Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Salvation-Seagate HD Doctor Woes
PostPosted: June 8th, 2008, 15:09
BlackST wrote:
How long this thread will be going on ? If someone has something to say please do it - unless this thread is intended as a poll about how many users of this forum have bought / is going to buy such products. I am going to buy anyway but advice is always welcome.
Hi ,
This thread Is Intended for All the Friends Here To discuss Here About Salvation Data Seagate Product Technical Tips ,Errors,Bugs ,Etc etc ,this is Not a Buy It Or Leave it thread,Until We do not How Many Use The software there is No Reason To Proceed .
@ Laura :Give this Gentlemen His Seagate Tool ...... :good:
PostPosted: June 8th, 2008, 17:09
Hi all ,
Few questions That i Still Have to figure Out
1 :In the boot management TAB ,
what Will Load the APP,CER and the CERT Tables into ram the buttons called APP,CERT ,CERT TAb or the buttons Called APP to HDD ,CER To HDD ,CERT TAb To HDD . :ddown: .this is not Clear At all
PostPosted: June 8th, 2008, 18:21
Its similiar to the LDR for Maxtors. I have used it a few times to jump start a Seagate drive with a damaged SA. I believe it is in the manual or pdf files.
PostPosted: June 9th, 2008, 1:11
Hi ,
That i Know ...But they Write
APP APP To HDD
CERT CERT To HDD
CERT TAB CERT TAB To HDD
Load All Mods Ignore Wirire Fail To SA
Question is that what tabs load the same in ram the once on the write or the left........
Others :Please Start discussion the Issues And Solutions In The thread Now .........
PostPosted: June 9th, 2008, 11:21
Please Download the New Verion of the Software they Have Launched the Version 2.2 of the software .I Made some Interesting changes For the Language.ini file and here is what it does
1 :Corrects spelling mistake of Clear P lsit To Clear P List
2 :Corrects Spelling Mistake of Clear G Lsit To Clear G List
3 :corrents spelling Mistake of Clear T Lsit To Clear T List
4 :In The Boot Management Tab it Modifies The APP,CERT and CERT TAB To APP to Ram ,Cert to Ram ,CERT TAB to RAM and Load all Mods To RAM .Its More clear Like This
As We Have More People Now Using This Tool ,Please share Your Experiences On This tool Now ,All Your Issues and Problems Etc ,We also Need To share Firmware .
PostPosted: June 9th, 2008, 12:00
Hi ,
I forgot to attach the script file ,Its attached now ..............
Language.ini [5.27 KiB]
Downloaded 836 times
PostPosted: June 10th, 2008, 14:43
Amarbir wrote:
Hi ,
Hi ,
The Script File Was Downloaded 14 Times But Not even One Guys Has started Posting Issues And Problem and Sucess Stories In Seagate Salvation Tool .Sean I Expect You To Start Before Me ... :lol:
PostPosted: June 12th, 2008, 22:25
I guess I'll break the ice.
I have the HDDoctorforSeagate and I have been doing head depop on some defective HD to repair them;
since I do not have a clean room to do a head exchange instead. Now for the head depop to take effect HDD Zerofill had to be done which if Im not mistakin writes zero to every sector and rewrite ID.
Now I did a Head#0 depop and after I did the HD zerofill it took close to 40 minutes to finish the. My objective is to minimize time and at the same time obtaining the same result (namely on level T commands in the form of Bx,y). I was thinking to change the symbol rate using the special command on terminal from 9600 symbol/sec to say 1228000 symbol/sec.
Is this possible?
I asked the technical support and they told me that they have never done it before.
But I just dont want to try until Im sure it can be done becasue I dont want to risk anything.
any advice on this will be apreciated.
regard
Pedro E.
PostPosted: June 12th, 2008, 23:31
Is this possible?
regard
Pedro E.
here a qeastion for you if you repop the head or turn of a faulty head on the hard drive
why can you not do a recovery with the other heads
it sounds to me that you have to redo the hard drive all again and zero it out
for it to work again
in that case you wont be able to get any recovered data back at all
im i wrong or right
i dont see the point in this product from salvation
as the ideal is to recover data not to destroy it
PostPosted: June 13th, 2008, 4:56
I have all. hope can be help of you.
PostPosted: June 13th, 2008, 11:16
i think susan = salvationlaura :D :D
PostPosted: June 13th, 2008, 12:50
im i wrong or right
I guess I didnt explain my self correctly.
I just want to REPAIR the HD not DR. the data is not important for me right now.
I wanted to know if I could set the boud rate to a higher symbol/rate value and if this would be implemented on the HDDzerofill I have to do in other for the Head depop to take place.
on a 160 GB drive I depoped H0 and it toook close to 40 minutes. so that is why Iam asking if some1 knows if this could be done.
PostPosted: June 13th, 2008, 12:51
:ookay: right on the spot!!
PostPosted: June 13th, 2008, 14:16
Bingo..................
PostPosted: June 13th, 2008, 14:19
Is this possible?
regard
Pedro E.
Question .
If you do Change the Rate It will Not Matter Cos when you do Zerofill in this Tool "I might be wrong here" it uses ATA to fill all sectors with zero .Even if it does a Security Erase Like We Put Password in MHDD and Do The Rate Increase Will not Make a Difference.
PostPosted: June 13th, 2008, 14:22
Hi ,
when We Connect the Terminal To the HDD And The IDe Cable And do ROM and firmware Backup,i have few question here
1 :How Are We Sure the copied ROM is 100% Matching With the Internal ROM ,Lets Assume Some Of the Connection was not proper and we did copy the rom but the contents do not match .is this possible .Salvation should have a match feature so that we could take out all the connections and reconnect the drive and power it up and test if the rom and firmware copy was identical to the old saved copy
PostPosted: June 13th, 2008, 15:10
Amarbir wrote:
Question .
I had the feeling it wouldnt make a difference since when I did it it changing the symbols/second parameter it took more or less the same time as if I hadnt change the baud rate at all.
Thanks for answering me anyways.
regard
Pedro. E
PostPosted: June 13th, 2008, 17:42
Clean rooms are phenomenally overrated.
Duncan
PostPosted: June 13th, 2008, 20:24
Odiferous wrote:
[Clean rooms are phenomenally overrated.
Duncan
why r they phenomenally overrated duncan?
is there something better than a clean room to do surgery on the HDD?
PostPosted: June 14th, 2008, 2:29
:D :D no, I'm not Laura. I'm Susan. But you are also right, I'm her colleague. :wink: :wink:
Users browsing this forum: No registered users and 77 guests
