Re: Toshiba 500GB out of DVR Locked
September 19th, 2016, 12:55
ROM.rar [404 Bytes]
Downloaded 1 time
similar to access terminal blocked
You do not want to sell this locked-HDD?
September 20th, 2016, 2:46
I don't have any external programmers. If you'd be kind to recommend me a good one + software, I will get one and dump the ROM from a locked one. Unfortunately, I don't have many drives of this kind (only 2 left) as the rest of them left with the batch. DAMN ! The unlocked drive I had was from a long time ago ( I think a few months ) and I don't have anymore of these unlocked drives. Back then I was a real noob and didn't bother with those Toshiba. But yeah, you can write/read/erase them, user LBA is no problem, I only wanted to unlocked them since it seemed like a nice challenge. I'd lost my will when I saw that I couldn't edit anything there, but I found these 2 old locked ones and began researching again. I don't there's a way to sell the locked one, after all I am just an employee here, but I can try to talk and see if it can be done. So the dumping of the ROM of a locked drive with the external programmer - that is kinda the only thing I can do right now. Only useful thing from the above attachments would be the RAM, IIRC it contains an altered ROM image.
September 22nd, 2016, 9:08
I'm not that technical guys but I do have ROM programmer I got with my MRT, I guess the ROM is the one marked in red? If the process involves soldering it will not be worthy to deal with the unlocking of these drives...
September 26th, 2016, 19:16
Hi all !, I managed to unlock the Toshiba MK5055GSX Firmware ver. FG001M
User Password was forgotten, Security - Maximum, Master Password unchanged.
Here's the solution that helped me !
I have created the dos bootable usb and copied onto atapwd.exe and zu.exe programs.
Next I've run the atapwd.exe and issued the command SECURITY ERASE PREPARE and exit the program.
Next run the zu.exe with zu /s in my case and Bam !!! hdd unlocked !! :)
Hopefully this will help someone ;)
September 29th, 2016, 17:27
is it possible to unlock such drives with reading the rom and modify it?
September 30th, 2016, 1:23
I'm still on hold to a programmer coming, but I've gotten my hands on another Toshiba from the MQ01ABD family, the V series for desktop. I'm uploading the ROM and stuff out of it, maybe we could understand it's internal workings. However, from a glance, I have to say that it's ...different from the ROM's of other brands. Also, trying to read the service tracks yields in errors over errors, I guess there are only some specific tracks that are available/used in the PC3K utility. I'm gonna check out which one's are and try to get them again to get a glimpse on how they are. I am pretty sure the ROM of the locked one's (either 250,320 or 500 GB) is almost exactly the same as this one.
000000-07FFFF.rar
ROM read through terminal.
(284.11 KiB) Downloaded 1311 times
000000-000FFF.rar
RAM read through terminal.
(3.04 KiB) Downloaded 1406 times
SABackup.rar
The CP's and G-List.
(14.98 KiB) Downloaded 1368 times
September 30th, 2016, 7:52
Spildit wrote:
zenelli wrote:is it possible to unlock such drives with reading the rom and modify it?
Maybe ... We would still need to discover how. But the first step would be that- Read ROM and extract it's CPs. Then compare with ROM from unlocked drive.
well i have taking out the chip and read with my programmer, maybe someone can tell me more.
it is an MK5061GSY TOSHIBA
toshiba.rar
(274.31 KiB) Downloaded 1243 times
September 30th, 2016, 19:56
Here are the CPs I extracted from zenelli's ROM:
MK5061GSY_ROM_CPs.rar
(23.15 KiB) Downloaded 1167 times
October 1st, 2016, 8:36
fzabkar wrote:Here are the CPs I extracted from zenelli's ROM:
I'm not an expert so i dont know where to look for the password
October 4th, 2016, 2:52
Does anyone have any idea what this might refer to ?
" 512KB 12V BTIN_ROM UART Program Loader..for Gibson1.0 model Loader Version AUGB14064.00 "
October 24th, 2016, 7:44
Okay, so I've managed to get a read on a locked ROM by the use of a programmer. Here it is. So far, the differences between it and a normal ROM are MANY. I'm also uploading the ROM of a MQ01ABD of 320 GB, yet do bear in mind that it's firmware is AX01, not AZ01Q like the locked one's. At a close analysis, it crushed any hope to figure out how it's locked, due to the huge number of differences ( more than 30k ), yet I can point out several locations that seemed "suspect" :
at 0x30800 we have smth called scrt_flag;
at 0x54A60 several flags indicating different options appear to be set ( eg hdd is frozen, security locked ).
