Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: ST2000LM007 cloned but no file works
PostPosted: December 5th, 2024, 16:14
OK, just upload a couple of JPEGs.
Here it is: https://we.tl/t-CZgLaCA7VE
PostPosted: December 5th, 2024, 17:38
I tried a few JPEGs. None have a JPEG signature. They all look like the first few sectors have been stripped from the file. The Sony JPEG contains a small 160x120 thumbnail image.
The MP4 files also appeared to be affected in the same way.
I don't understand how any software, especially R-Studio, could make such a mess out of file carving. :-?
PostPosted: December 5th, 2024, 17:40
what are your thoughts? I would really love to learn more about this case of mine
PostPosted: December 5th, 2024, 17:48
I have no explanation for your results.
Try different software, eg DMDE. Also, try R-Photo.
To see the problem for yourself, examine the headers of good JPEG and MP4 files, and compare them against your bad ones.
HxD is a freeware hex editor:
https://mh-nexus.de/en/hxd/
PostPosted: December 5th, 2024, 17:53
R-photo couldn't find anything, not a single thing. I will try DMDE
PostPosted: December 6th, 2024, 6:00
DMDE actually worked, found many files and folder names intact. how and why r-studio failed in a case like this? I feel like I won't be buying rtt software anymore
PostPosted: December 6th, 2024, 6:27
try an older version, it might be a bug or something... or misuse?
PostPosted: December 6th, 2024, 6:29
I've been using it for more than a year, I had many successful recoveries
PostPosted: December 6th, 2024, 12:27
I can't explain why R-Photo found no signatures, but R-Studio seems to be offsetting the first cluster of the file by 64 sectors. It seems to be finding the directory records of each file. These records contain the file name, file size and starting cluster. Since the file system metadata have been destroyed, R-Studio would need to calculate the LBA of the first cluster in the file system and then offset the starting cluster of each file relative to this. Maybe that's where it is going wrong? Is it time to submit a bug report?
PostPosted: December 6th, 2024, 13:30
I e-mailed them about this yesterday, they keep insisting that I am doing something wrong. Still an ongoing discussion
PostPosted: December 6th, 2024, 14:45
Yeah, the JPEGs are full of JPEG data, but as Franc says, no "header".
Does JpegDigger detect JPEGs? Let the tool detect cluster size. If it takes > half hour then there's probably no file signatures.
PostPosted: December 6th, 2024, 14:49
I do not know about JpegDigger, DMDE already did the job. But I can test it if you like, Dr. Tuna
PostPosted: December 6th, 2024, 14:53
Oh sorry, missed that. I responded to a post @ Reddit, https://www.reddit.com/r/datarecovery/c ... _recovery/
PostPosted: December 6th, 2024, 15:10
@Pandemicc, can you show us the Partitions tab in DMDE?
PostPosted: December 6th, 2024, 16:15
sure, here https://imgur.com/a/iMFRfMt
PostPosted: December 6th, 2024, 18:04
I was wondering if DMDE would find the old exFAT volume at a different location. Apparently not.
PostPosted: December 6th, 2024, 18:28
It's curious that your exFAT volume begins at sector 64. Is that just a coincidence?
PostPosted: December 6th, 2024, 18:53
I have no idea, I would love to provide more information if needed
PostPosted: December 6th, 2024, 19:06
I'm wondering whether the original configuration was a "super floppy" with a boot sector at LBA 0. A subsequent repartition and reformat would destroy the boot sector, and perhaps R-Studio then assumes that LBA 64 is the original boot sector location. This 64-sector offset would account for the loss of the first 64 sectors of every recovered file.
You could examine LBA 0 to LBA 63 and look for non-zero sectors. If you find something, you could carve out that area and upload it. DMDE has a Tools -> Copy Sectors function for this purpose.
PostPosted: December 7th, 2024, 4:51
That is something that I am very much not familiar of, Im going to need more guidance
Users browsing this forum: Google [Bot], WebClaw and 302 guests
