Could a company using a PC-3000 Portable Pro with head mapping and different imaging strategies adjust the head configuration to obtain better reads from those sectors?
No. The previous data recovery lab guaranteed to use the PС-3000 when cloning the hard drive. If they weren't successful, why would another lab with the same equipment get a different result?
If they were talking about 50 or so sectors, those 50 sectors represent only 25 kilobytes of data out of the 60 gigabytes of disk capacity, which is an excellent result for a drive that had some reading issues.
The lab could, of course, manually read the remaining 50 sectors, albeit with error correction disabled. This could yield anything from a few incorrect letters in a text file to no data at all, but it certainly doesn't guarantee a correct recovery.
P.S. When the hard drive firmware detects an unreadable sector, it tries its best to read the data, including adjusting various internal parameters - nothing better than that can exist. You can only give the drive more time or try reading the unreadable sectors several times, intermittently, but if the drive can't read data from several sectors with its original heads, it usually won't be able to read them at all.
I have got the logs so do you want me to paste it on here?
Since you made a copy in HDDSuperClone, you should also have the project file saved. Take a screenshot of the number of copied and uncopied sectors (as in the photo below) to make it clearer what we're dealing with.
My question is whether another data recovery company might have a better chance of recovering data from those remaining bad sectors.
Since I only need about 35 files (ZIP, EXE, TXT, and URL files), I'm wondering whether it's worth getting a second opinion.
Theoretically, yes. The problem is that these remaining files can be corrupted for four reasons: currently unreadable sectors, damaged (and relocated) sectors in the past - part of the data within the file was lost in the process, lost information in the file system about the location of fragments of these files, and corruption/overwriting of parts of these files by the CHKDSC.
My point is that recovering these remaining files can be a hundred times more difficult than cloning the hard drive.
