA cables end-to-end using cable No. 3, No. 4 and No 11. That’s nine feet of cables kids.
PostPosted: April 11th, 2016, 19:26
There is quite a difference, IMHO, between shielded cable and unshielded wires with SATA.
PostPosted: April 11th, 2016, 20:09
That wasn't a question, that was a fact.
I'm not trying to theorize based on some articles, I know this for a fact.
I did similar soldering, first hand.
And I can see from the picture that the wires are too long for this model.
I know this because I was able to get successful results with shorter wires.
PostPosted: April 11th, 2016, 21:03
Hey guys,
I got some pictures back from Maxim at ACE Laboratory Support team with more information on this new PCB. Too big to post here so I'll just provide the links Ace gave me (with their permission).
http://i.imgur.com/oInA35B.jpg
http://i.imgur.com/N9fhAa5.jpg
http://i.imgur.com/giypSg8.jpg
Hope this helps,
Brian
PostPosted: April 11th, 2016, 23:23
Me too.
PostPosted: April 12th, 2016, 16:07
The only "fact" your experiments prove, if anything, is that a short mess has a better chance of working than a long mess. The problem is in the shoddy workmanship, not the length of the cable per se. The SATA standard allows for cable lengths of 1m. The magazine article demonstrates that 1.8m lengths will still work reliably.
The fact that your setup works at all is due to the resilience of the SATA hardware, ie luck. To understand why your work is a mess you need to understand the concepts of "transmission line", "characteristic impedance", and "signal reflection". It is not sufficient to simply connect a wire from point to point.
IMHO the best and most logical approach would be to chop the end off a SATA cable and pare back the individual wires. I would also connect each of the grounds to the PCB. These ground wires eliminate or reduce crosstalk between the Tx and Rx signals. An alternative method would be to use ribbon cable, but that would be a crapshoot also.
PostPosted: April 12th, 2016, 16:18
I'm not sure why we are even arguing about this.
PostPosted: April 12th, 2016, 16:23
Maybe it's because you don't understand the importance of the concepts of "transmission line", "characteristic impedance", and "signal reflection".
PostPosted: April 12th, 2016, 16:29
exactly
And since soldering single wires gets much different results than creating perfectly shielded and aligned connection as it is inside SATA cable I see no point posting articles about SATA CABLES here, trying to justify "long mess", as you were trying to do.
IMHO
The best approach would be to use SATA PCB
The fast approach is to use short wires
Your approach pursues theoretical clarity in which nobody has interest, except yourself.
That's why some people just go and do stuff and some people tell other people how they would do it if they would have time/skills/parts/knowledge and a million other things.
PostPosted: April 12th, 2016, 16:49
That's the problem when programmers pretend to be engineers. As for quick solutions, it doesn't take much time to do things right. After you're done, just add the cable to your toolbox for next time.
PostPosted: April 12th, 2016, 16:53
Says a guy who have never even tried it
PostPosted: April 12th, 2016, 17:10
Actually, I do.
It must be very satisfying to sit in front of your computer and make all kinds of theoretical pronouncements that have no basis in experience, and premature judgements that are off the mark. Maybe with a bit more presumption & arrogance, I could try it myself?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 47 guests
