Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: February 14th, 2007, 14:52
ok thx.
PostPosted: February 19th, 2007, 1:56
Fix mode does not erase the data!
Self Scan erases the data!
You can run Fix mode and it will try to repair the currupted modules in your Firmware.
 Post subject: I Need Maxtor Firmware Repairer
PostPosted: May 16th, 2007, 17:43
Hi.
I have a problem with a Maxtor Hadr Disk (Fireball 3 or 2F040L0).
When the BIOS autodetect the disk, it show "MaxtorARES C64K".
I know that the problem is Firmware, because the PowerMax Application show that the other things are OK. Only the BIOS Recognition fails.
Thanks if anyone can help me.
Screesh!
PostPosted: May 17th, 2007, 4:47
hi friend,
i can help u -can u tell me the tool name u r using like pc3000 or salvation maxtor firmware repairer pro
pls let me know so then i can help u..
PostPosted: May 25th, 2007, 21:03
Hi.
I don't have any of these programs, so I already have the problem.
The Maxtor Firmware Repairer that is available on Internet only can fix a Maxtor 541DX (2B020H1 2B010H1) and I have a 40 GB Maxtor Fireball 3 (2F040L0). I'll try to change the logical card (if I find another disk with the same reference)
See ya.
PostPosted: May 28th, 2007, 2:25
MY FRIEND,
IF U NEED TO RECOVER YOUR DATA ..
U NEED TO RUN IN SAFE MOD PUT JUMPER IN SAFE MODE
1- FIRST START UTILITY THEN SEE ON VIEW STATUS SHOULD NOT SHOW BUSY MUST SHOW READY STATUS THEN GO START WORK..
2- HDDGUIDE THEN PRESS RWEMS
3- THEN CHECK INFO IF SHOW U INFORMATION OF DRIVE THEN PRESS
FIX MODULES.. YOUR DATA WILL RECOVERED AND YOUR DRIVE WILL BE IN DETECTION.. (IF U DO FIX MOD YOUR DRIVE CAN NOT WIPED)
DONT WORRY TRUST ON SALVATION PRODUCT..
ENJOY
HDDKING
PostPosted: May 28th, 2007, 2:31
I think HDDKING give you a really good solution. It's a typical firmware problem. Our product Maxtor Firmware Repairer will help you with this problem.
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: June 1st, 2007, 3:19
hddking wrote:
MY FRIEND,
ENJOY
HDDKING
He does not have the program why are u telling him the procedure its of no use .
Users browsing this forum: No registered users and 47 guests
