Re: Seagate ST6000NE0023 ROM "contains critical damaged obje
April 1st, 2025, 16:28
RAJOO wrote:
fzabkar wrote:I used my own tool to find all possible candidates for single-bit errors. Then I used F3ROMExplorer to decompress the LZMA payload. The solution does not require that the CRC be recalculated.
SIR,
we need F3 rom explorar licence / paid version ?
please
Contact the author -- E123.
April 23rd, 2025, 2:44
Hello friends
I am a newbie. I also have the problem of LED BB error.spindle doesn't spin and BSY register is one. If possible, please check the attached ROM and fix it.
Thank you.
ST6000NM0115
FW:SN04
ROM.rar
(381.03 KiB) Downloaded 530 times
July 6th, 2025, 4:59
fzabkar wrote:I use the same free version of F3RomExplorer.
This is my tool (STROMFIX_2):
https://www.hddoracle.com/viewtopic.php?p=22181#p22181
It finds all possible candidates for a single-bit error in a Seagate ROM segment.
SIR
like to share your tools here
STROMFIX_2
please
July 6th, 2025, 12:09
RAJOO wrote:like to share your tools here
STROMFIX_2
July 8th, 2025, 11:27
fzabkar is living supercomputer having knowledge of everything -electronics , hard disks , programming , Its amazing how he has given solution to something which even ace TS cannot do.
Hat's off fzabkar. Thanks a lot for all the help extended.
August 12th, 2025, 1:11
Its usefulness for Seagate looks very interesting. I have been using your WD utility to repair corrupted bios for several years now, and it is very good. But your Seagate Utility didn't know about it. Can you share it? What version of F3romExplorer do you use? The version I have is F3romExplorer_free_1.0.9
sir
can we unpack 10tb seagate rom with.
thanks
August 12th, 2025, 17:32
RAJOO wrote:[can we unpack 10tb seagate rom with.
I had trouble doing this with one of the newer ROMs. Can you upload your ROM dump?
