 Post subject: FUJITSU MPG3409-AT
PostPosted: November 12th, 2004, 2:06
Does anyone have the HDDL Instructions in English Format?
I need to use it for a Fujitsu MPG 3409 -AT doesnt recognized
i use victoria 1.2.3b and found error in Some CP Modules from HDD System Area and Memory Area , No Errors in ROM
so if i try to repair the modules the data are destroyed? I need to recover data from hard disk, doen anyone know another program freeware,
PostPosted: November 12th, 2004, 21:23
Sorry there is no freeware to fix MPG3409, only paid software. :(
btw: what is victoria 1.2.3b ???
-BR-
 Post subject: Re: FUJITSU MPG3409-AT
PostPosted: November 13th, 2004, 4:48
Hi Alberto,
you must find faq on this forum and in archives.
you should search using google, yandex etc.
you will find what you need and then the work begins.
There are more ...... :serenade:
PostPosted: November 13th, 2004, 12:06
Hola Albero com esta tu ?
PostPosted: November 15th, 2004, 9:24
This is an ENGLISH language forum ...
Users browsing this forum: Google [Bot] and 148 guests
