 Post subject: HELP on samsung HD103SI
PostPosted: November 29th, 2018, 7:46
,,i has clear G-List and Glist-50,,on SRT ..
the Drive is now frozen,, to fix now need merg G to P? how do it?
WARNING : - Clearing the A-List will make you loose all the data present on the "spare" sectors. This means that for example if during the normal use of the drive "x" sectors were considered "bad" by the drive and swapped by a spare that now have valid data when one issues the "Clear A-List" command the data on those "x" sectors will no longer be accessible !!!
 Post subject: Re: HELP on samsung HD103SI
PostPosted: November 29th, 2018, 18:18
If you want to recover data, never modify the P-LIST.
Adding GList to PList would be useful to repair the HDD but you would lose all the data.
If you delete GList you will lose the sectors that have been relocated.
If you lose the PLIST in principle you have lost everything.
Make a backup of the entire SA, always before starting to manipulate the SA.
If I am wrong in something please rectify. Thank you.
PostPosted: November 29th, 2018, 18:34
AIUI, the OP is not interested in the data.
PostPosted: November 29th, 2018, 18:38
Fzabkar, regards.
A question.
If the Alist is deleted, will data be lost?
PostPosted: November 29th, 2018, 20:58
I think he does need the data.
Nvidea wrote:
hello dear
can help me on HD103SI
smart is good but when i run mhdd he back to warning ...
i allready run dban and security erase on victoria is frozen need password, how to get ?
PostPosted: November 30th, 2018, 3:28
And in SAMSUNG what are the lists RList, VList and SList?
And where is the list of sectors pending to be reassigned?
PostPosted: November 30th, 2018, 4:00
http://www.hddoracle.com/viewtopic.php?f=44&t=1175&p=5283&hilit=RList+VList+SList#p5283
PostPosted: November 30th, 2018, 7:18
sorry for the delay
I would to thank you,
I'm not interested in data, just resurrect DRIVE for windows, fix uncorretables X erros ... :?
I learned a lot at hddoracle hotswap is ok to me now...
How to fix the "LED 1A04" problem :
i follow this, I thought this would correct the bad sectors...
but erased all sectors and is not accessible dead, what should I do for the sectors to work again??
PostPosted: November 30th, 2018, 7:40
in WD i know tha need G to P but samsung i no know
I used WDR Demo. You need to right-click your mouse to open the options menu.
Go to Actions -> Super Format -> Merge G to P
Just wait for a success or error message in the log.
After this do Actions -> Super Format -> ReMerge G to P
clear smart ...
it is correct?
PostPosted: November 30th, 2018, 15:15
I just backup the modules, Should i write to drive so will realocate?
lose all the data: mean lose sectors to remap? or lose docs, pics, etc..?
mhp666 wrote:
You loose access to re-mapped sectors and you will be re-directed to original Bad sector for each entre you delete on G-List.
it means i deleted G-List? maybe remap again on some script mhdd? or is all lose?
Adding GList to PList without and with Terminal, means the drive no will be able again to remap?
i never should do it then?
i has made it on all my WD and reallity bad sector is increasing ...
PostPosted: February 28th, 2019, 5:33
Otherwise why to go to the trouble of all of this ?
http://www.hddoracle.com/viewtopic.php?t=2617#p19342
He would just buy a donor and use it instead of buying it and kill it moving head(s)/platters, etc ....
By the look of things i would say he wants the data.
HELLO
if HD is lost with G-List cleaned, I can use the PCB for the donor to another drive?
and the body can be used as a patient to other drives?
or just the head(s)/platters can be used?
PostPosted: March 10th, 2019, 19:37
hmmmm thank much for reply ..
Why would you want to re-use the .... PLATTERS ?
i yet no understand,,
then can use all Body whole, or only heads,platter?, the PCB is Losse? then G list is recorded on PCB?
i can't open no know how swap heads,,newbie free,, :lol: if I open without the clear room is losse same way ..
PostPosted: March 13th, 2019, 16:41
sorry
I not want to change the plates and head, I know not to do this, I just wanted to know if I can still use the body with this Glist cleaned as a patient .... :?:
PostPosted: March 14th, 2019, 17:23
You can use the platters to put coffee cup on. Or to scare birds from plants. Oh, make sure power is turned off before placing coffee cup.
https://www.mjm.co.uk/
Users browsing this forum: No registered users and 76 guests