Before anything, I'll try to understand a bit more about it's internal workings, since there are many descriptions inside available (btw, the omnipresent japanese wording is there).
000000-07FFFF(unlocked AX).rar
(284.11 KiB) Downloaded 1268 times
newlockedrom.rar
(283.13 KiB) Downloaded 1481 times
October 24th, 2016, 19:22
The newlockedrom.bin dump appears to be from the 320GB HDD whereas the 000000-07FFFF(unlocked AX) dump is from the 500GB HDD. Is this correct?
newlockedrom.bin
0007AFE0  4D 4E 20 20 20 20 20 20 20 20 20 20 20 20 20 20  MN
0007AFF0  20 20 20 20 20 58 34 37 58 54 58 30 43 54 54 4F       X47XTX0CTTO
0007B000  53 48 49 42 41 20 4D 51 30 31 41 42 44 30 33 32  SHIBA MQ01ABD032
0007B010  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0007B020  20 20 20 20 20 20 00 00 00 00 00 00 00 00 00 00
000000-07FFFF.bin
0007AFF0  20 20 20 20 20 32 35 4A 41 50 31 57 48 54 54 4F       25JAP1WHTTO
0007B000  53 48 49 42 41 20 4D 51 30 31 41 42 44 30 35 30  SHIBA MQ01ABD050
0007B010  56 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20  V
October 24th, 2016, 19:59
FWIW, this is my take on the situation.
Each ROM has a table of CPs. The two tables are identical.
newlockedrom.bin
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13
0005BCE8                                      AA 00 54 4F 00 00 00 00              ª.TO....
0005BCFC  D0 8A 05 D0 A0 03 A0 03 90 03 01 00 34 00 52 43 00 00 00 00  Њ.Р. .....4.RC....
0005BD10  40 8A 05 D0 70 00 70 00 6E 00 01 00 33 00 57 43 00 00 00 00  @Š.Ðp.p.n...3.WC....
0005BD24  D0 32 0A D0 50 0E 50 0E 4E 0E 01 00 99 00 4D 4F 00 00 00 00  Ð2.ÐP.P.N...™.MO....
0005BD38  70 8E 05 D0 10 00 00 00 00 00 00 00 44 00 53 47 00 00 00 00  pŽ.Ð........D.SG....
0005BD4C  80 8E 05 D0 30 00 30 00 2E 00 01 00 92 00 43 4F 00 00 00 00  €Ž.Ð0.0.....’.CO....
0005BD60  B0 8E 05 D0 10 00 10 00 0C 00 01 00 C1 00 47 4F 00 00 00 00  °Ž.Ð........Á.GO....
0005BD74  C0 8E 05 D0 10 00 10 00 02 00 01 00 95 00 48 54 00 00 00 00  ÀŽ.Ð........•.HT....
0005BD88  D0 8E 05 D0 10 00 10 00 0C 00 01 00 55 00 4D 4E 00 00 00 00  ÐŽ.Ð........U.MN....
0005BD9C  E0 8E 05 D0 C0 00 40 00 00 00 01 00 56 00 4D 4E 00 00 00 00  àŽ.ÐÀ.@.....V.MN....
0005C6FC  D0 D1 05 D0 10 00 10 00 0E 00 01 00 0A 01 56 46 00 00 00 00  ÐÑ.Ð..........VF....
0005C710  D0 2F 0B D0 E0 0F E0 0F DE 0F 01 00 0B 01 45 44 00 00 00 00  Ð/.Ðà.à.Þ.....ED....
0005C724  00 5B 05 D0 00 18 00 18 FE 17 01 00 83 00 00 00 53 48 00 00  .[.Ð....þ...ƒ...SH..
0005C738  E0 8F 05 D0 20 00 20 00 18 00 00 00 53 5A 00 00 00 90 05 D0  à..Ð . .....SZ.....Ð
0005C74C  D0 00 D0 00 C6 00 00 00 48 50 00 00 D0 90 05 D0 10 00 10 00  Ð.Ð.Æ...HP..Ð..Ð....
0005C760  0C 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ....................
