Re: General (and not general)Seagate questions - for everyone :)
March 1st, 2009, 19:03
ccc wrote:Hi
Try to press "." several times to see if it's doing something or not....As far as I know this is a long test but 24 hour(for 2 heads) is too long...something is wrong there...
And are you sure that after test 40 comes test 41?...look in log 4e to see the test sequence...
Rgds
I have tried:
T>E4e
No log 4E on disk
T>
Not luck. :(
Thanks anyway!
Somebody have any suggestion?
Thanks,
Janos
March 25th, 2009, 18:04
I had a very little time, and done some steps...
The selfscan is done (i have found the next step, it was the 31 after the 40).
But now this is what i can see:
Interface task reset
4096k x 16 buffer detected
PUMA - 1_Disk M-22d 11-11-04 10:47
Spin Ready
3.43 01-26-05 16:23
(P)(H)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .083
Cert Table loaded
T>N50,,22
T>
(power cycle)
Spin Ready
3.43 01-26-05 16:23
(P)(H)SATA Reset
OVERLAY FAILED
T>
Somebody have any suggestion, where to start?
Thanks,
Janos
March 26th, 2009, 2:14
BlackST wrote:I have already pointed out what seems to be ignored : commercial available tools , on which the majority of repair shops and DR rely on, are only tools to access the SA or firmware zone, driven by human beings. We have to use our logic skill / capabilities, unless it is a simple, "clickable" solution.
What's worst, the more I go further researching and experimenting, the more I can do without those expensive tools. The DR is moving to phisycal, hands-on-drive level, and if you really want to do magic, if you know sufficiently how things work, you can write down your own tools even in Turbo Pascal (maybe forgetting GUI but who cares ?). Enough said.
Agree :cool:
March 26th, 2009, 2:55
To N.C.
You need to rewrite ATA overlay(track) from an identical model/fw.
Rgds
March 26th, 2009, 4:38
ccc wrote:To N.C.
Rgds
Thank you!
I have the backup of this drive.
Can I use this ATA module?
Janos
March 26th, 2009, 4:56
Of course you can....
Rgds
April 6th, 2009, 8:21
Now i have a little time, and was played a little more.
I have uploaded own ATA overlay.
After the next restart, the drive sad:
Stuff Was Unreadable
T>
And now what? :)
J
April 6th, 2009, 9:12
Hi
There are many ways to resolve this:
You can rewrite sect 4 of vendor track from an identical model or from his own track saved before ss,
or in T you can type F and as response type ASCIFE - that will reset STUFF to defaults;after that you must input the corect parameters for STUFF...
Rgds
April 6th, 2009, 12:13
ccc wrote:Hi
Rgds
If the modules not have the sect. 4 than i have not saved this before ss. :(
If i select the T> F, what do i need to input?
Thanks,
Janos
April 6th, 2009, 15:24
T>F
Setstuff>ASCIFE
April 6th, 2009, 16:14
Thanks my friends,
This works, but i still have problems. :D
The drive comes up to ready now, but shows strange ID and LBA.
I have fixed this with SD seagate, but the drive have some unreadable sectors.
Now i have started the security fasterase from MHDD, but the terminal shows there are bads on the disk. :(
Thanks,
April 6th, 2009, 18:31
Janos,
after clearing the STUFF did you add the values back?
April 7th, 2009, 5:37
quasimodo wrote:Janos,
No.
The ASCIFE sets to the default, and than i power cycled the hdd.
On the startup, it starts to rebuild the smart sectors, and gets ready with strange ID sting and about 210GB LBA capacity. :D (80GB drive)
Janos
April 7th, 2009, 5:56
Like I said, after reseting STUFF, you must correct the values according to the drive model, lba , max lba, etc....
Rgds
April 7th, 2009, 6:35
ccc wrote:Like I said, after reseting STUFF, you must correct the values according to the drive model, lba , max lba, etc....
Rgds
If i am right, this is what i have done with the Seagate doctor...
I have set the LBA value and drive ID.
no?
J
April 7th, 2009, 6:46
OK...Did you verifyed ,with mhdd for ex., if now the values for model, lba, are ok?....If they are ok, try to remap those bad sectors with mhdd or victoria or any ather program.
Rgds
June 12th, 2009, 10:58
ccc wrote:Hi
Rgds
Now i have another drive after SS.
The ATA upload is done, but i have another problem:
APLUS - 1_Disk S.07 08-16-04 10:34
Spin Ready
3.01 08-16-04 10:35
(P)PATA Reset
T>F
SetStuff->ASCIFE
Setting stuff to defaults
Unsupported drive type 0x f2
@ this point, the typing is disappear, and i can only exit from this command.
Any suggestion? :D
Thanks,
Janos
June 12th, 2009, 11:17
Hi
Try to set drive type ...T>Y command
Rgds
June 12th, 2009, 11:18
ccc wrote:Hi
Rgds
I have seen from the doc, the Y command resets the defect lists and all calibrations...
I need to repeat the 3 day ss? :D
Thanks,
Janos
June 12th, 2009, 11:25
Also try to look at this post:
7200-stuff-mess-t12153.html#p79225
It may help you....Or try to rewrite the 4 sector of vendor track...
Rgds
