Re: Lacie Network Drive with Seagate Barracudea 7200.12 clic
January 19th, 2016, 13:57
if the data is not needed why would you bother, throw from the empire state building or whatever, but I really can't understand the urge to destroy the drive using random commands
January 19th, 2016, 16:20
Let's just say, that this was the Apollo 40 Lunar Mission and I was stuck on the moon because of this drive and my only hope of safe return was mission control entering some commands from earth and/or attempting a firmware update. What would you do? :)
January 19th, 2016, 16:24
Whatever commands being sent will not work because the drive is not in a state where it can pick them up.
It's like talking to another person. You could talk all you want to, but if the other person is sleeping is on drugs, then your message will not be received and processed. Because the other person is impaired.
January 19th, 2016, 16:31
I wouldn't be on the moon if I wasn't familiar with the right commands, so if i am stuck on the moon i know exactly what commands to use, and what commands will destroy my only way out
January 19th, 2016, 17:12
What's the difference between this guys drive and mine?
viewtopic.php?t=23489&start=#p158547
Seems like he had some success running some of those commands posted earlier.
January 19th, 2016, 17:23
With limited info in the thread, it seems his drive was not clicking. Additionally, it seems like his drive is not as degraded and at times it received commands.
Try the following command at the prompt:
V40
Post output.
January 19th, 2016, 17:42
labtech wrote:Try the following command at the prompt:
V40
+1
January 19th, 2016, 20:05
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>V40
Failed to load overlay 00000004
LED:000000CC FAddr:0029E965
LED:000000CC FAddr:0029E965.€......€€.€€þ
January 19th, 2016, 20:52
labtech wrote:Whatever commands being sent will not work because the drive is not in a state where it can pick them up.
January 20th, 2016, 0:05
Ok, I guess I will just shelf this one. Maybe move onto my pile of way older busted drives to experiment with, maybe even open one of them up and just get a feel for the different parts and inner workings of them. (yes, I know they are ruined once I do this outside of clean room). Wish this current drive had been more reasonable but I guess it's broken. Thanks for your help though. I learned a lot.
January 20th, 2016, 4:31
jermy wrote:I wouldn't be on the moon if I wasn't familiar with the right commands, so if i am stuck on the moon i know exactly what commands to use, and what commands will destroy my only way out
If i went to the moon i wouldn't take a Seagate :mrgreen:
January 20th, 2016, 8:43
day1data wrote:If i went to the moon i wouldn't take a Seagate :mrgreen:
:lol:
i wouldn't take a Seagate even on earth :lol:
the OP want :)
January 20th, 2016, 12:58
Yea, I definitely won’t be buying seagate again. Or Lacie for that matter. Luckily I have some pretty decent backups so I'm not hurt too bad but it’s annoying because this drive is less than 5 years old and sat in a ceiling in luxury not being worked too hard. Whatever. It is what it is.
January 20th, 2016, 13:23
clickofdeath wrote:this drive is less than 5 years old
WOW, it last that long ? :lol:
i have a seagate here that came in, just a few month on the road... :(
January 20th, 2016, 13:54
probably around 3 years.
January 20th, 2016, 14:44
clickofdeath wrote:probably around 3 years.
That is how long on average this series drive lasts.
