September 11th, 2008, 12:54
The best software, hard choice.
I wear year with recovery software and i obtained excelent results with software of 39$ and with software of 500$ i can not restore any data, but i have been the opoosite situation too, try to recover data with software of 39$ and no obtain any data but with the other obtain all the data.
so dificult decision.
Try software and think about the response of the testing.
Bye
September 11th, 2008, 13:50
skyunlimited wrote:Damn it, one of my WD drives go wrong, it can not be detected and i heard a bad noise, fortunately i got a backup of the most important data, but not all, what can i do?
AWWCH!!! I felt sorry for you dude. (*cough*) (*clears throat*)
Seems like Dr.Chad's plan didn't go as well as you expected, didn't it?
If you read my thread, you'll understand what I'm trying to say.
skyunlimited wrote:there is some new experiment data inside which i haven't got time to back up
What's next? Off to see wiseleo.
wiseleo wrote:3 digits range
I can see a grin on your face -->
To myself: Do I have superpower or is it just coincidence?
Sorry for using too much emo, need to show more emotions
September 12th, 2008, 1:51
Last night i got a yahoo email, someone recommended DC to me, he claimed DC is able to solve my problem and they spend 8 years in developing DC. I replied the email asking for some data sheet about the tool, i hope it is true, not kidding me!
September 12th, 2008, 2:24
skyunlimited wrote:Last night i got a yahoo email, someone recommended DC to me, he claimed DC is able to solve my problem and they spend 8 years in developing DC. I replied the email asking for some data sheet about the tool, i hope it is true, not kidding me!
Sorry to chime in and possibly rain on your parade, but you, like
so many others, seem to think that there is some "Magic" software
that will fix everything, sorry it ain't gonna happen.
DC may solve your problem, but just as likely it won't.
The VERY FIRST process in Data Recovery is to determine the
problem. You have to do proper diagnosis BEFORE you can decide
on a course of action for recovery. If the drive has physical damage
then NO software will solve your problem. If the drive has electronic
damage, again software won't help you.
The answers you were given in the beginning of the thread were
the correct answers.
IF your questions were intended so that you can pursue a career
or position in data recovery, then the answer is there is no "BEST"
software. It takes lots of different softwares/hardwares and tools.
and multiple thousands of $$$ . And then there is the learning curve,
Add several years of study to acquire the proper knowledge.
Your present problem would probably be best solved by sending to
a pro. ( and in the long-run will save you time and money)
September 12th, 2008, 2:34
I'm sure he was telling the complete truth. I've been lying through my teeth. You can't trust me, I'll tell you to do reckless things, like backing up. It is very clear you are going to move ahead in some direction or another, no matter what. Let us know how it goes after you get DC. Many of us are waiting for more reports on how well it works. If not, the Deepspar imager will likely do a better job. If for some reason these don't work, perhaps it's a firmware issue, and a PC3000 UDMA might be able to take care of it. All these will help, unless if you have bad heads. Unfortunately, I don't know much about diagnosing heads, so I couldn't possibly tell you if a bad noise, knocking, etc, could be bad heads. It's probably best to get the tools, and find out. Let us know how it goes.
September 12th, 2008, 3:21
skyunlimited wrote:Hi wiseleo,
The hdd can not be detected at all, there is some new experiment data inside which i haven't got time to back up, but not that urgent.
Do you have or know some 'Tool' which has some auto detection functions and then functions to recover data?
You had ample warning.This will cost you more than $1000 to fix. Probably closer to $2000. I am guessing you will be redoing the experiment.
Stop ignoring our advice.
I have absolutely no pity for you.
Good luck.
September 12th, 2008, 3:43
I do have accepted your advice and i wrote them down, i will remember it ten thousand years!
I have now backed up all the experiment data , so it is safe now. I have double copies for each.
As for DC, i will see what others say about it and then take actions. If it is really good, i think i will be happy to introduce to all of you guys.
October 14th, 2008, 17:05
I hope this is an alright spot to post my question
I've been visiting a few websites & reviewing the data recovery software they offer. I've checked out ZAR, WhiteCanyon, Magic Jelly Bean & MediaRecover so far. Unfortunately, I've gotten myself into a situation where my HD is damaged & I'm not sure if recovery of my valuables is possible. This is a very imperative recovery, so please, help me out.
Thanks. Sam.
October 14th, 2008, 17:26
First step in your case is to diagnose exact problem.
You have to post all the details about a drive and it symptoms, such as: it spins up, makes any noise? If you tried something, what is it?
If your drive has physical damage, there is no software will help you with your problem it could only make it worse.
October 20th, 2008, 5:30
sjohnson2 wrote:I hope this is an alright spot to post my question
Thanks. Sam.
inform the failure situation of your hdd.
October 20th, 2008, 5:36
Your problem is not detected still. How can you expect DC is for to solve the issue... You r facing problem of fever n u r taking the medicine of AIDS. what can u expect?
Submit the failure issue. Or diagnose by yourself or by professional.
October 20th, 2008, 10:56
One persons fav software, is probably someone else's pet hate. Its not so much the software you use, its the software you prefer in each different scenario that makes a difference. Knowing the advantages and disadvantages of each package is what will give better results. I like UFS Explorer because it lists the DIR structure instantly with no enumeration or anything, yet it sometimes misses data and theres no option to mark or unmark certain files and subfolders. I also like R-Studio where you can mark and unmark folders and files, but takes a while to list DIR structure sometimes, and can sometimes be unstable. I use a total of about 8 software packages, each is better than the other in a certain situation. there is no one solution, but many. Trial and error is where you will find good software.
October 20th, 2008, 10:57
shahij wrote:You r facing problem of fever n u r taking the medicine of AIDS. what can u expect?
This is so true, and so funny too! lol
October 20th, 2008, 11:13
I use all different software. R studio is very good is certain situations. Winhex is my fav though.
Please don't make fun of AIDS. I had it once and it wasn't very nice.
October 20th, 2008, 11:23
On behalf of the entire forum I would like to apologise for the reference to AIDS, and am just glad you managed to get through it.
October 20th, 2008, 11:26
Never underestimate the Power of PC3000
October 20th, 2008, 12:04
Is that how you got rid of your AIDS
October 20th, 2008, 12:09
I'm not allowed to say but yes.
October 20th, 2008, 12:12
Unfortunatley I cannot draw my own conlcusions from your bland retort. I have a bit of a sniffle at present. Do you think PC3000 could help me before it develops into green parrot disease?
October 20th, 2008, 12:14
Ive actually developed some bad sectors on my feet, do you think a remap of my service area will work? lol
