Re: Rosewood
August 31st, 2017, 10:15
Try with this (if you have the last software version) http://ts.acelaboratory.com/index.php?/ ... ood-drives
Re: Rosewood
August 31st, 2017, 10:41
Ys last version!
Re: Rosewood
August 31st, 2017, 12:16
No offense. I would tell the customer that you can use paperweights, it is the best utility you can find for this scrap.
It is not firmware problem, the surfaces are made of butter, there is not much expectation in most cases.
All laboratories are full of these "recent" units ..... for something will be
Re: Rosewood
August 31st, 2017, 13:58
colanco wrote: the surfaces are made of butter
LOL!!! :lol:
Re: Rosewood
August 31st, 2017, 17:06
MindMergepk wrote:
there is a way to write sysfiles with pc3k to these drives. :idea:
of course there is...
Re: Rosewood
September 1st, 2017, 13:54
Amarbir[CDR-Labs] wrote:
MindMergepk wrote:
pepe wrote:these drives are lacking the command to write sysfiles, so don't expect too much from pc3k.
Ts Support Ace no solution in case!!!!
Is that so i Need To Ask TS Support From Ace again Is This is The Case
Re: Rosewood
September 1st, 2017, 16:09
Do these commands work?
    F"READ_SPARING_ENABLED",0,22
    F"WRITE_SPARING_ENABLED",0,22
    F"OFFLINE_SPARING_ENABLED",0,22
    F"DAR_ENABLED",0,22
    F"DISABLE_IDLE_ACTIVITY",1,22
    F"BGMS_DISABLE_DATA_REFRESH",1,22
    F"ABORT_PREFETCH",1,22
    F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
    F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
    F"MediaCacheControl",00,22
