Re: Drive recognised but every sector is bad
June 15th, 2016, 18:09
I checked my resources for a suitable donor module. The closest I could find was this one:
module        version (ASCII / hex)
32.MOD        0             30
31.MOD        0             30
34.MOD        132R?         31 33 32 52 3F
33.MOD        132R?         31 33 32 52 3F
00000000  08 14 31 1E 32 30 00 00 00 3F 00 00 00 00 00 00  ..1.20...?......
00000010  00 00 00 00 00 00 08 00 5C 00 00 00 6C 00 00 00
00000020  CC 0A 00 00 FA 0F 00 00 97 02 00 00 03 00 97 02
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000040  31 04 B9 04 B2 B6 B8 04 07 55 01 00 00 20 00 00
00000050  97 02 00 00 B7 A3 05 00 69 5A BE 04 00 00 00 00
Yours is ...
31_00B0.MOD   0             30
33_0122.MOD   132D?         31 33 32 44 3F
34_000C.MOD   132D?         31 33 32 44 3F
Information from module 02 ...
yours
    WDC WD400JB-00FMA0
    WD-WMAJ91017411
    SJBULBPMM6H7CSRLVMKNUF
    01-01-2004
donor
    WDC WD400JB-00FMA0
    WD-WMAJA1035123
    SJBULBPMM6H7CRRJVMKNUK
    01-26-2004
FWIW, I also found a WD800JB-00FMA0:
33.RPM        1500?         31 35 30 30 3F
32.RPM        1500?         31 35 30 30 3F
34.RPM        1500?         31 35 30 30 3F
31.RPM        1500?         31 35 30 30 3F
June 15th, 2016, 22:23
RD32SEC2 gave the the same error as the other script - Drive reports error :(
Sorry your last post went a bit over my head, are you saying that the modules look the same between the donor and mine?
June 16th, 2016, 16:16
fzabkar wrote:The following script works on my BB drive.
Sorry, I posted the wrong draft of my script. The corrected one was included in the RAR attachment, so no problem. Here is the correct version (which I tested and included in the RAR):
; reads first 2 sectors of module 32 on heads 0 and 1
reset
waitnbsy
regs = $45 $0b $00 $44 $57 $a0 $80
waitnbsy
regs = $d6 $01 $be $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsfrom = rd32h0s1.bin
regs = $d5 $01 $bf $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = mod3201.bin
waitnbsy
checkdrq
sectorsfrom = rd32h1s1.bin
waitnbsy
checkdrq
sectorsto = mod3211.bin
waitnbsy
checkdrq
sectorsfrom = rd32h0s2.bin
waitnbsy
checkdrq
sectorsto = mod3202.bin
waitnbsy
checkdrq
sectorsfrom = rd32h1s2.bin
waitnbsy
checkdrq
sectorsto = mod3212.bin
; end
; rd32h0s1.bin -- 0C 00 01 00 FE FF FF FF 00 00 F6 01 01 00 00 00
; rd32h0s2.bin -- 0C 00 01 00 FE FF FF FF 00 00 F7 01 01 00 00 00
; rd32h1s1.bin -- 0C 00 01 00 FE FF FF FF 01 00 F6 01 01 00 00 00
; rd32h1s2.bin -- 0C 00 01 00 FE FF FF FF 01 00 F7 01 01 00 00 00
June 16th, 2016, 16:31
If you examine module 02, you will find text strings that identify the drive. The manufacture/build dates are 3 weeks apart. Also, if you compare the header information of the donor's MOD 32, you will see that it is similar to the header info in your patient's MOD 31. My only concern is in regard to the numbers at offset 0x40 and beyond. These numbers point to LBAs and cylinders which are reserved for sparing. They may not be the same in your drive.
I would be tempted to copy the donor's module to your own drive, but if we get it wrong, then that may render the drive inaccessible for further attempts.
You might first like to try the following modified script. It avoids head 0 and tries to read head 1.
; reads first sector of module 32 on head 1
reset
waitnbsy
waitnbsy
waitnbsy
checkdrq
waitnbsy
checkdrq
This next script reads the first sector of MOD 31. You might like to try it before we do anything more adventurous. If this doesn't work, then this will point to a problem with your method.
As before, copy the script and BIN file to the appropriate places.
; reads first sector of module 31 on head 0
reset
waitnbsy
waitnbsy
waitnbsy
checkdrq
sectorsfrom = rd31h0s1.bin
waitnbsy
checkdrq
sectorsto = mod3101.bin
; end
; rd31h0s1.bin -- 0C 00 01 00 FE FF FF FF 00 00 42 01 01 00 00 00
rd31sec1.rar
(316 Bytes) Downloaded 523 times
June 17th, 2016, 5:21
fzabkar wrote:You might first like to try the following modified script. It avoids head 0 and tries to read head 1.
Ok I'll give that a try, is there a way I can convert that code into the script and bin file that I need to run it?
fzabkar wrote:This next script reads the first sector of MOD 31. You might like to try it before we do anything more adventurous. If this doesn't work, then this will point to a problem with your method.
Ok done, I've uploaded the output .bin file here
http://www.filedropper.com/mod3101
June 17th, 2016, 6:47
Just copy the text into a script file using a text editor (not word processor). Choose a name such as RD32H1S1, and place it in the SCRIPTS directory. The RD32H1S1.BIN file is the same as previously uploaded.
Your uploaded mod3101.bin file is indeed the first sector of MOD 31, so your method is OK.
June 17th, 2016, 10:36
OK RD32H1S1 didn't work, gave the same error. Are the modules mirrored on the platters, so should the first sector of head 1 be identical to the first sector of head 0? Should we try the same script but for head 0?
June 17th, 2016, 17:40
Head 0 was the first head accessed by the original script. Since the script bombed on the first head, it was therefore unable to test the second head. My second script tested the second head on its own. In short, neither head is allowing access to MOD 32. :-(
June 23rd, 2016, 17:25
Update:
The user was able to recover all but 20MB of the data. We achieved this by replacing the damaged module 32 via direct CHS writes, firstly to head #1, then to head #0. I don't know if we could have achieved the same end by "regenerating the translator" using NazYura's MHDD script. AIUI, module 31 is the translator, but perhaps the aformentioned command regenerates both modules ???
We used the following scripts. Please be WARNED that the write scripts are tailored for the OP's drive and should not be applied to another drive, even one with the same model and firmware version. This is because there is no guarantee that the modules will be located at the same CHS address.
http://www.users.on.net/~fzabkar/temp/write32.rar
http://www.users.on.net/~fzabkar/temp/write32hd0.rar
http://www.users.on.net/~fzabkar/temp/regntran.rar
BTW, I realise that we could have written module 32 using a different VSC, but I wanted to see what would happen when we specifically wrote to head #1.
