Problem with hard disk MK4025GAS??
June 24th, 2008, 11:24
Problem with hard disk MK4025GAS connect it to the adapter USD he acknowledges, but does not create a C: drive is looking for someone knows what best solution and I thank the aid.
Re: Problem with hard disk MK4025GAS??
June 24th, 2008, 14:26
Hello, sorry to say that, but it is pretty hard to understand the things U write, try to speak proper english.
It is not that good that whoever reads your post has to think hard about what you probably meant.
June 24th, 2008, 16:37
It is hard to help you, because missing a lot of knowledge about proper recovery. (as i see)
Try to put the drive directly to the PC IDE or SATA port.
Use 2.5" -> 3.5" converter if needed.
Try to diagnose this way.
Regards,
Janos
June 24th, 2008, 23:15
what did u got on ATA registers, reach readiness? DRDY DSC, BSY ? did u heard any strange sound while tried to did the recalibration process,
Best Regards
November 29th, 2008, 22:34
so what your trying to say is that the windows does not see the drive
as possible your using it for backup on your computer
do the following go to start at the bottom left hand side of windows
control panel
administrative tools
computer management
disk management
do you see the toshiba drive in the right hand side.
