Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Cloning Tool
PostPosted: June 8th, 2017, 17:50
@bunty
My opinion of not continuing is based on the fact that this is getting to a higher technical level, and you seemed like you were not comfortable with that. If you still want to keep trying things and still have the card, I will stand by my offer of limited help to assist with fzabkar, depending on how much time I can afford to spend on it. But understand, you are at the point of experimentation. And I am only offering help to assist fzabkar with his ideas, I am not offering continued direct help as I do not have the time.
@fzabkar
If bunty wants to continue, I am willing to help some with hddsupertool scripting if needed. And by help I mean I will assist you, not write all the code myself.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: June 10th, 2017, 1:49
Hi maximus
Thanks for all the efforts. Like I said I am not comfortable with command line work & will not be able to do anything myself.
I have still kept both images and card is also with me. If someone is keen to dig deeper , I can give remote access to both .
Thanks.
PostPosted: August 12th, 2017, 8:50
Hi Maximus & fzabkar
There is update to this case , Can you pls.PM your email ID ? I want to share some information.
Thanks.
PostPosted: August 15th, 2017, 6:29
Hi Spildit
Yes I will share it with you , can you pls.PM your email ID? Since both Maximus and Fzbkar were actively involved and know this case , I want to update them.
Thanks.
