 Post subject: Maxtor N40P
PostPosted: November 8th, 2004, 20:58
No access to Maxtor DiamondMax Plus 8.
Detects in Bios as Maxtor N40P.
Get error when booting "Secondary Master Hard Drive Error" Press F1 to continue.
Definitely firmware issue, confirmed with Maxtor.
Can I just replace the board? Will another board from same spec hd work?
If I need to write internal firmware, what is the best way to go about doing this?
Code: NAR61EA0
SN#: 6E040L0711005
Thank you in advance for your help.
PostPosted: November 9th, 2004, 5:01
It's firmware disorder. Replace the PCB borad is useless. If you have pc3000 or hrt, maybe it can be repaired.
PostPosted: November 9th, 2004, 19:07
or maybe not 50/50 :)
 Post subject: i have some
PostPosted: November 10th, 2004, 0:51
i have these new firmware
001: 6E040L0711014-KCCA-B8FWA
002: 6E040L0711014-KCCA-B8FWA
003: 6E040L0510202-KGBA-B6FE1
004: 6E040L0510214-KMCA-B4FEA
005: 6E040L0711014-KMCA-B8FEA
006: 6E040L0510605-KMBA-B8FEA
007: 6E040L07110L6-KMGA-B8FED
008: 6E040L0510205-KGGA-B4FEA
009: 6E040L0510214-KMGA-B6FEB
010: 6E040L0510253-KMCA-B6FEB
011: 6E040L0510614-KMCA-B8FEA
012: 6E040L0510623-KMGA-B8FEA
013: 6E040L0510633-KMGA-B8FEA
014: 6E040L0510634-KMGA-B8FEA
if you like i can search for you
Users browsing this forum: No registered users and 163 guests