000000-07FFFF.bin
0005BD9C                          AA 00 54 4F 00 00 00 00 D0 8A 05 D0          ª.TO....Њ.Ð
0005BDB0  A0 03 A0 03 90 03 01 00 34 00 52 43 00 00 00 00 40 8A 05 D0   . .....4.RC....@Š.Ð
0005BDC4  70 00 70 00 6E 00 01 00 33 00 57 43 00 00 00 00 D0 32 0A D0  p.p.n...3.WC....Ð2.Ð
0005BDD8  50 0E 50 0E 4E 0E 01 00 99 00 4D 4F 00 00 00 00 70 8E 05 D0  P.P.N...™.MO....pŽ.Ð
0005BDEC  10 00 00 00 00 00 00 00 44 00 53 47 00 00 00 00 80 8E 05 D0  ........D.SG....€Ž.Ð
0005BE00  30 00 30 00 2E 00 01 00 92 00 43 4F 00 00 00 00 B0 8E 05 D0  0.0.....’.CO....°Ž.Ð
0005BE14  10 00 10 00 0C 00 01 00 C1 00 47 4F 00 00 00 00 C0 8E 05 D0  ........Á.GO....ÀŽ.Ð
0005BE28  10 00 10 00 02 00 01 00 95 00 48 54 00 00 00 00 D0 8E 05 D0  ........•.HT....ÐŽ.Ð
0005BE3C  10 00 10 00 0C 00 01 00 55 00 4D 4E 00 00 00 00 E0 8E 05 D0  ........U.MN....àŽ.Ð
0005BE50  C0 00 40 00 00 00 01 00 56 00 4D 4E 00 00 00 00 E0 8E 05 D0  À.@.....V.MN....àŽ.Ð
0005C7B0  10 00 10 00 0E 00 01 00 0A 01 56 46 00 00 00 00 D0 2F 0B D0  ..........VF....Ð/.Ð
0005C7C4  E0 0F E0 0F DE 0F 01 00 0B 01 45 44 00 00 00 00 00 5B 05 D0  à.à.Þ.....ED.....[.Ð
0005C7D8  00 18 00 18 FE 17 01 00 83 00 00 00 53 48 00 00 E0 8F 05 D0  ....þ...ƒ...SH..à..Ð
0005C7EC  20 00 20 00 18 00 00 00 53 5A 00 00 00 90 05 D0 D0 00 D0 00   . .....SZ.....ÐÐ.Ð.
0005C800  C6 00 00 00 48 50 00 00 D0 90 05 D0 10 00 10 00 0C 00 00 00  Æ...HP..Ð..Ð........
0005C814  03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ....................
The CPs in both ROMs are located at 0x79400.
newlockedrom.bin
00079400  54 4F 06 0A B3 EC 06 0A B3 EC 00 00 DC EC 00 00 DC EC 36 03  TO..³ì..³ì..Üì..Üì6.
00079414  2A F9 36 03 2A F9 36 03 2A F9 36 03 2A F9 36 03 2A F9 36 03  *ù6.*ù6.*ù6.*ù6.*ù6.
00079428  2A F9 36 03 2A F9 36 03 2A F9 00 00 00 00 00 00 00 00 00 00  *ù6.*ù6.*ù..........
0007943C  00 00 00 1B 43 53 01 00 A0 00 50 00 00 00 00 00 00 00 00 E1  ....CS.. .P........á
00079450  43 53 01 00 A0 00 50 00 00 00 00 00 00 00 00 E1 43 53 00 00  CS.. .P........áCS..
00079464  00 00 00 00 00 00 00 00 00 00 00 94 43 53 00 00 00 00 00 00  ...........”CS......
000000-07FFFF.bin
00079400  54 4F 65 05 42 EC 65 05 42 EC 00 00 FC EC 00 00 FC EC 36 03  TOe.Bìe.Bì..üì..üì6.
ISTM that it may be worth trying to patch the locked drive's CPs (addresses 0x79400 - 0x7FFFF) into an unlocked ROM. Each CP has its own XOR8 checksum. However, I don't know if there are any additional checksums. If other checksums do exist, then hopefully the patch will not invalidate them. Also, the patch assumes that the lock is not contained within a CP. If it is, then hopefully the unlocked ROM code will ignore this lock. One additional question is whether the ROM firmware needs to match the SA firmware in some way.
