Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: Yesterday, 16:51
0x43110081: RW_EDAC_HW_UNCORR_ERR - Disc Xfr - EDAC HW uncorrectable error.
0xC3160080: RW_DATA_SYNC_TIMEOUT - Disc Xfr - Data sync timeout error.
PostPosted: Yesterday, 16:52
The problem is definitely not with the NAND. According to the log, it’s failing to read the service area. Either the heads are dead, or you’ve mixed something up with the ROM. And the SA adaptives turned out to be similar, which is highly unlikely...
PostPosted: Yesterday, 16:54
You put the original ROM back onto the patient board, right? :)
PostPosted: Yesterday, 17:01
I'm pretty sure I did. I also verified it multiple times after flash.
Update: I never closed the flashing software. The Patient ROM is still selected. I am sure I flashed it. It is even in the log.
PostPosted: Yesterday, 17:18
According to the ROM dumps, the patient serial number is W771H0Q2. The donor is W772YJ39.
PostPosted: Yesterday, 17:28
That's correct
I only dumped the donor-rom I never flashed it anywhere
PostPosted: Today, 5:51
Well, then this drive survived an encounter with the floor or the wall. With spinning platters. It's not often that the SA is completely destroyed on both heads. Where is the recording density the lowest... 8)
Users browsing this forum: grevan and 72 guests
