Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WDC firmware fix w/o pricey tools?
PostPosted: May 22nd, 2014, 3:48
louis wrote:
saltwater wrote:
Hello again! :-)
All modules readed from the rom except the 0001. The error code is 5441 (SERVO_ERROR_CODE_BASE_SvirActSync)
mod 1 it's the directory module...and it's on SA. try to use the rom adaptives from the donor's pcb. if it doesn't work, then there's a problem with the HSA.
Thank you louis and fzakbar!
The donor was a different model: WD30EZRX-00MMMB0. The sick drive was fallen while it's powered. I think if i have a copy of WD20EARX-00MMMB0 firmware modules, then with WDR i can load overlay, and module list from file, and maybe i can access to the sick drive's SA.
Users browsing this forum: Majestic-12 [Bot] and 43 guests
