October 8th, 2008, 11:01
Odiferous wrote:mediaman wrote:hhhaaa
well done!
doomer: i'm trying to be professional but the learning curve is steep. This is the first failure i have had in the past 20 disks. good thing it's mine and not a customers. Come on, what would you try next?
If you've achieved a success rate of 19 head swaps out of 20, then ..... (not quite sure what to say)
Duncan
October 8th, 2008, 11:11
pninja wrote:mediaman wrote:FAILURE!
Hi mediaman,
Just to double check the head and your skill, put it back to its original place and align it.
If it worked then your H swap was perfect. Look for possibility of incompatible head assembly,
bad PCB or F/W problem.
If it didn't work, conclusion is there...![]()
I have done HS on this model 3 times. One complete fail. Other two partial success.
In one case I had to disable a head to clone the drive. In another case cloned with
tons of bad sectors.
October 8th, 2008, 11:21
October 8th, 2008, 11:49
BlackST wrote:At this point seems that I have to sell the solutions or outsource.....
@mediaman, why don't you ask someone who has in-house technologies or solutions and/or high success rate for outsourcing instead of asking for capital assets and/or training? It's not possible to give away such resources (sorry for being "so clear" but sometimes it's needed - I am renowned for saying things right out and as things are) I mean you send them the disk, have the job done for good and with excellent results, you earn in terms of company image and also don't have to invest for appliances and technology, plus your profit margin... I usually outsource what I can't do due to time pressure, parts availability or simple convenience. That's business, mister !
October 8th, 2008, 12:29
October 8th, 2008, 22:35
mediaman wrote:pninja wrote:mediaman wrote:FAILURE!
Hi mediaman,
Hey PNINJA, thanks. Yes the reverse swap did sound like a nice learning idea and I was going to go for it but real work got in the way. I now realize that only one repair station (Atola Insigt + Server) at a time is very slow way to handle several disks. I concluded that the alignment issue would not make it worth the try.
Have you really managed workable HSA swaps on 2 out of 3 WD75000AAKS? Did you just bolt them up and they worked? No lid tweaking? Do tell.PM fine. In your head disable case, did you use Deepspar head mapping feature to do that? Insight does NOT support head control
Thanks again for the positive feedback!
October 9th, 2008, 0:26
pninja wrote:mediaman wrote:pninja wrote:mediaman wrote:FAILURE!
Hi mediaman,
I don't have Insight tools. I use my home made tools plus ACE lab and Salvation data.
However I found your words "Have you really managed..." insulting, I'll give you a hint and
leave it to you to find
the answer to your question after your HSA numbers passed 1000 or so and you managed to make some
special and very simple tools for yourself. The task that looks impossible now, will be a simple routine after years of experience.
Your problem is you are relying too much on commercial tools. They won't help you on many cases. Just read again what experts told you before.
A hint, to work with WD drives you have to observe and control the head
movement. Make a simple tool as a HA fastener and a way to apply pressure on any
direction. So, you won't have to close the cover. The tool should be heavy enough to
to stop HA vibration when moving.
October 9th, 2008, 13:46
Russwinters wrote:While I have not performed a head swap on these series WD drives; I personally own a 640AAKS and did quite a bit of research on them. They are the ~320GB per platter design; and they actually utilize a ramp; so as long as you load the new heads on to the ramp they should be fairly aligned; the ramp should somewhat eleviate the lid screw issue. As long as the heads remain parked on the ramp when you tighten then lid screw the drive should at least be in good enough shape to recoer data; but on the negative side these are high density drives, so in that respect; Godspeed to you.
October 9th, 2008, 13:50
October 9th, 2008, 14:00
mediaman wrote:750 is 4 platters/8 heads
cheers
October 9th, 2008, 14:02
October 9th, 2008, 15:06
Amarbir wrote:mediaman wrote:750 is 4 platters/8 heads
cheers
Well ,
In That Case You Made a Impressive Head Swap attempt Mate ,In WD Its All About Alignment ,Pepe sir and Master dimitry have good experience in this very good indeed .i Love your inclination to do work,Thats very impressive ,We need more people like you ,If i had the experience here i would have shared with you ,But i know someone who i will like to ask and report back,Well done again
Amarbir wrote:And Hey ,
How did You Get Insight tools altoha
October 9th, 2008, 15:09
mediaman wrote:Amarbir wrote:mediaman wrote:750 is 4 platters/8 heads
cheers
Well ,
thanks mate. I am conceptualizing a jig now to:
a- hold HDA firmly
b- hold HSA/lid firmly
c- alow micrometer x/y/z adjustments between the two
d-document and cycle tried positions with some electromagnetic feeedback
sounds good here, lets see if I ever do it, or if it ever works..Amarbir wrote:And Hey ,
I went to meet Dimitry, did a course with him and bought it
October 9th, 2008, 15:12
[/quote][/quote][/quote]Amarbir wrote:
Well ,
Thats Great To PM Me With the Experiment these drives are very bad as far as alignment is concerned ,And PM Me How Much You Got That Tool For ,I Think Its For Release Comming Month .I am Waiting For Master Dimitry words on This issue
October 9th, 2008, 15:22
[/quote][/quote]mediaman wrote:Amarbir wrote:
Well ,
October 9th, 2008, 15:31
[/quote]Amarbir wrote:mediaman wrote:Amarbir wrote:
Well ,
