Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba MK6032GSX SATA with burnt CPU
PostPosted: August 11th, 2007, 2:53
Amarbir wrote:
Can we transfer the platter to the donor and recover data in this type of drive if we match everything what has to be matched .this should give atleast some data reading success and with DE it should be better results.
Yes Amarbir sir, but it's rather difficult. This model (and probably all models in near future...) can not be easily transplanted to a new donor. May be 1-2 times we'll get lucky..but I don't know for sure..Never got any case with burnt ARM before... :(
My Forum
PostPosted: August 11th, 2007, 15:44
To all guru's
Will after changing head and making the drive come in Data extractor and using virtual translator option will help :?:
DF :)
DF :)
www.datatracksystem.net
PostPosted: August 15th, 2007, 7:32
If the PCB is replaced with one with similar adaptives, that the disk will work with many shifts, is there a more convenient way to find the shifts? Is there a way to manually find the location a file should be at, and the location it is actually at and recover it correctly with file names? In many cases customers will require specific and unique files for in-house applications which do not have identifiable headers for RAW data recovery. :(
PostPosted: August 21st, 2007, 11:38
Of course there is way to find shift points and locate the files, I have written some code to do that. To do this U need to clone the drive, then U have to define partition starts, scan the partition for important file system objects (MFT records, directory entries, inode tables, etc, depending on the FS), then U can locate the files and find shifts from the beginning to the end.
regards,
PostPosted: August 22nd, 2007, 17:08
Hi Pepe,
This is custom Software You Have Written For Self Use .Can You share a Snapshot Of the Same .Its Interesting .
PostPosted: August 23rd, 2007, 13:54
That's it. :)
File comment: That's it
PostPosted: August 23rd, 2007, 15:26
Well Nice,
It Was Long Ago I Used To Write Anti virus Software
Users browsing this forum: No registered users and 69 guests
