February 15th, 2021, 1:13
testuser wrote:DR-Kiev wrote:This is Diablo 3S with full map of heads. It has nothing unique inside ROM , donor PCB with same exactly FW version should do the trick. But windows won’t help you access the data normal way . This is NAS and there is Linux file system.
Okay then i will order another PCB. How can i fully sure of firmware version? I have Linux so no problem reading if it is succesfully recognized in BIOS.
February 15th, 2021, 14:30
DR-Kiev wrote:testuser wrote:DR-Kiev wrote:This is Diablo 3S with full map of heads. It has nothing unique inside ROM , donor PCB with same exactly FW version should do the trick. But windows won’t help you access the data normal way . This is NAS and there is Linux file system.
You can download any FW version using specific tools, for example pc3k or WDR , but you dont no yet what is original FW so prepare bunch of them and try download every.
February 16th, 2021, 1:30
testuser wrote:DR-Kiev wrote:testuser wrote:DR-Kiev wrote:This is Diablo 3S with full map of heads. It has nothing unique inside ROM , donor PCB with same exactly FW version should do the trick. But windows won’t help you access the data normal way . This is NAS and there is Linux file system.
Do i need to buy any special hardware for it?