October 25th, 2016, 1:23
Yes, the second dump is from a 500 GB HDD. So for now, I should just attempt to patch the locked CPs into the unlocked ROM. Actually, I think if the lock is located within a CP that would be great, as we can just extract the CPs from both ROMs and then compare them and see exactly in which CP the lock is located. Otherwise, I assume the lock is located above the CP table and that would be...not so great. Regarding the ROM firmware needing to match the SA firmware...I somehow doubt it has to, but it's just a hunch.
October 25th, 2016, 1:27
Another thing worth trying would be to take the CPs from the unlocked one and patch them to a locked ROM...and if it would unlock it, then I guess we can be pretty sure where the lock is. Though I do have to ask, don't these CPs contain data essential to each HDD ? Moving them around from one another seems like a stretch.
October 25th, 2016, 14:32
My CP extraction tool assumes that the CPs are located at 0x70000. When I wrote it I didn't have many ROM examples to work with, so I didn't know what differences I would encounter. I'll try to update it when I can.
October 25th, 2016, 23:05
I have extracted the CPs from each ROM.
The first CP is actually CP 0x010B ("ED") at offset 0x77C00. Sorry for my error.
MQ01ABD032.rar
(19.53 KiB) Downloaded 1258 times
MQ01ABD050V.rar
(21.21 KiB) Downloaded 1301 times
October 26th, 2016, 3:34
Those tables are not complete. They are contains some standard command set.
October 26th, 2016, 5:13
Martin wrote:
fzabkar wrote:Each ROM has a table of CPs. The two tables are identical.
I don't understand. I count 134 CPs in total in each table. Are you saying that there are more?
October 26th, 2016, 16:43
These empty CPs (PP, WV, PQ) are not in the table. I haven't checked for others.
0007F2E0  50 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00  PP..............
0007F2F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0007F300  57 56 00 00 00 00 00 00 00 00 00 00 00 00 00 00  WV..............
0007F310  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01  ................
0007F320  50 51 FF FF FF FF FF FF FF FF FF FF FF FF FF FF  PQÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F330  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F340  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F350  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F360  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F370  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F380  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0007F390  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 79  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿy
There are several CPs (DB -> VF) in the table that don't appear to be in the ROM.
ID     Name  Dword2     Rel/Abs Address  Byt11  Size (ROM/SA/size3)   Byt18  Byt19  XOR8
0109   SX    00000000   05D1D0 / 07F2D0    D0   0010 / 0010 / 000E    01     00     00
- the following empty (?) CPs are not in the table
       PP                        7F2E0          0020
       WV                        7F300          0020
       PQ                        7F320          0080 ?
- the following CPs are in the table but not in ROM ???
00F8   DB    00000000   09F010 / 0C1110    D0   1C90 / 1C90 / 1C8E    01     00     00
00FC   AM    00000000   0A0CA0 / 0C2DA0    D0   0990 / 0990 / 098E    01     00     00
00BF   OU    00000000   0A1630 / 0C3730    D0   0E50 / 0E50 / 0E4E    01     00     00
00C9   OV    00000000   0A2480 / 0C4580    D0   0E50 / 0E50 / 0E4E    01     00     00
0033   WC    00000000   0A32D0 / 0C53D0    D0   0E50 / 0E50 / 0E4E    01     00     00
0230   CA    00000000   0A4120 / 0C6220    D0   1630 / 1630 / 162E    01     00     00
0231   CB    00000000   0A5750 / 0C7850    D0   1630 / 1630 / 162E    01     00     00
0232   CC    00000000   0A6D80 / 0C8E80    D0   1630 / 1630 / 162E    01     00     00
0233   CD    00000000   0A83B0 / 0CA4B0    D0   1630 / 1630 / 162E    01     00     00
0234   CE    00000000   0A99E0 / 0CBAE0    D0   1630 / 1630 / 162E    01     00     00
0235   CF    00000000   0AB010 / 0CD110    D0   1630 / 1630 / 162E    01     00     00
00D3   ZH    00000000   0AC640 / 0CE740    D0   6760 / 6760 / 675E    01     00     00
00F7   FC    00000000   0B2DA0 / 0D4EA0    D0   01A0 / 01A0 / 019E    01     00     00
00F4   WD    00000000   0B2F40 / 0D5040    D0   0090 / 0090 / 008E    01     00     00
010A   VF    00000000   0B2FD0 / 0D50D0    D0   0FE0 / 0FE0 / 0FDE    01     00     00
