 Post subject: hard disk gone...can i recover data from it....?
PostPosted: October 3rd, 2008, 6:04
my hard disk is gone,can i recover data from it...system is not detecting harddisk....plzzzz help....?
 Post subject: Re: hard disk gone...can i recover data from it....?
PostPosted: October 3rd, 2008, 6:28
Anything is poossible....
Can you give us a little more information?
Make/model of hard disk?
Is the disk being recognized in the BIOS? In Windows?
Any clicking sounds?
What led to the Harddisk failure?
PostPosted: October 5th, 2008, 7:50
Is the drive spinning or not ?
PostPosted: October 5th, 2008, 19:54
No, you can't recover data from it. A professional can. Send it to one if the data is important.
Note: This is a reasonably accurate answer, based on how I sized you up. If you want a slightly more accurate answer, you'll give more details. Not like 'I've got an E-Machine computer, and it doesn't work'. Specifically, what drive, what did you do, what is it doing, making sounds, etc. Otherwise, re-read the first line.
PostPosted: October 6th, 2008, 16:15
vinaypcs, really u cant, a professional can recover obviously your data...
but u can mess up with self analysis.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 6th, 2008, 16:45
where are you located?
