Re: ST2000DM001 doesn't spin - Need a lot of advices
November 14th, 2020, 8:11
• 3 V port (VCC(A)): 1.5 V to 3.6 V
• 5 V port (VCC(B)): 1.5 V to 5.5 V
control signals are described as 2.7-5.5, which means #OE and DIR pins i guess.
It is confusing though that input levels are given at
Low: 0-0.7(0.8)
High: 1.7- for Vcc=2.3-2.7V on channel A
November 14th, 2020, 9:55
But I had 2 more ROMS (One from my dad and another one I ordered from Aliexpress) and they were read perfectly with no issues.
November 15th, 2020, 12:04
probably a loose contact inside the rom chip itself from the pin to the die. it intermittently cuts off and on giving you the readings you have. Its only a guess though..
November 15th, 2020, 12:34
That could be. There was a "pin/leg" that was reaaaaaaaaaaally weak. When I started with all of this I had no idea how to desolder and I messed up some pins. :?
November 27th, 2020, 20:32
If you want, ship me the original drive and I'll solve it for you for no cost. (Assuming there is no head damage, and just firmware or soldering work),
