Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Hitachi ATA password
PostPosted: June 3rd, 2017, 18:02
helpless wrote:
How this happens? When zu tells you "POWER OFF / ON AND EXECUTE ZU AGAIN" you re-power your drive with the PCB on, run the same command, but instead of "UNLOCK DONE" it tells you the same "POWER OFF / ON AND EXECUTE ZU AGAIN" message again.
All is true. It should be :shock:
Edits to nvram. A message ("POWER OFF / ON AND EXECUTE ZU AGAIN") is displayed. Need a restart
Spin up, calculates S/ON (and does not work on tables),edit security, edit nvram.
Again displays a message and again needs to restart.
In 2013 I did not know how to perform a restart drive without turning off the power of the drive
Is there any progress on it?
no. I will do when there is a desire and time.
What version do you use?
And it was not the first time zu did this - I have a bunch of Hitachi drives that zu has made a paperweight of.
Just do not use it.
PostPosted: June 3rd, 2017, 19:43
helpless
L9 on the table was not found, here is the log for K9
      Model: Hitachi HTS542525K9SA00
Firmware: BBFOC39P
   Serial: 080705BB3F00WDJP34BG
Disk size: 488397168 LBAs             238475 Mb
      CHS: 16383/16/63                8063 Mb
    SMART: Enabled, Errlog, Selftest
    CACHE: 7229k; L/A=ON; Wr=ON;      ok
  Support: LBA, HPA, AAM, APM, DLM, DMAUDMA-6
  AAM val: 254                        Maximum
  APM val: 128                        Minimum
    Erase: ~106 minutes
Security: ON, Max, Locked                                              <------------
    ATA-8: SATA1, NCQ, PEC, SCT, WrUnk
c:\_dumps>zu /a
BBFOC39PHitachi HTS542525K9SA00
NOT SUPPORTED
c:\_dumps>zu /a.
HDD=HGST/IBM
POWER OFF/ON AND EXECUTE ZU AGAIN
c:\_dumps>zu /a.
HDD=HGST/IBM
POWER OFF/ON
UNLOCK DONE
c:\_dumps>zu /a
NO PWD.BYE!
c:\_dumps>
PostPosted: June 4th, 2017, 7:35
August 2, 2013. Is there a newer version out?
You need to restart twice and after each restart execute zu?
Does it make any difference if the model number ends with L9SA60 or L9SA00 ?
PostPosted: May 25th, 2020, 12:40
Hi everyone,
Is Moltke still around ? I want to report dat Zu_beta_fix_2013 is also not working with HTS7250505A7E630.
if I do zu /p. it says IBM/ARM not supported.
if I do zo /p8 it says : Model HTS7250505A7E630 is not supported.
PostPosted: May 26th, 2020, 5:06
HTS7250505A7E630 should be HTS725050A7E630.
PostPosted: May 26th, 2020, 6:10
maybe offtopic but still good to know: Is Moltke still active, I read on some forums that he was banned/left by him self. And in some older posts there is Mr Zhong, that he was an expert on Zu. And he was banned. What is the story ? and contacting whom would give higher chance of an answer ?
PostPosted: May 26th, 2020, 6:20
Eugene names change like gloves. )
now he is - tametung
http://forum.ru-board.com/topic.cgi?for ... tart=600#6
PostPosted: May 26th, 2020, 7:25
ok, thanks. I ll see if can find some info there.
PostPosted: January 17th, 2023, 5:49
my Hitachi HDD is also locked so please can anyone provide me a better solution to how unlocked my Hitachi HDD and i get my old data.
Users browsing this forum: No registered users and 271 guests
