 Post subject: Seagate 500GB dropped
PostPosted: October 14th, 2008, 9:43
Hello friends
I want u help on this case, Seagate 500GB wich was dropped ST3500630A
The drop caused, FDB seizing and movement of heads to the begin of platters, but doesnt looks scratch over platters
Was not possible to repair it the spindle, so need to did a platter exchange, after that the hdd spins, and i can hear the reach of servo mark, but then cannot reach DRDY , stay on BSY DSC.
This is the log by terminal after did platter exchange .
Donnor was same Model, Site code, and FW, i tried head swap even, thinking on a damage of heads caused by the heads i did head swap but nothing change same log and same problem.
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
$SFI
AMR
+$SFI
AMR
(P)PATA Reset
$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
$$$SFI
AMR
$SFI
AMR
Failed sys sect. write! Nwt Er 16 RdWr 15e1a.01.0002
$SFI
AMR
DiskAccess ReadSector EC=15 at ffffffff.00.0011
$SFI
AMR
$SFI
AMR
$$SFI
AMR
$$$$SFI
AMR
T>Pgm=00 Trk=FFFFF(15E16:00[17032]).0(0).080(080) Zn=E Err=00 ErCt=0000 Hlth=0050 CHlth=0000 Ntrdy LBA=0000068E
I tried a F> test and this was the result
F>R
Buzz HM SFI
F>j,,1
3.AAE 11-03-06_16:51 AAE,GX_3D_6H_P,3A
T>R
$SFI
AMR
$SFI
AMR
$SFI
AMR
T>Pgm=00 Trk=00000(15DA2:00[16FBE]).0(0).000(000) Zn=E Err=00 ErCt=0000 Hlth=0050 CHlth=0000 Ntrdy LBA=000003E0
Like u can see the hdd reach Servo mark, and its possible to load SA, the second time , doesnt show , SFI;AMR after did type "R" inmediatly show
T> but stay at Not Ready
Any idea, im think looks like a missalignment, but how to solve it, if u want post here or on PM
Sinceraly
Alberto
 Post subject: Re: Seagate 500GB dropped
PostPosted: October 14th, 2008, 10:12
Give it more time to init
PostPosted: October 14th, 2008, 10:31
Agree. Maybe platter relative skew. Should init in a reasonable time, expect a LOOOONG image time...
PostPosted: October 14th, 2008, 12:27
There is a possibility for disk disallignment, because of the drop or transfer of the platters, which is very hard to determine now.
www.datarecoveryne.com
PostPosted: October 14th, 2008, 12:40
agree
PostPosted: October 14th, 2008, 12:43
beto wrote:
doomer thanks for u answer i left the hdd some time on the initalize process, but still its doing the same , im going to tried to upload the sound generated from the hdd maybe that could be more usefull
THanks a lot again
you don't need to post sounds. I can "hear" that "scratchy noise" from the terminal log
Drive should come ready or it should return an error (like overlay failled) and go on T level
it is of course alignment
Error 15 is: Rd/wr seek timeout code
Error 16 is: Seek timeout
You can try to re-align platters but it is hard work :(
PostPosted: October 14th, 2008, 14:17
Doomer, just a question: how much 'skewing' is tolerated in microns/degrees? I mean relative skew or rotation between platters. Doesn't PES and TF work ?
PostPosted: October 14th, 2008, 14:39
answered in PM
PostPosted: February 1st, 2011, 7:50
Any other people with this fault? I had a disk in which gave the following log. It sounded horrible, and took a couples of attempts to become ready, but then imaged OK and quickly too. The owner was not aware of any physical shock to the disk.
Reset
4096k x 32 DRAM
HM SFI
$$$SFI
AMR
(P)PATA Reset
Master
$$$$SFI
AMR
$$$$SFI
AMR
$$SFI
AMR
etc...
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: February 1st, 2011, 15:42
Happens.... but the reason need to be investigated as many causes can be (symptom is identical).
And NEVER assume customers are telling you EVERYTHING.... :mrgreen:
PostPosted: July 30th, 2024, 5:09
Got a 160GB one. With same problem. Drive was spinning but stayed busy. After swapping both Heads and PCB this are the logs
Users browsing this forum: Google [Bot] and 89 guests
